查看: 1381|回复: 3
[每日一码] 列出所有冻结的图层
发表于 2017-5-9 16:12:10 | 显示全部楼层 |阅读模式
  1. (defun lislayerdoc ( / d l r )
  2.     (while (setq d (tblnext "layer" (not d)))
  3.         (if (and (zerop (logand 21 (cdr (assoc 70 d))))
  4.                  (< 0 (cdr (assoc 62 d)))
  5.                  (/= "defpoints" (strcase (setq l (cdr (assoc 2 d))) t))
  6.             )
  7.             (setq r (cons l r))
  8.         )
  9.     )
  10.     (vl-sort r '<)
  11. )
已领礼包: 1742个
财富等级: 堆金积玉
发表于 2017-5-9 16:17:05 | 显示全部楼层
图层 vla相对方便些
  1. (defun lislayerdoc(l)
  2.   (vlax-for x (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
  3.     (if (= (vlax-get-property x "Freeze") :vlax-true)
  4.       (setq l (cons (vla-get-name x) l))
  5.     )
  6.   )
  7.   l
  8. )
已领礼包: 217个
发表于 2017-5-9 16:19:04 | 显示全部楼层
犀利啊我的哥,您的方法我试了可以的。楼主的办法有问题,获取的图层都是非冻结的。
已领礼包: 9341个
发表于 2017-5-9 18:01:14 | 显示全部楼层
正需要,支持楼主大人了!
GMT+8, 2026-11-6 00:14 , Processed in 0.392165 second(s), 35 queries , Gzip On.
