查看: 1794|回复: 5
[每日一码] 多段线自动标注所有边和所有内角的代码
已领礼包: 20个
发表于 2017-5-7 10:25:53 | 显示全部楼层 |阅读模式
  1. (defun c:dimpolygons (/         *error*   mr_IsPointInside    mid
  2.                       adoc      spc       sel       d         i
  3.                       lw        enx       pl        lwn       enxn
  4.                       plni      plno      plnom     plm       clr
  5.                       lastent  ss        en
  6.                      )
  7.   (vl-load-com)
  8.   (defun *error* (m)
  9.     (vla-endundomark adoc)
  10.     (if m
  11.       (prompt m)
  12.     )
  13.     (princ)
  14.   )
  15.
  16.   (setq lastEnt (entlast))
  17.
  18.   (setq clr (getvar "CLAYER"))
  19.   (command "-layer" "Make" "0-Dims" "color" "3" "" "")
  20.   (defun mr_IsPointInside (pt ptlst / trianglst ptinsidetriangle-p trl)
  21.     (defun trianglst (ptlst       /           unique
  22.                       LM:ListClockwise-p      clockwise-p l
  23.                       p1          p2          p3          trl
  24.                      )
  25.       (defun unique (l)
  26.         (if l
  27.           (cons (car l)
  28.                 (unique (vl-remove-if
  29.                           (function (lambda (x) (equal x (car l) 1e-6)))
  30.                           l
  31.                         )
  32.                 )
  33.           )
  34.         )
  35.       )
  36.       ;; List Clockwise-p - Lee Mac
  37.       ;; Returns T if the point list is clockwise oriented
  38.       (defun LM:ListClockwise-p (lst)
  39.         (minusp
  40.           (apply '+
  41.                  (mapcar
  42.                    (function
  43.                      (lambda (a b)
  44.                        (- (* (car b) (cadr a)) (* (car a) (cadr b)))
  45.                      )
  46.                    )
  47.                    lst
  48.                    (cons (last lst) lst)
  49.                  )
  50.           )
  51.         )
  52.       )
  53.       (defun clockwise-p (p1 p2 p3)
  54.         (< (* (- (car p2) (car p1)) (- (cadr p3) (cadr p1)))
  55.            (* (- (cadr p2) (cadr p1)) (- (car p3) (car p1)))
  56.         )
  57.       )
  58.       (setq l ptlst)
  59.       (while (> (length ptlst) 3)
  60.         (setq p1 (car ptlst)
  61.               p2 (cadr ptlst)
  62.               p3 (caddr ptlst)
  63.         )
  64.         (cond
  65.           ((LM:ListClockwise-p ptlst)
  66.            (if
  67.              (and
  68.                (clockwise-p p1 p2 p3)
  69.                (= (length
  70.                     (unique
  71.                       (vl-remove
  72.                         nil
  73.                         (mapcar
  74.                           (function (lambda (a b) (inters p1 p2 a b)))
  75.                           l
  76.                           (cdr (reverse (cons (car l) (reverse l))))
  77.                         )
  78.                       )
  79.                     )
  80.                   )
  81.                   2
  82.                )
  83.                (= (length
  84.                     (unique
  85.                       (vl-remove
  86.                         nil
  87.                         (mapcar
  88.                           (function (lambda (a b) (inters p2 p3 a b)))
  89.                           l
  90.                           (cdr (reverse (cons (car l) (reverse l))))
  91.                         )
  92.                       )
  93.                     )
  94.                   )
  95.                   2
  96.                )
  97.                (= (length
  98.                     (unique
  99.                       (vl-remove
  100.                         nil
  101.                         (mapcar
  102.                           (function (lambda (a b) (inters p3 p1 a b)))
  103.                           l
  104.                           (cdr (reverse (cons (car l) (reverse l))))
  105.                         )
  106.                       )
  107.                     )
  108.                   )
  109.                   2
  110.                )
  111.              )
  112.               (progn
  113.                 (setq trl (cons (list p1 p2 p3) trl))
  114.                 (setq ptlst (vl-remove p2 ptlst))
  115.                 (setq ptlst
  116.                        (cdr (reverse (cons (car ptlst) (reverse ptlst)))
  117.                        )
  118.                 )
  119.               )
  120.               (setq ptlst
  121.                      (cdr (reverse (cons (car ptlst) (reverse ptlst))))
  122.               )
  123.            )
  124.           )
  125.           ((not (LM:ListClockwise-p ptlst))
  126.            (if
  127.              (and
  128.                (not (clockwise-p p1 p2 p3))
  129.                (= (length
  130.                     (unique
  131.                       (vl-remove
  132.                         nil
  133.                         (mapcar
  134.                           (function (lambda (a b) (inters p1 p2 a b)))
  135.                           l
  136.                           (cdr (reverse (cons (car l) (reverse l))))
  137.                         )
  138.                       )
  139.                     )
  140.                   )
  141.                   2
  142.                )
  143.                (= (length
  144.                     (unique
  145.                       (vl-remove
  146.                         nil
  147.                         (mapcar
  148.                           (function (lambda (a b) (inters p2 p3 a b)))
  149.                           l
  150.                           (cdr (reverse (cons (car l) (reverse l))))
  151.                         )
  152.                       )
  153.                     )
  154.                   )
  155.                   2
  156.                )
  157.                (= (length
  158.                     (unique
  159.                       (vl-remove
  160.                         nil
  161.                         (mapcar
  162.                           (function (lambda (a b) (inters p3 p1 a b)))
  163.                           l
  164.                           (cdr (reverse (cons (car l) (reverse l))))
  165.                         )
  166.                       )
  167.                     )
  168.                   )
  169.                   2
  170.                )
  171.              )
  172.               (progn
  173.                 (setq trl (cons (list p1 p2 p3) trl))
  174.                 (setq ptlst (vl-remove p2 ptlst))
  175.                 (setq ptlst
  176.                        (cdr (reverse (cons (car ptlst) (reverse ptlst)))
  177.                        )
  178.                 )
  179.               )
  180.               (setq ptlst
  181.                      (cdr (reverse (cons (car ptlst) (reverse ptlst))))
  182.               )
  183.            )
  184.           )
  185.         )
  186.       )
  187.       (setq
  188.         trl (cons (list (car ptlst) (cadr ptlst) (caddr ptlst)) trl)
  189.       )
  190.       trl
  191.     )
  192.     (defun ptinsidetriangle-p (pt p1 p2 p3)
  193.       (and
  194.         (not
  195.           (or
  196.             (inters pt p1 p2 p3)
  197.             (inters pt p2 p1 p3)
  198.             (inters pt p3 p1 p2)
  199.           )
  200.         )
  201.         (not
  202.           (or
  203.             (> (+ (distance pt p1) (distance pt p2))
  204.                (+ (distance p3 p1) (distance p3 p2))
  205.             )
  206.             (> (+ (distance pt p2) (distance pt p3))
  207.                (+ (distance p1 p2) (distance p1 p3))
  208.             )
  209.             (> (+ (distance pt p3) (distance pt p1))
  210.                (+ (distance p2 p3) (distance p2 p1))
  211.             )
  212.           )
  213.         )
  214.       )
  215.     )
  216.     (setq trl (trianglst ptlst))
  217.     (vl-some (function
  218.                (lambda (x)
  219.                  (ptinsidetriangle-p pt (car x) (cadr x) (caddr x))
  220.                )
  221.              )
  222.              trl
  223.     )
  224.   )
  225.   (defun mid (p1 p2)
  226.     (mapcar (function (lambda (a b) (/ (+ a b) 2.0))) p1 p2)
  227.   )
  228.   (vla-startundomark
  229.     (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
  230.   )
  231.   (setq spc (vla-get-block (vla-get-activelayout adoc)))
  232.   (if (not (tblsearch "DIMSTYLE" "MVVA Standard Imperial"))
  233.     (Alert "MVVA Standard Imperial dimension style not loaded")
  234.     (Command "-dimstyle" "r" "MVVA Standard Imperial")
  235.   )
  236.   (prompt "\nSelect closed POLYGONS...")
  237.   (setq sel (ssget (list '(0 . "LWPOLYLINE") '(-4 . "&=")
  238.                          '(70 . 1)           '(-4 . "<not")
  239.                          '(-4 . "<>")        '(42 . 0.0)
  240.                          '(-4 . "not>")
  241.                         )
  242.             )
  243.   )
  244.   (initget 7)
  245.   (setq d (getdist
  246.             "\nPick or specify offset distance for dimensioning : "
  247.           )
  248.   )
  249.   (if sel
  250.     (progn
  251.       (repeat (setq i (sslength sel))
  252.         (setq lw (ssname sel (setq i (1- i))))
  253.         (setq enx (entget lw))
  254.         (setq
  255.           pl (mapcar
  256.                (function
  257.                  (lambda (x)
  258.                    (trans (list (car x) (cadr x) (cdr (assoc 38 enx)))
  259.                           lw
  260.                           1
  261.                    )
  262.                  )
  263.                )
  264.                (mapcar (function cdr)
  265.                        (vl-remove-if
  266.                          (function (lambda (x) (/= (car x) 10)))
  267.                          enx
  268.                        )
  269.                )
  270.              )
  271.         )
  272.         (vla-offset (vlax-ename->vla-object lw) d)
  273.         (setq lwn (entlast))
  274.         (setq enxn (entget lwn))
  275.         (setq plni
  276.                (mapcar
  277.                  (function
  278.                    (lambda (x)
  279.                      (trans (list (car x) (cadr x) (cdr (assoc 38 enxn)))
  280.                             lwn
  281.                             1
  282.                      )
  283.                    )
  284.                  )
  285.                  (mapcar (function cdr)
  286.                          (vl-remove-if
  287.                            (function (lambda (x) (/= (car x) 10)))
  288.                            enxn
  289.                          )
  290.                  )
  291.                )
  292.         )
  293.         (if (not (mr_IsPointInside (car plni) pl))
  294.           (progn
  295.             (entdel lwn)
  296.             (vla-offset (vlax-ename->vla-object lw) (- d))
  297.             (setq lwn (entlast))
  298.             (setq enxn (entget lwn))
  299.             (setq plni
  300.                    (mapcar
  301.                      (function
  302.                        (lambda (x)
  303.                          (trans
  304.                            (list (car x) (cadr x) (cdr (assoc 38 enxn)))
  305.                            lwn
  306.                            1
  307.                          )
  308.                        )
  309.                      )
  310.                      (mapcar (function cdr)
  311.                              (vl-remove-if
  312.                                (function (lambda (x) (/= (car x) 10)))
  313.                                enxn
  314.                              )
  315.                      )
  316.                    )
  317.             )
  318.           )
  319.         )
  320.         (entdel lwn)
  321.         (setq
  322.           plno (mapcar
  323.                  (function
  324.                    (lambda (a b)
  325.                      (mapcar (function +) a (mapcar (function -) a b))
  326.                    )
  327.                  )
  328.                  pl
  329.                  plni
  330.                )
  331.         )
  332.         (setq plnom
  333.                (mapcar (function (lambda (a b) (mid a b)))
  334.                        plno
  335.                        (cdr (reverse (cons (car plno) (reverse plno))))
  336.                )
  337.         )
  338.         (mapcar (function (lambda (a b c)
  339.                             (vla-addDimAligned
  340.                               spc
  341.                               (vlax-3d-point a)
  342.                               (vlax-3d-point b)
  343.                               (vlax-3d-point c)
  344.                             )
  345.                           )
  346.                 )
  347.                 pl
  348.                 (cdr (reverse (cons (car pl) (reverse pl))))
  349.                 plnom
  350.         )
  351.         (setq pl (reverse (cons (car pl) (reverse pl))))
  352.         (setq
  353.           plm (mapcar (function (lambda (a b) (mid a b))) pl (cdr pl))
  354.         )
  355.         (mapcar (function (lambda (a b c d)
  356.                             (vla-AddDim3PointAngular
  357.                               spc
  358.                               (vlax-3d-point a)
  359.                               (vlax-3d-point b)
  360.                               (vlax-3d-point c)
  361.                               (vlax-3d-point d)
  362.                             )
  363.                           )
  364.                 )
  365.                 (cdr pl)
  366.                 plm
  367.                 (cdr (reverse (cons (car plm) (reverse plm))))
  368.                 (cdr (reverse (cons (car plni) (reverse plni))))
  369.         )
  370.       )
  371.     )
  372.     (prompt
  373.       "\nEmpty sel. set... Retry routine with valid sel. set..."
  374.     )
  375.   )
  376.
  377.   (setq ss (ssadd))
  378.   (if (setq en (entnext LastEnt))       ;Check if there's a new entity created since the last one
  379.     (while en                           ;Step through all new entities
  380.       (ssadd en ss)                     ;Add it to the selection set
  381.       (setq en (entnext en))            ;Get the next entity
  382.     )
  383.   )
  384.   (command "_.-dimstyle" "Apply" ss "")
  385.
  386.   (*error* nil)
  387.   (setvar "CLAYER" clr)
  388. )
已领礼包: 3191个
发表于 2017-5-7 10:46:12 | 显示全部楼层
太好了,好好学习天天向上,不断进步
已领礼包: 780个
发表于 2017-5-7 13:21:07 | 显示全部楼层
这个必须顶!!!!!!
已领礼包: 5800个
发表于 2017-5-7 16:29:40 | 显示全部楼层
大师的代码就是牛,代码看着就舒服。
已领礼包: 1827个
财富等级: 堆金积玉
发表于 2017-5-7 19:44:44 | 显示全部楼层
出现这个是怎么回事,错误: 输入的字符串太长
发表于 2019-8-31 22:40:01 | 显示全部楼层
太好了,感谢分享,大师辛苦了
GMT+8, 2026-11-4 17:49 , Processed in 0.610333 second(s), 42 queries , Gzip On.
