查看: 1540|回复: 2
[研讨] 删除wipeout源码
已领礼包: 217个
发表于 2017-6-16 13:34:34 | 显示全部楼层 |阅读模式
我写了一个简单低配版的,如下:(写着当练习了,怕长时间不写忘记怎么写了)
游客,如果您要查看本帖隐藏内容请回复
之前收藏了一个他人写的,我试用了一下,检查时报错了
参数太少: (WCMATCH (vla-get-Name ITEM "*|*"))
看起来很牛但是没法用,本人才疏学浅看不懂prelayer函数是什么原理,如何修改,请有兴趣的大师试一试,改一改,最好能加点注释让小弟学习一下。
叩谢
(vl-load-com)(defun_prelayers (adoc / item layers prop tmp)
  (vlax-for item (vla-get-layers adoc)
    (if (not (wcmatch (vla-get-name item"*|*")))
      (setq layers (cons (append (list item)
                                 (mapcar(function (lambda (prop / tmp)
                                                    (setq tmp (vlax-get-property item prop))
                                                    (vl-catch-all-apply (function (lambda () (vlax-put-property item prop:vlax-false))))
                                                    (cons prop tmp)
                                                    ) ;_ end of lambda
                                                  ) ;_ end of function
                                        '("freeze" "lock")
                                         ) ;_end of mapcar
                                 ) ;_ end ofappend
                         layers
                         ) ;_ end of cons
            ) ;_ end of setq
      ) ;_ end of if
    ) ;_ end of vlax-for
(defunc:remove-wipeout (/ adoc layers count err)
  (vla-startundomark (setq adoc(vla-get-activedocument (vlax-get-acad-object))))
  (setq layers (_prelayers adoc))
  (setq count 0
        err 0
        ) ;_ end of setq
  (vlax-for blk_def (vla-get-blocks adoc)
    (if (equal (vla-get-isxref blk_def):vlax-false)
      (vlax-for ent blk_def
        (if (wcmatch (strcase(vla-get-objectname ent)) "*WIPEOUT*")
          (if (vl-catch-all-error-p(vl-catch-all-apply (function (lambda () (vla-erase ent)))))
            (setq err (1+ err))
            (setq count (1+ count))
            ) ;_ end of if
          ) ;_ end of if
      ) ;_ end of if
  (foreach item layers
    (foreach prop (cdr item)
      (vl-catch-all-apply (function (lambda ()(vlax-put-property (car item) (car prop) (cdr prop)))))
      ) ;_ end of foreach
    ) ;_ end of foreach
  (princ (strcat "\nErased wipeout :" (itoa count) "\nError erasing : " (itoa err)))
  (vla-endundomark adoc)
  (princ)
) ;_ end of defun
已领礼包: 2476个
发表于 2017-6-16 13:40:05 | 显示全部楼层
搜WIPEOUT就行..
已领礼包: 2025个
发表于 2024-5-29 12:17:53 | 显示全部楼层
谢谢楼主的分享!
回复来学习一下
GMT+8, 2026-11-3 07:33 , Processed in 0.505107 second(s), 33 queries , Gzip On.
