查看: 1246|回复: 1
[每日一码] 设置尺寸样式相关设置为BYLAYER
发表于 2017-5-9 13:23:39 | 显示全部楼层 |阅读模式
  1. (defun c:DS2BL (/ acdoc dsobj obj)
  2.   (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
  3.   (setq dsobj (vla-get-dimstyles acdoc))
  4.   (vlax-for obj dsobj
  5.     (vla-put-activedimstyle acdoc (vla-item dsobj (vla-get-name obj))) ;set dimstyle current
  6.     (vlax-invoke acdoc 'setvariable "DimCLRD" 256) ;Dimension line and leader color
  7.     (vlax-invoke acdoc 'setvariable "DimCLRE" 256) ;Extension line color
  8.     (vlax-invoke acdoc 'setvariable "DimCLRT" 256) ;Dimension text color
  9.     (vla-copyfrom obj acdoc) ; update the Dim Style
  10.   )
  11.   (princ)
  12. )
 楼主| 发表于 2017-5-9 13:27:09 | 显示全部楼层
命令版本
  1. (defun c:DCBL (/ DimStyles@ StyleName$)
  2. (princ "\nDimstyles color bylayer")
  3.         (setq StyleName$ (cdr (assoc 2 (tblnext "DIMSTYLE" t))))
  4.         (setq DimStyles@ (list StyleName$))
  5.
  6.         (while (setq StyleName$ (cdr (assoc 2 (tblnext "DIMSTYLE"))))
  7.                 (setq DimStyles@ (append DimStyles@ (list StyleName$)))
  8.         )                ;end while
  9.
  10.         (foreach StyleName$ DimStyles@
  11.                 (command "DIMSTYLE" "R" StyleName$)
  12.                 (setvar "DIMCLRD" 256)                                        ;Dimension line and leader color
  13.                 (setvar "DIMCLRE" 256)                                        ;Extension line color
  14.                 (setvar "DIMCLRT" 256)                                        ;Dimension text color
  15.                 (command "DIMSTYLE" "S" StyleName$ "Y")
  16.         )                ;foreach
  17. (princ)
  18. )
GMT+8, 2026-11-6 00:15 , Processed in 0.353097 second(s), 31 queries , Gzip On.
