查看: 1888|回复: 0
[每日一码] Entmake MPolygon实体
已领礼包: 20个
发表于 2017-5-27 16:45:58 | 显示全部楼层 |阅读模式
MPolygon是AUTOCAD MAP里面的实体,如果加载 acmpolygonobjXXX.arx , XXX是ACAD的大版本号。 是可以通过ENTMAKE函数生成MPOLYGON实体的。
  1. (defun c:makeMPolygon (/ filename)
  2.   (setq filename (strcat "acmpolygonobj" (substr (getvar "ACADVER") 1 2) ".dbx"))
  3.   (or (member filename (arx))
  4.       (arxload filename)
  5.   )
  6.   (entmake '((0 . "MPOLYGON")
  7.              (100 . "AcDbEntity")
  8.              (100 . "AcDbMPolygon")
  9.              (70 . 1)
  10.              (10 0.0 0.0 0.0)
  11.              (210 0.0 0.0 1.0)
  12.              (2 . "ANSI31")
  13.              (71 . 0)
  14.              (91 . 2)
  15.              (92 . 2)
  16.              (73 . 0)
  17.              (72 . 0)
  18.              (93 . 5)
  19.              (10 62.6859 18.6225 0.0)
  20.              (10 120.0 60.2636 0.0)
  21.              (10 177.314 18.6225 0.0)
  22.              (10 155.422 -48.7543 0.0)
  23.              (10 84.5779 -48.7543 0.0)
  24.              (92 . 2)
  25.              (73 . 0)
  26.              (72 . 0)
  27.              (93 . 4)
  28.              (10 20.0 100.0 0.0)
  29.              (10 20.0 -100.0 0.0)
  30.              (10 220.0 -100.0 0.0)
  31.              (10 220.0 100.0 0.0)
  32.              (76 . 1)
  33.              (52 . 0.0)
  34.              (41 . 2.0)
  35.              (77 . 0)
  36.              (78 . 1)
  37.              (53 . 0.785398)
  38.              (43 . 0.0)
  39.              (44 . 0.0)
  40.              (45 . -4.49013)
  41.              (46 . 4.49013)
  42.              (79 . 0)
  43.              (11 0.0 0.0 0.0)
  44.              (99 . 0)
  45.              (450 . 0)
  46.              (451 . 0)
  47.              (460 . 0.0)
  48.              (461 . 0.0)
  49.              (452 . 0)
  50.              (462 . 0.0)
  51.              (453 . 0)
  52.              (470 . "")
  53.             )
  54.   )
  55.   (princ)
  56. )
GMT+8, 2026-11-6 02:40 , Processed in 0.429273 second(s), 32 queries , Gzip On.
