查看: 1048|回复: 1
[求助] 拾取多段线,如何得到拾取位置的前一个顶点和后一个顶点?
已领礼包: 10个
发表于 2017-5-27 12:46:56 | 显示全部楼层 |阅读模式
已领礼包: 20个
发表于 2017-5-27 12:56:22 | 显示全部楼层
LWPOLYLINE的顶点参数值是段的整数值,比如 0,1,2,3......
所以从拾取点先得到前一个点和后一个顶点的参数值,然后用 vlax-curve-getpointatparam就求得两个顶点了。
  1. (defun c:tt (/ s e a)
  2.   (if (and (setq s (entsel "\n 选取 LWPolyline :"))
  3.            (eq (cdr (assoc 0 (entget (setq e (car s))))) "LWPOLYLINE")
  4.       )
  5.     (mapcar '(lambda (p) (vlax-curve-getpointatparam e p))
  6.             (list (setq        a (fix (vlax-curve-getparamatpoint
  7.                                  e
  8.                                  (vlax-curve-getclosestpointto e (cadr s))
  9.                                )
  10.                           )
  11.                   )
  12.                   (1+ a)
  13.             )
  14.     )
  15.   )
  16. )
GMT+8, 2026-11-6 00:13 , Processed in 0.584858 second(s), 35 queries , Gzip On.
