查看: 1036|回复: 2
[研讨] 来,我们看看普通的加法,对不同数据类型的执行效率
发表于 2017-5-17 10:45:50 | 显示全部楼层 |阅读模式
  1. (XD::Benchmark
  2.   '((1+ 1)
  3.     (+ 1 1)
  4.     (+ 1 1.0)
  5.     (+ 1.0 1.0)
  6.    )
  7. )
  1. Elapsed milliseconds / relative speed for 32768 iteration(s):
  2.     (1+ 1)..........1313 / 1.17 <fastest>
  3.     (+ 1 1).........1485 / 1.03
  4.     (+ 1 1.0).......1485 / 1.03
  5.     (+ 1.0 1.0).....1531 / 1 <slowest>
复制代码
1、整数相加, 1+函数 比 + 快
2、整数和实数相加,效率基本相同
3、实数相加,效率最慢
 楼主| 发表于 2017-5-17 10:59:37 | 显示全部楼层
所以,选择集操作,尽量用1+
  1. (setq ss (ssget "x"))
  2. (defun ss1 (ss / i lst e)
  3.   (setq i -1)
  4.   (while (setq e (ssname ss (setq i (1+ i))))
  5.     (setq lst (cons e lst))
  6.   )
  7.   (princ)
  8. )
  9. (defun ss2 (ss / i lst e)
  10.   (setq i -1)
  11.   (while (setq e (ssname ss (setq i (+ i 1))))
  12.     (setq lst (cons e lst))
  13.   )
  14.   (princ)
  15. )
  16. (defun c:tt ()
  17.   (XD::Benchmark
  18.     '((ss1 ss)
  19.       (ss2 ss)
  20.      )
  21.   )
  22.   (princ)
  23. )
测试:
  1. 命令: (repeat 5 (c:tt))
  2. Elapsed milliseconds / relative speed for 16384 iteration(s):
  3.     (SS1 SS).....1625 / 1.04 <fastest>
  4.     (SS2 SS).....1688 / 1 <slowest>
  5. Elapsed milliseconds / relative speed for 8192 iteration(s):
  6.     (SS2 SS).....1719 / 1.18 <fastest>
  7.     (SS1 SS).....2032 / 1 <slowest>
  8. Elapsed milliseconds / relative speed for 4096 iteration(s):
  9.     (SS1 SS).....1000 / 1 <fastest>
  10.     (SS2 SS).....1000 / 1 <slowest>
  11. Elapsed milliseconds / relative speed for 4096 iteration(s):
  12.     (SS2 SS).....1063 / 1.01 <fastest>
  13.     (SS1 SS).....1078 / 1 <slowest>
  14. Elapsed milliseconds / relative speed for 8192 iteration(s):
  15.     (SS1 SS).....1750 / 1.02 <fastest>
  16.     (SS2 SS).....1781 / 1 <slowest>
复制代码
基本上是1+要快
 楼主| 发表于 2017-5-17 11:10:17 | 显示全部楼层
那遍历选择集递增写法
和
(ssname ss i)
(setq i (1+ i))
两种写法哪个快?
  3.   (setq i -1)
  5.    )
  6.   (princ)
  7. )
  8. (defun ss4 (ss / i lst e)
  9.   (setq i 0)
  10.   (while (setq e (ssname ss i))
  11.     (setq i (1+ i))
  12.   )
  13.   (princ)
  14. )
  15. (defun c:tt1 ()
  16.   (XD::Benchmark
  17.     '((ss1 ss)
  18.       (ss4 ss)
  19.      )
  20.   )
  21.   (princ)
  22. )
  1. 命令: (repeat 5 (c:tt1))
  3.     (SS4 SS).....1406 / 1.11 <fastest>
  4.     (SS1 SS).....1563 / 1 <slowest>
  6.     (SS1 SS).....1625 / 1.12 <fastest>
  7.     (SS4 SS).....1828 / 1 <slowest>
  8. Elapsed milliseconds / relative speed for 8192 iteration(s):
  9.     (SS4 SS).....1735 / 1.09 <fastest>
  10.     (SS1 SS).....1891 / 1 <slowest>
  11. Elapsed milliseconds / relative speed for 8192 iteration(s):
  12.     (SS4 SS).....1578 / 1.06 <fastest>
  13.     (SS1 SS).....1672 / 1 <slowest>
  15.     (SS1 SS).....1672 / 1.04 <fastest>
  16.     (SS4 SS).....1734 / 1 <slowest>
复制代码
基本上,是分开写的要快
(ssname ss i)
(setq i (1+ i))
大家也可以在你的机器上测试下上面代码。
GMT+8, 2026-11-5 22:53 , Processed in 0.790427 second(s), 33 queries , Gzip On.
