查看: 3318|回复: 8
[每日一码] 设置动态块的属性值
已领礼包: 20个
发表于 2017-5-19 13:29:40 | 显示全部楼层 |阅读模式
  1. (defun set-dynprop (blk prop value / def err)
  2.                    ;|
  3. blk    pointer to block reference
  4. prop   dynmic property name
  5. value  value to set to prop
  6. call sample:
  7. (set-dynprop (car (entsel "\nSelect block")) "base" 2)
  8. |;
  9.   (if (and (setq blk (cond
  10.                        ((= (type blk) 'ename)
  11.                         (setq blk (vlax-ename->vla-object blk))
  12.                         )
  13.                        ((= (type blk) 'vla-object) blk)
  14.                        ) ;_ end of cond
  15.                  ) ;_ end of setq
  16.            (= (vla-get-objectname blk) "AcDbBlockReference")
  17.            (vlax-method-applicable-p blk 'getdynamicblockproperties)
  18.            (setq def (car (vl-remove-if-not
  19.                             (function
  20.                               (lambda (x)
  21.                                 (= (strcase prop) (strcase (vla-get-propertyname x)))
  22.                                 ) ;_ end of LAMBDA
  23.                               ) ;_ end of function
  24.                             (vlax-safearray->list (vlax-variant-value (vla-getdynamicblockproperties blk)))
  25.                             ) ;_ end of vl-remove-if-not
  26.                           ) ;_ end of car
  27.                  ) ;_ end of setq
  28.            ) ;_ end of and
  29.     (if (vl-catch-all-error-p
  30.           (setq err (vl-catch-all-apply
  31.                       (function
  32.                         (lambda ()
  33.                           (vla-put-value def value)
  34.                           ) ;_ end of LAMBDA
  35.                         ) ;_ end of function
  36.                       ) ;_ end of VL-CATCH-ALL-APPLY
  37.                 ) ;_ end of setq
  38.           ) ;_ end of VL-CATCH-ALL-ERROR-P
  39.       (princ (strcat "\nError setting value "
  40.                      (vl-princ-to-string value)
  41.                      " to property \""
  42.                      prop
  43.                      "\" : "
  44.                      (vl-catch-all-error-message err)
  45.                      ) ;_ end of strcat
  46.              ) ;_ end of princ
  47.       ) ;_ end of if
  48.     ) ;_ end of if
  49.   ) ;_ end of defun
已领礼包: 6056个
发表于 2017-5-20 00:10:37 | 显示全部楼层
谢谢分享!
已领礼包: 780个
发表于 2017-6-26 13:32:05 | 显示全部楼层
大师,这个怎么用啊?...
已领礼包: 488个
发表于 2017-6-26 15:25:39 | 显示全部楼层
(vla-put-value def value) 可以直接赋值value呀 !?
不是应该是Variant吗?
已领礼包: 9341个
发表于 2017-6-26 17:43:24 | 显示全部楼层
谢谢分享学习!
已领礼包: 6468个
发表于 2017-7-4 00:07:03 | 显示全部楼层
这个有用。
已领礼包: 8个
发表于 2019-9-23 12:44:00 | 显示全部楼层
这个很好,可以参考
已领礼包: 13个
发表于 2019-9-23 14:38:11 | 显示全部楼层
不错,很好很有用
发表于 2020-2-5 22:49:06 | 显示全部楼层
谢谢,下载,学习,下,
GMT+8, 2026-11-4 03:45 , Processed in 0.447287 second(s), 45 queries , Gzip On.
