查看: 1540|回复: 0
[求助] acadapp.GetAcadState.IsQuiescent 总是false,为什么?
发表于 2017-5-4 15:38:24 | 显示全部楼层 |阅读模式
VB6做的exe程序,打开dwg文件。acadapp.open 文件出现“部件忙”没有响应,点切换按钮到cad,却是空闲状态。有时候要重启cad才正常打开文件
  1.     Dim ts As String
  2.     Dim tsmsg As String
  3.     Dim acadapp As AcadApplication
  4.     On Error Resume Next
  5.     cadfilepathd = Command$
  6.     cadfilepathd = "C:\temp\1.dwg"
  7.     Set acadapp = GetObject(, "AutoCAD.Application.17.1") '检测cad是否打开
  8.     If Err.Number = 429 Then  'cad如果没有打开
  9.         Error.Clear
  10.             Set acadapp = CreateObject("", "AutoCAD.Application.17.1") '打开cad
  11.             acadapp.Visible = True 'cad可见
  12.             SendMessageBynum& acadapp.hwnd, WM_SYSCOMMAND, SC_RESTORE, 0
  13.             SetForegroundWindow acadapp.hwnd
  14.             BringWindowToTop acadapp.hwnd
  15.             If acadapp.GetAcadState.IsQuiescent = True Then
  16.               acadapp.Documents.Open cadfilepathd '打开相应文件
  17.               acadapp.Visible = True 'cad可见
  18.             End If
  19.             'SendMessageBynum& acadapp.hwnd, WM_SYSCOMMAND, SC_RESTORE, 0
  20.             SetForegroundWindow acadapp.hwnd
  21.             BringWindowToTop acadapp.hwnd
  22.     Else        '如果打开了
  23.         If acadapp.GetAcadState.IsQuiescent = True Then
  24.             acadapp.Visible = True 'cad可见
  25.             SendMessageBynum& acadapp.hwnd, WM_SYSCOMMAND, SC_RESTORE, 0
  26.             SetForegroundWindow acadapp.hwnd
  27.             BringWindowToTop acadapp.hwnd
  28.             acadapp.Documents.Open cadfilepathd '打开相应文件
  29.         Else
  30.         End If
  31.     End If
GMT+8, 2026-11-22 08:17 , Processed in 1.532875 second(s), 10 queries , Gzip On, File On.
