查看: 1237|回复: 1
[分享] 块的拖动类的实现
发表于 2017-5-20 19:25:01 | 显示全部楼层 |阅读模式
按照Arx例子写了一个块的拖动类,有两个动作:移动和旋转
移动取点,旋转取角度
代码中PromptPointResult res = prompts.AcquirePoint(jigOpts);是取点的动作,想改为AcquireAngle一直没有成功
代码如下:
[C#] 纯文本查看 复制代码
using System;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
namespace TlsCad
       public class BlockRefJig:EntityJig
              Point3d mPosition;
              double mAngle;
              int mPromptCounter;
              public BlockRefJig(ObjectId id):base(new BlockReference(new Point3d(0,0,0),id))
                     mPosition=new Point3d(0,0,0);
                     mAngle=0;
              protected override SamplerStatus Sampler(JigPrompts prompts)
                     JigPromptOptions jigOpts = new JigPromptOptions();
                     if(mPromptCounter == 0)
                            jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates | UserInputControls.NoZeroResponseAccepted | UserInputControls.NoNegativeResponseAccepted );
                            jigOpts.Message = "\n请输入基点:";
                            PromptPointResult dres = prompts.AcquirePoint(jigOpts);
                            Point3d positionTemp = dres.Value;
                            if(positionTemp != mPosition)
                                   mPosition = positionTemp;
                            else
                                   return SamplerStatus.NoChange;
                            if(dres.Status == PromptStatus.Cancel)
                                   return SamplerStatus.Cancel;
                            else
                                   return SamplerStatus.OK;
                     else if (mPromptCounter == 1)
                            jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates | UserInputControls.NoNegativeResponseAccepted);
                            jigOpts.BasePoint = mPosition;
                            jigOpts.UseBasePoint = true;
                            jigOpts.Message = "\n请输入旋转角度:";
                            double angleTemp = -1;
                            Point3d AnglePnt = res.Value;
                            angleTemp = AnglePnt.GetVectorTo(mPosition).AngleOnPlane(
                                   new Plane(
                                   Application.DocumentManager.MdiActiveDocument.Database.Ucsorg,
                                   Application.DocumentManager.MdiActiveDocument.Database.Ucsxdir,
                                   Application.DocumentManager.MdiActiveDocument.Database.Ucsydir
                            if (angleTemp != mAngle)
                                   mAngle = angleTemp;
                            else
                            if(res.Status == PromptStatus.Cancel)
                            else
                     else
              protected override bool Update()
                     try
                            ((BlockReference)Entity).Position=mPosition;
                            ((BlockReference)Entity).Rotation =mAngle;
                     catch(System.Exception)
                            return false;
                     return true;
              public void setPromptCounter(int i)
                     mPromptCounter = i;
              public Entity GetEntity()
                     return Entity;
2007下,下面修改了一些BUG
[C#] 纯文本查看 复制代码
using System;
namespace TlsCad
        Point3d mPosition;
        double mAngle;
        int mPromptCounter;
            mAngle=0;
                JigPromptPointOptions jigOpts = new JigPromptPointOptions();
                Point3d positionTemp = res.Value;
                else
                else
                JigPromptAngleOptions jigOpts = new JigPromptAngleOptions();
                PromptDoubleResult res = prompts.AcquireAngle(jigOpts);
                double angleTemp = res.Value;
                    mAngle = angleTemp;
                else
                if (res.Status == PromptStatus.Cancel)
                else
            else
            try
                return false;
            return true;
            mPromptCounter = i;
            return Entity;
已领礼包: 3191个
发表于 2017-5-21 08:10:01 | 显示全部楼层
学习了,好好学习天天向上
GMT+8, 2026-11-3 13:44 , Processed in 2.403114 second(s), 30 queries , Gzip On.
