查看: 906|回复: 2
[每日一码] 提取图中属性到外部文件
已领礼包: 20个
发表于 2017-5-6 19:29:07 | 显示全部楼层 |阅读模式
  1. (defun gattex ()
  2.   (setq Blocklist '("Test Blockatt"))  ; ** edit to include block names to
  3.                                        ; select
  4.   (setq TagList '("TAG1"))               ; ** edit to include tag names to
  5.                                        ; extract
  6.                                        ; create block names separated by
  7.                                        ; columns, for selection filter
  8.   (setq Blocknames (List2String BlockList))
  9.   (setq ss (ssget "_X" (list '(0 . "INSERT") (cons 2 BlockNames))))
  10.   (if (not ss)
  11.     (quit)
  12.   )
  13.   (setq Root (getvar "DWGPREFIX"))
  14.   (setq file (open (strcat Root (substr (getvar "DWGNAME") 1 (-
  15.        (strlen
  16.        (getvar "DWGNAME")
  17.        ) 4
  18.                                                              )
  19.                                 ) "attributes.CSV"
  20.                    ) "w"
  21.              )
  22.         i -1
  23.   )
  24.   (write-line (strcat Root (getvar "DWGNAME") " -found " (itoa
  25.        (sslength ss)
  26.                                                          )
  27.                       " block(s) with attributes"
  28.               ) file
  29.   )
  30.   (repeat (sslength ss)
  31.     (setq TagRow nil
  32.           ValRow nil
  33.     )
  34.     (setq Edata (entget (setq e (ssname ss (setq i (1+ i))))))
  35.     (write-line "" file)
  36.     (write-line (strcat "block name:" "," (Dxf 2 Edata)) file)
  37.     (while (/= (Dxf 0 Edata) "SEQEND")
  38.       (if (and
  39.             (= (Dxf 0 Edata) "ATTRIB")
  40.             (member (dxf 2 Edata) TagList) ; if tag is on list
  41.           )                               ; and
  42.         (progn
  43.           (setq TagRow (cons (Dxf 2 Edata) TagRow))
  44.           (setq valRow (cons (Dxf 1 Edata) ValRow))
  45.         )                               ; progn
  46.       )
  47.       (setq Edata (entget (setq e (entnext e))))
  48.     )                                       ; while
  49.     (write-line (List2String (reverse TagRow)) file)
  50.     (write-line (List2String (reverse ValRow)) file)
  51.   )                                       ; repeat
  52.   (close file)
  53.   (princ (strcat "\nDone writing file " Root "attributes.csv"))
  54.   (princ)
  55. )
  56. ;defun
  57. ;;-------------------------------
  58. (defun List2String (Alist)
  59.   (setq NumStr (length Alist))
  60.   (foreach Item AList
  61.     (if (= Item (car AList))               ; first item
  62.       (setq LongString (car AList))
  63.       (setq LongString (strcat LongString "," Item))
  64.     )
  65.   )
  66.   LongString
  67. )
  68. ;defun
  69. ;;--------------------------------
  70. (defun Dxf (code pairs)
  71.   (cdr (assoc code pairs))
  72. )
  73. (defun c:test ()
  74.   (gattex)
  75.   (princ)
  76. )
下面是VBA代码
[Visual Basic .NET] 纯文本查看 复制代码
Sub Blocks(row, col)
    Dim BlocksSelSet As AcadSelectionSet
    Dim blockref As AcadBlockReference
    Dim AttRef As Variant
    Dim I As Integer
    Dim gpCode(0) As Integer
    Dim dataValue(0) As Variant
    Dim groupCode As Variant, dataCode As Variant
    Dim NumOfBlocks As Integer
    Dim mode
    Dim AttMode As Long
    Dim constant As String
    Dim currentmode As Integer
    Dim attrobject As AcadAttribute
    On Error Resume Next
    Set BlocksSelSet = ThisDrawing.SelectionSets.Add("All_Blocks")
'define type of selection set (crossing, window, etc, in this case, all)
    mode = acSelectionSetAll
'this is a selection set filter
    gpCode(0) = 0
    dataValue(0) = "Insert"
    groupCode = gpCode
    dataCode = dataValue
    'this collects all blocks into the seletion set
    BlocksSelSet.Select mode, , , groupCode, dataCode
    NumOfBlocks = BlocksSelSet.Count
    For x = 1 To NumOfBlocks
        Set blockref = BlocksSelSet(x)
        excelsheet.Cells(row, col).Value = blockref.Name
        excelsheet.Cells(row, col + 1).Value = blockref.layer
        excelsheet.Cells(row, col + 2).Value = Format(blockref.insertionPoint(0), "##,##0.00") & "," & Format(blockref.insertionPoint(1), "##,##0.00")
        row = row + 1
        AttRef = blockref.GetAttributes
            For I = LBound(AttRef) To UBound(AttRef)
            Set attrobject = AttRef(I)
                ' Do something with the attribute refs here.
                excelsheet.Cells(row, col).Value = AttRef(I).TagString
                excelsheet.Cells(row, col + 1).Value = AttRef(I).layer
                excelsheet.Cells(row, col + 3).Value = AttRef(I).TextString
                constant = Choose(attrobject.mode, "acAttributeModeInvisible", "acAttributeModeConstant", "", "acAttributeModeVerify", "", "", "", "acAttributeModePreset")
                row = row + 1
            Next
    Next
    row = row + 1
  'clean up
    BlocksSelSet.Clear
    BlocksSelSet.Delete
    rownum = row
End Sub
已领礼包: 780个
发表于 2017-5-7 20:58:15 | 显示全部楼层
哇,简直酷毙了!!!
已领礼包: 6056个
发表于 2017-5-8 00:06:08 | 显示全部楼层
谢谢分享。
GMT+8, 2026-11-5 22:07 , Processed in 0.457164 second(s), 33 queries , Gzip On.
