- UID
- 1
- 积分
- 16123
- 精华
- 贡献
- 威望
- 活跃度
- D豆
- 在线时间
- 小时
- 注册时间
- 2002-1-3
- 最后登录
- 1970-1-1
ObjectARX Technical Newsletter - June 2000
This document is part of ObjectARX Newsletter Archive
ObjectARX Technical Newsletter - June 21st 2000
/Note: Have you missed a Newsletter issue? Visit our Newsletter archive at
the following URL:/
http://adn.autodesk.com/techsupp/techsupp/docs/newsletters.htm
Dear ObjectARX developer,
Note: Welcome to the June 2000 edition of the ObjectARX Technical
Newsletter. First let us apologize to those of you who were expecting
a May 2000 edition of the ObjectARX Technical Newsletter. We did
not post an ObjectARX newsletter for May 2000. This was due to the
implementation and roll out of the brand new and redesigned ADN
Technical web site. Please take a visit and inspect the new ADN
web site for yourself. We hope you like it.
http://www.autodesk.com/adn
Table of contents:
1- How to veto application QUIT and/or document close in ObjectARX 2000
2- Starting an OEM 2000 product through automation.
3- Preventing toolbar customization in OEM 2000 products.
4- Announcing ADN e-Learning Courses on Autodesk e-Learning Website!
QUESTION:
How can I intercept and veto the QUIT and CLOSE commands in AutoCAD 2000?
In AutoCAD R14, redefining the QUIT and CLOSE commands works in all cases.
However, in AutoCAD 2000 it works if the commands are typed, but they do
not work from the menu (File -> Exit) or if the application is
"terminated" using the "X" window button. How can I intercept and veto
QUIT and CLOSE in these cases? In R14, redefining QUIT command works
in all cases. However, in R2000 it works OK if the command is typed,
but it doesn't work from the menu (File->Exit) or if the application is
"terminated" using "X" window button. How can I intercept and possibly
veto QUIT in these cases? Also, the same problem exists when redefining
document CLOSE command. How can I intercept and possibly veto CLOSE in
all cases?
ANSWER:
It is true that due to the MDI implementation in R2000, only typed QUIT
and CLOSE can be redefined. There are solutions for other cases and some
are not straightforward. To systematically cover all the cases, let's first
summarize how the AutoCAD application (app) can be QUIT-ed, and how a
document (doc) can be CLOSE-ed:
APP1. typed QUIT command
APP2. AutoCAD menu File->Exit
APP3. "X" button on the app frame
APP4. Window menu -> Close (or Alt+F4) - if you click on the window icon
in top left corner, or right-click app taskbar icon or window frame.
DOC1. typed CLOSE command
DOC2. AutoCAD menu File->Close
DOC3. "X" button on the doc window frame
DOC4. Window menu -> Close (or Ctrl+F4) - if you click on the doc window
icon in top left corner
If you only want to do some clean-up operations, the simplest solution
covering all the above cases is to use AcEditorReactor::beginQuit() for
APP1-4 and AcEditorReactor::beginClose(AcDbDatabase* pDwg) for DOC1-4.
If you want to veto the application QUIT process, the following will
work for ALL cases APP1-4. You do not have to redefine QUIT command at
all, just add the following editor reactor as shown in the following
code fragment:
<code_begin>
// AsdkTheEditorRctr derived from AcEditorReactor
void AsdkTheEditorRctr::beginQuit()
veto();
<code_end>
Unfortunately, you CANNOT veto document CLOSE in the same manner in
beginClose() - it would return and error status of eNotApplicable.
Also you cannot veto CLOSE in
AcApDocManagerReactor::documentToBeDestroyed(AcApDocument* pDoc) reactor.
Additionally you CANNOT veto CLOSE by sending a CANCEL command in
AcEditorReactor::commandWillStart(). Therefore for the CLOSE operation,
we need to resolve each case DOC1-4. The following is a summary and code
details are in the attached project.
DOC1: Use standard UNDEFINE command to undefine CLOSE. In ARX, you would
typically do this in the InitApplication() function, use ads_queueexpr().
DOC2: UNDEFINE will not work here, so you need standard Acad message
filter (see acedRegisterFilterWinMsg()). Monitor for WM_COMMAND with
ID_FILE_CLOSE.
DOC3: Neither UNDEFINE nor acedRegisterFilterWinMsg() work here. You
need to trap WM_SYSCOMMAND (not passed to acedRegisterFilterWinMsg())
with SC_CLOSE. You must use standard Windows hook of WH_CBT type
(::SetWindowsHookEx(WH_CBT,...).
DOC4: same as DOC3.
The following URL is for Developer Note 56977 on the ADN WEB site is
the project that demonstrates implementation details. The application
defines the SETVETO command to toggle app QUIT and/or doc CLOSE
vetoing. There are a number of message boxes displayed to clarify
the execution flow. There are also indications where APP2-4 cases
can be alternatively covered, since redefining QUIT would cover
only APP1. In the CBTHook() callback function for windows hook,
there are number of calculations to verify if the SC_CLOSE is for
application or document. Note that different sub-cases of
APP4 and DOC4 yield different messages but some may still be
impossible to distinguish (e.g. Alt+F4). DOC3 case also produces
completely different message if the window is zoomed (maximized)
when no mouse coordinates are passed in. All this is redundant
if you are not interested in what is being SC_CLOSE-ed
(see the code comments).
/cgi-bin/solution.pl?SID=56977
AutoCAD OEM does not expose an Application object, so you cannot
access it from another application. What you need to do is access
your ARX module directly. Here's what you need to do:
First, you need to setup the registry so the CLSID of the top level
object in your ARX application is registered as LocalServer implemented
by your product's EXE.
You need to make the ARX application load on startup. The best way to do
this is to make your ARX application a required module.
Lastly, in the kInitAppMsg for the ARX application, register the class
factory of your top level object with CoRegisterClassObject() and add
an instance of your top level object as the active object with
RegisterActiveObject().
As your ARX application is no longer a local server, you will not need
DllRegisterServer(), DllCanUnloadNow() etc.
Take a look at the PolySamp sample application to see how this is done,
or you follow the link below to see just the relevant code.
/cgi-bin/solution.pl?SID=54842
If you've disabled menu customization in your OEM 2000 product, the
toolbars can still be modified if you right-click on them and choose
"Customize" from the context menu. This works fine only for this
editing session, but when the product is closed and restarted it will
only display the default menu, which will have none of your commands
you added with the "Customize" dialog for the previous session.
The reason for this is because modifying the toolbars rewrites the MNS
file, making the MNS file newer than the MNC file. This tells AutoCAD
and OEM that the MNC file needs to be recompiled, but since menu
customization is turned off there is no way for the product to recompile
the menu, so it resorts to it's default menu.
If this happens, you can get the full menu back by altering the dates on
either the MNC or MNS file. It doesn't matter which one you change as
long as the MNC file more recent than the MNS file. Of course, the custom
toolbars will be lost, but the full menu will return.
There really isn't any way to fully disable toolbar customization with
the OEM APIs because the right-click menu is hard-coded into the engine
and cannot be changed. Since you can't change the actual engine code,
one way around this is to use the Win32 API to intercept the
WM_RBUTTONUP and WM_RBUTTONDOWN messages. If they are being sent to a
toolbar (a window who's class is ToolbarWindow32), then you will just
return without passing that message along. By filtering in this manner,
right-clicking will have no effect over toolbars but will still work
in the drawing area or the text window.
4. Announcing ADN e-Learning Courses on Autodesk e-Learning Website!
ADN e-Learning courses are now available on the Autodesk e-Learning
Website at the following URL:
http://www.autodesk.com/e-learning
The main features of the website include (see the related Press Release)
http://www3.autodesk.com/adsk/item/0,,282165,00.html
Bringing together online courses, e-courseware, and virtual classroom
training in a one-stop website*
Providing access to the courses to all of our Autodesk partners and users
(including non-ADN members)
Some free preview courses to get you started.
More than 2,600 courses on operating systems, database, network
administration, programming, strategic planning, communications,
management, and more besides courses on Autodesk products.
We now have e-Learning modules with HTML and streaming audio for
2 ObjectARX2000 labs, 2 Visual LISP lessons and an introductory module
for Actrix Technical API on the Autodesk e-Learning website.
We will continue to roll out more and more ADN courses on this website,
in the coming weeks.
*Presently, ADN material is only provided as online training material
Actions:
Please test drive free courses for your team
http://www.headlight.com/promo/sign_others_up/1,1346,ad-,00.html
Please test drive free courses for yourself
http://www.headlight.com/promo/b ... ,1606,ad-74,00.html
Please familiarize yourself with the customization area of the web site
http://www.headlight.com/browse_channels/0,1036,ad-675,00.html
Consider participating in the relevant chat session
http://adn.autodesk.com/techsupp/training/ecschedule.htm
We welcome your feedback on the material and what material and chat sessions
you need most in the future.
Please e-mail <adn-training-worldwide@autodesk.com> with your input.
Please watch this space for future material, chat schedules and more
information on the ADN e-Learning program.
To subscribe or unsubscribe, go to
You received this message as a result of your registration
on the ADN List Server subscription page. If you no longer wish
to receive these messages, read the next section, How to use this
mailing list.
How to use this mailing list:
You may unsubscribe from this e-mail newsletter, or subscribe to
a variety of other informative e-mail newsletters, by returning
to the ADN List Server subscription page at
and changing your subscription preferences.
Alternatively, from the subscribed account you can send an e-mail to
<Majordomo-partnersys@autodesk.com> with the following command in the
body of your email message:
unsubscribe <list-name>
Autodesk Developer Network (ADN) information and events:
For information on all ADN topics, please visit:
THIS DOCUMENT IS PROVIDED FOR INFORMATIONAL PURPOSES ONLY. The
information contained in this document represents the current view of
Autodesk Inc. on the issues discussed as of the date of publication.
Because Autodesk must respond to change in market conditions, it
should not be interpreted to be a commitment on the part of Autodesk
and Autodesk cannot guarantee the accuracy of any information
presented after the date of publication.
INFORMATION PROVIDED IN THIS DOCUMENT IS PROVIDED 'AS IS' WITHOUT
WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING BUT NOT
LIMITED TO THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
PARTICULAR PURPOSE AND FREEDOM FROM INFRINGEMENT.
The user assumes the entire risk as to the accuracy and the use of
this document. This document may be copied and distributed subject to
the following conditions:
1. All text must be copied without modification and all pages must
be included
2. All copies must contain Autodesk's copyright notice and any other
notices provided therein
3. This document may not be distributed for profit
