查看: 1353|回复: 2
[分享] 使用.NET获取一个图层上的所有实体
发表于 2017-5-21 08:25:02 | 显示全部楼层 |阅读模式
[C#] 纯文本查看 复制代码
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
namespace EntitySelection
  public class Commands
    [CommandMethod("EOL")]
    static public void EntitiesOnLayer()
      Document doc =
        Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      PromptResult pr =
        ed.GetString("\nEnter name of layer: ");
      if (pr.Status == PromptStatus.OK)
        ObjectIdCollection ents =
          GetEntitiesOnLayer(pr.StringResult);
        ed.WriteMessage(
          "\nFound {0} entit{1} on layer {2}",
          ents.Count,
          (ents.Count == 1 ? "y" : "ies"),
          pr.StringResult
    private static ObjectIdCollection
      GetEntitiesOnLayer(string layerName)
      Document doc =
      // Build a filter list so that only entities
      // on the specified layer are selected
      TypedValue[] tvs =
        new TypedValue[1] {
            new TypedValue(
              (int)DxfCode.LayerName,
              layerName
      SelectionFilter sf =
        new SelectionFilter(tvs);
      PromptSelectionResult psr =
        ed.SelectAll(sf);
      if (psr.Status == PromptStatus.OK)
        return
          new ObjectIdCollection(
            psr.Value.GetObjectIds()
      else
        return new ObjectIdCollection();
另外一个
[C#] 纯文本查看 复制代码
// 访问AutoCAD程序对象。
// 访问 the AutoCAD 编辑器。
// 命令注册。
// 访问数据库对象。
        [CommandMethod("SelectOnlayer")]
        static public void SelectEnt()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            PromptResult pr =
             ed.GetString("\n请输入图层名称: ");
                TypedValue[] filList = new TypedValue[1];
                filList[0] = new TypedValue((int)DxfCode.LayerName, pr.StringResult);
                SelectionFilter filter = new SelectionFilter(filList);
                PromptSelectionResult ssRes = ed.SelectAll(filter);
                if (ssRes.Status == PromptStatus.OK)
                    SelectionSet SS = ssRes.Value;
                    int nCount = SS.Count;
                    ed.WriteMessage("在{0}层上找到{1}个实体", pr.StringResult, nCount);
已领礼包: 15个
发表于 2017-11-14 15:46:15 | 显示全部楼层
好东西,学习了
发表于 2018-1-9 08:58:05 | 显示全部楼层
haole ,zenme wode ping dazi yongbule
GMT+8, 2026-11-2 21:47 , Processed in 0.463597 second(s), 32 queries , Gzip On.
