查看: 1012|回复: 3
[求助] 有好多文字 要求按照文字的X,Y坐标按照从右往左 从下往上的排序!谢谢
发表于 2017-5-25 08:46:19 | 显示全部楼层 |阅读模式
已领礼包: 20个
发表于 2017-5-25 09:08:32 | 显示全部楼层
搜索  xd::pickset:tablesort
 楼主| 发表于 2017-5-25 10:00:59 | 显示全部楼层
选择集排序(按坐标)
 楼主| 发表于 2017-5-25 10:11:07 | 显示全部楼层
希望提供类似代码
以下代码无法运行
(Defun c:bh (/ ss sscnt slist sname blkattlist blkattval newval)
(setvar "cmdecho" 0)
(command ".undo" "BE")
(setq ss (ssget '((0 . "TXT"))))
(setq sscnt (sslength ss) nno 0)
(setq pd1 (cdr (assoc 10 (entget (ssname ss 0)))))
(setq pd2 (cdr (assoc 10 (entget (ssname ss 1)))))
(setq ang_pd (angle pd1 pd2))
(cond ((= ang_pd (* pi 0.5)) (sort_nam_X_mi_ma))
((= ang_pd (* pi 1.5)) (sort_nam_X_mi_ma))
((or (/= ang_pd (* pi 0.5)) (/= ang_pd (* pi 1.5))) (sort_nam_Y_mi_ma))
(setq blkattlist (subst (cons 1 newval) (assoc 1 blkattlist) blkattlist))
(entmod blkattlist)
(entupd sname)
);progn
);if
(setq nno (1+ nno))
);while
(command ".undo" "E")
(setvar "cmdecho" 1)
(princ)
;;;;;;;;;根据X坐标从小到大将所选图元排序;;;;;;;;
(defun sort_nam_x_mi_ma ()
(setq n (sslength ss))
(setq list_ent nil)
(setq m 0)
(while (< m n)
(setq list_ent (append list_ent (list (ssname ss m))))
(setq m (1+ m))
(setq l 0)
(setq m 1)
(while (< l n)
(setq b (nth l list_ent))
(while (< m n)
(setq c (nth m list_ent))
(if (< (nth 1 (assoc 10 (entget c))) (nth 1 (assoc 10 (entget b))))
(progn
(setq list_ent (subst 'aa (nth l list_ent) list_ent))
(setq list_ent (subst 'bb (nth m list_ent) list_ent))
(setq list_ent (subst c 'aa list_ent))
(setq list_ent (subst b 'bb list_ent))
(setq b c)
(setq m (1+ m))
(setq l (1+ l))
(setq m (1+ l))
);end defun
;;;;;;;;;根据Y坐标从小到大将所选图元排序;;;;;;;;
(defun sort_nam_Y_mi_ma ()
(setq list_ent nil)
(setq m 0)
(while (< m n)
(setq m (1+ m))
(setq l 0)
(setq m 1)
(while (< l n)
(setq b (entget (nth l list_ent)))
(while (< m n)
(setq c (entget (nth m list_ent)))
(if (< (nth 2 (assoc '10 c)) (nth 2 (assoc '10 b)))
(progn
(setq b c)
(setq m (1+ m))
(setq l (1+ l))
(setq m (1+ l))
);end defun
GMT+8, 2026-11-6 00:15 , Processed in 0.429277 second(s), 35 queries , Gzip On.
