查看: 2524|回复: 0
[分享] Filtering Windows messages inside AutoCAD using .NET
发表于 2017-5-21 10:19:37 | 显示全部楼层 |阅读模式
http://through-the-interface.typ ... iltering-windo.html
                        Back when I joined Autodesk in 1995, I worked in European Developer Support with one of the most talented programmers I've met, Markus Kraus. One of Markus' contributions to the R13 ARX SDK (or maybe it was R14?) was a sample called pretranslate, which remained on the SDK up until ObjectARX 2008, under samples/editor/mfcsamps/pretranslate (it was removed from the 2009 SDK when we archived a number of aging samples).
Anyway, with AutoCAD 2009 the API that makes this sample possible has been added to the .NET API, so in homage to Markus' original sample (which I have fond memories of demoing during a number of events around Europe), I decided to translate the original C++ sample to C#.
Here's the C# code:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using System.Windows.Interop;
using System;
namespace PreTranslate
  public class Commands
    // Keys
    const int MK_SHIFT = 4;
    const int MK_CONTROL = 8;
    // Keyboard messages
    const int WM_KEYDOWN = 256;
    const int WM_KEYUP = 257;
    const int WM_CHAR = 258;
    const int WM_SYSKEYDOWN = 260;
    const int WM_SYSKEYUP = 261;
    // Mouse messages
    const int WM_MOUSEMOVE = 512;
    const int WM_LBUTTONDOWN = 513;
    const int WM_LBUTTONUP = 514;
    static long MakeLong(int LoWord, int HiWord)
      return (HiWord << 16) | (LoWord & 0xffff);
    static IntPtr MakeLParam(int LoWord, int HiWord)
      return (IntPtr)MakeLong(LoWord,HiWord);
    static int HiWord(int Number)
      return (Number >> 16) & 0xffff;
    static int LoWord(int Number)
      return Number & 0xffff;
    // State used by the VhmouseHandler to filter on
    // the vertical or the horizontal
    bool vMode;
    bool hMode;
    int ptx;
    int pty;
    // Commands to add/remove message handlers
    [CommandMethod("caps")]
    public void Caps()
      Application.PreTranslateMessage +=
        new PreTranslateMessageEventHandler(CapsHandler);
    [CommandMethod("uncaps")]
    public void UnCaps()
      Application.PreTranslateMessage -=
    [CommandMethod("vhmouse")]
    public void Vhmouse()
        new PreTranslateMessageEventHandler(VhmouseHandler);
    [CommandMethod("unvhmouse")]
    public void UnVhmouse()
    [CommandMethod("watchCC")]
    public void WatchCC()
        new PreTranslateMessageEventHandler(WatchCCHandler);
    [CommandMethod("unwatchCC")]
    public void UnWatchCC()
    [CommandMethod("noX")]
    public void NoX()
        new PreTranslateMessageEventHandler(NoXHandler);
    [CommandMethod("yes")]
    public void YesX()
    // The event handlers themselves...
    // Force alphabetic character entry to uppercase
    void CapsHandler(
      object sender,
      PreTranslateMessageEventArgs e
      // For every lowercase character message,
      // reduce it my 32 (which forces it to
      // uppercase in ASCII)
      if (e.Message.message == WM_CHAR &&
          (e.Message.wParam.ToInt32() >= 97 &&
          e.Message.wParam.ToInt32() <= 122))
        MSG msg = e.Message;
        msg.wParam =
          (IntPtr)(e.Message.wParam.ToInt32() - 32);
        e.Message = msg;
    // Force mouse movement to either horizontal or
    // vertical
    void VhmouseHandler(
      object sender,
      // Only look at mouse messages
      if (e.Message.message == WM_MOUSEMOVE ||
          e.Message.message == WM_LBUTTONDOWN ||
          e.Message.message == WM_LBUTTONUP)
        // If the left mousebutton is pressed and we are
        // filtering horizontal or vertical movement,
        // make the position the one we're storing
        if ((e.Message.message == WM_LBUTTONDOWN ||
            && (vMode ||  hMode))
          msg.lParam = MakeLParam(ptx, pty);
          e.Message = msg;
          return;
        // If the Control key is pressed
        if (e.Message.wParam.ToInt32() == MK_CONTROL)
          // If we're already in "vertical" mode,
          // set the horizontal component of our location
          // to the one we've stored
          // Otherwise we set the internal "x" value
          // (as this is the first time through)
          if (vMode)
            msg.lParam =
              MakeLParam(
                ptx,
                HiWord(e.Message.lParam.ToInt32())
            e.Message = msg;
            pty = HiWord(e.Message.lParam.ToInt32());
          else
            ptx = LoWord(e.Message.lParam.ToInt32());
          vMode = true;
          hMode = false;
        // If the Shift key is pressed
        else if (e.Message.wParam.ToInt32() == MK_SHIFT)
          // If we're already in "horizontal" mode,
          // set the vertical component of our location
          // Otherwise we set the internal "y" value
          if (hMode)
            msg.lParam =
              MakeLParam(
                LoWord(e.Message.lParam.ToInt32()),
                pty
            e.Message = msg;
          else
          hMode = true;
          vMode = false;
        else
          // Something else was pressed,
          // so cancel our filtering
          vMode = hMode = false;
    // Watch for Ctrl-C, and display a message
    void WatchCCHandler(
      object sender,
      // Check for the Ctrl-C Windows message
          e.Message.wParam.ToInt32() == 3)
        Document doc =
          Application.DocumentManager.MdiActiveDocument;
        doc.Editor.WriteMessage(
          "\nCtrl-C is pressed"
    // Filter out use of the letter x/X
    void NoXHandler(
      object sender,
      // If lowercase or uppercase x is pressed,
      // filter the message by setting the
      // Handled property to true
          (e.Message.wParam.ToInt32() == 120 ||
          e.Message.wParam.ToInt32() == 88))
        e.Handled = true;
To be able to use the System.Windows.Interop namespace, you'll need to add a project reference to WindowsBase.dll. Strangely this can take some finding - at least on my system it wasn't included in the base assembly list. To find it, I browsed to:
C:\Program Files\Reference Assemblies\Microsoft\Framework\v3.0\WindowsBase.dll
The application defines a number of commands, which are described in this text from the original sample's ReadMe:
This sample shows how to pretranslate AutoCAD messages
before they're processed by AutoCAD.
In order to pre-processe AutoCAD messages, a hook function
needs to be installed. The following commands install
different hook functions.
- vhmouse/unvhmouse
  Installs/uninstalls a hook that makes the mouse move only in a
  vertical direction if <CTRL> key is pressed, and only in a
  horizontal direction if the <SHIFT> key is pressed.
- caps/uncaps
  Installs/uninstalls a hook that capitalizes all
  letters typed in the command window.
- noX/yes
  Installs/uninstalls a hook that filters out the
  letters 'x' or 'X'.
- watchCC/unwatchCC
  Installs/uninstalls a hook that watchs
  for <CTRL>+C key combination to be pressed.
Here's what happens when we run the various commands:
Command: caps
Command: UNCAPS
Command: vhmouse
Command: unvhmouse
Command: watchcc
Command:
Ctrl-C is pressed
Command:
Command: _copyclip
Select objects: *Cancel*
Command: nox
Command: yes
While you can't see all the effects of the various commands from this dump of the command-line, here are some comments and pointers, should you try this sample:
  • The Shift or Caps Lock keys was not used at all during entry of the command-names
  • During the vhmouse command, move the mouse around and use the Shift and Ctrl keys to force the movement to horizontal or vertical
    • The Ctrl key now shows an entity selection cursor in AutoCAD, so I should probably have changed to another key for this, but anyway
  • Ctrl-C now launches COPYCLIP, but we see the message first
  • The yes command should obviously be called yesx, but then we can't enter the "x" character after running the nox command. :-)
As a final note: I don't recommend filtering commonly-used keystrokes in your application - your users really won't thank you - but this fun little sample at least shows you the capabilities of the PreTranslate mechanism.
GMT+8, 2026-11-22 07:38 , Processed in 0.400174 second(s), 10 queries , Gzip On, File On.
