查看: 1696|回复: 1
[求助] 请问下各位大佬arx中怎么打印图纸的啊,网上没什么资料
发表于 2017-5-10 17:33:57 | 显示全部楼层 |阅读模式
请问下各位大佬arx中怎么打印图纸的啊,网上没找到资料;
已领礼包: 13个
发表于 2017-5-10 18:55:27 | 显示全部楼层
下面是ARX中用ACTIVEX批处理打印所有LAYOUTS的简单例子代码
关键步骤是:
1) Set the number of layouts be plotted using the method StartBatchMode() of the IAcadPlot object.
2) Preparing a variant array of BSTRs having the names of the layouts to be plotted and then pass it as argument to SetLayoutsToPlot() method.
3) Finally to plot, use PlotToDevice() method.
  1. //use MFC to test this code
  2. #import "acax19enu.tlb" raw_interfaces_only no_namespace
  3. void fBatchPlotLayouts()
  4. {
  5. try
  6. {
  7.   //get the AutoCAD application
  8.   IAcadApplicationPtr pApp = NULL;
  9.   pApp = acedGetAcadWinApp()->GetIDispatch(TRUE);
  10.   //get the Active Document
  11.   IAcadDocumentPtr pDoc = NULL;
  12.   pApp->get_ActiveDocument(&pDoc);
  13.   IAcadLayoutsPtr pLayOuts;
  14.   IAcadLayoutPtr pLayOut;
  15.   long mNumberOflayouts;
  16.   //get the layouts collection and the number of layouts
  17.   pDoc->get_Layouts(&pLayOuts);
  18.   pLayOuts->get_Count(&mNumberOflayouts);
  19.   //create the variant array that will hold the layout names
  20.   VARIANT mLayArr;
  21.   SAFEARRAYBOUND mSAB;
  22.   mSAB.lLbound = 0;
  23.   mSAB.cElements = mNumberOflayouts;
  24.   VariantInit(&mLayArr);
  25.   mLayArr.vt = VT_ARRAY | VT_BSTR;
  26.   mLayArr.parray = SafeArrayCreate(VT_BSTR,1,&mSAB);
  27.   //populate the variant array
  28.   long mCtr;
  29.   //note that array here has zero based index
  30.   for(mCtr = 0; mCtr < mNumberOflayouts; mCtr ++)
  31.   {
  32.    pLayOuts->Item(_variant_t(mCtr), &pLayOut);
  33.    BSTR strName;
  34.    pLayOut->get_Name(&strName);
  35.    SafeArrayPutElement(mLayArr.parray, &mCtr, strName);
  36.   }
  37.   //print the layout names that are being plotted
  38.   BSTR bstrName;
  39.   acutPrintf(_T("\nLayouts to be plotted:"));
  40.   for(mCtr = 0; mCtr < mNumberOflayouts;mCtr ++)
  41.   {
  42.    SafeArrayGetElement(mLayArr.parray,&mCtr,&bstrName);
  43.    acutPrintf(_T("\n%s"),(TCHAR*)(_bstr_t)bstrName);
  44.   }
  45.   acutPrintf(_T("\nPlotting started...\n"));
  46.   //plot the layouts
  47.   IAcadPlotPtr pPlot;
  48.   pDoc->get_Plot(&pPlot);
  49.   //set the number of plots and error mode to quiet
  50.   pPlot->put_NumberOfCopies(1);
  51.   pPlot->put_QuietErrorMode(VARIANT_TRUE);
  52.   //number of layouts to be plotted
  53.   pPlot->StartBatchMode(mNumberOflayouts);
  54.   //set the layouts to plot
  55.   pPlot->SetLayoutsToPlot(mLayArr);
  56.   VARIANT_BOOL returnBool;
  57.   pPlot->PlotToDevice(_variant_t("DWF6 ePlot.pc3"), &returnBool);
  58.   //clean up
  59.   VariantClear(&mLayArr);
  60. }
  61. catch (_com_error &e)
  62. {
  63.   acutPrintf(
  64.    _T("\nError while batch plotting. %s"),e.ErrorMessage());
  65. }
  66. }
GMT+8, 2026-11-3 03:11 , Processed in 0.421472 second(s), 30 queries , Gzip On.
