查看: 1572|回复: 0
[每日一码] C#中GetObjectSnapPoints函数的用法
已领礼包: 6个
发表于 2017-5-24 08:39:26 | 显示全部楼层 |阅读模式
本程序运用于对象捕捉,运行时,拾取一个圆或圆弧、椭圆,能得到圆心(当然,不用这个方法也能得到)。圆心捕捉也可更改为中点捕捉、象限点捕捉等……
  1. using System;
  2. using Autodesk.AutoCAD.ApplicationServices;
  3. using Autodesk.AutoCAD.Runtime;
  4. using Autodesk.AutoCAD.DatabaseServices;
  5. using Autodesk.AutoCAD.EditorInput;
  6. using Autodesk.AutoCAD.Geometry;
  7. namespace CS对象捕捉
  8. {
  9.     /// <summary>
  10.     /// TestClass的说明。
  11.     /// </summary>
  12.     public class TestClass
  13.     {
  14.         [CommandMethod("Test")]
  15.         public void Test()
  16.         {
  17.             Database db = HostApplicationServices.WorkingDatabase;
  18.             Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
  19.             PromptEntityOptions opt = new PromptEntityOptions("\n请选择圆、圆弧或椭圆");
  20.             opt.SetRejectMessage("\n您选择的对象不存在圆心,请重新选择!");
  21.             opt.AddAllowedClass(typeof(Circle), true);
  22.             opt.AddAllowedClass(typeof(Arc), true);
  23.             opt.AddAllowedClass(typeof(Ellipse), true);
  24.             PromptEntityResult res = ed.GetEntity(opt);
  25.             if (res.Status == PromptStatus.OK)
  26.             {
  27.                 using (Transaction trans = db.TransactionManager.StartTransaction())
  28.                 {
  29.                     Entity ent = (Entity)trans.GetObject(res.ObjectId, OpenMode.ForRead);
  30.                     Point3d pickPt = res.PickedPoint;
  31.                     Point3dCollection snapPts = new Point3dCollection();
  32.                     IntegerCollection geomIds = new IntegerCollection();
  33.                     geomIds.Add(0);
  34.                     ent.GetObjectSnapPoints(ObjectSnapModes.ModeCenter, 0, pickPt,
  35.                         pickPt, Matrix3d.Identity, snapPts, geomIds);
  36.                     ed.WriteMessage("\n您点取的点是:" + pickPt.ToString());
  37.                     for (int i = 0; i < snapPts.Count; i++)
  38.                     {
  39.                         ed.WriteMessage("\n您捕捉到的点是:" + snapPts.ToString());
  40.                     }
  41.                     trans.Commit();
  42.                 }
  43.             }
  44.         }
  45.     }
  46. }
GMT+8, 2026-11-3 10:18 , Processed in 0.369341 second(s), 28 queries , Gzip On.
