查看: 1416|回复: 1
[每日一码] 炸开所有的匿名块
发表于 2017-6-18 23:46:07 | 显示全部楼层 |阅读模式
  1. (defun c:ExplAnon ( / *error* _StartUndo _EndUndo _UnlockLayers _RelockLayers _i**plodable _GetBlockName acblk acdoc locked name ss )
  2.   (defun *error* ( msg )
  3.     (if locked (_RelockLayers locked))
  4.     (if acdoc  (_EndUndo acdoc))
  5.     (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
  6.         (princ (strcat "\n** Error: " msg " **")))
  7.     (princ)
  8.   )
  9.   (defun _StartUndo ( doc ) (_EndUndo doc)
  10.     (vla-StartUndoMark doc)
  11.   )
  12.   (defun _EndUndo ( doc )
  13.     (if (= 8 (logand 8 (getvar 'UNDOCTL)))
  14.       (vla-EndUndoMark doc)
  15.     )
  16.   )
  17.   (defun _UnlockLayers ( doc / l )
  18.     (vlax-for layer (vla-get-layers doc)
  19.       (if (eq :vlax-true (vla-get-lock layer))
  20.         (vla-put-lock (car (setq l (cons layer l))) :vlax-false)
  21.       )
  22.     )
  23.     l
  24.   )
  25.   (defun _RelockLayers ( lst )
  26.     (mapcar '(lambda ( l ) (vla-put-lock l :vlax-true)) lst)
  27.   )
  28.   (defun _i**plodable ( blockdef )
  29.     (or
  30.       (not (vlax-property-available-p blockdef 'explodable))
  31.       (eq :vlax-true (vla-get-explodable blockdef))
  32.     )
  33.   )
  34.   (defun _GetBlockName ( obj )
  35.     (if (vlax-property-available-p obj 'effectivename)
  36.       (vla-get-effectivename obj)
  37.       (vla-get-name obj)
  38.     )
  39.   )
  40.   (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object))
  41.         acblk (vla-get-blocks acdoc)
  42.   )
  43.   (if (ssget "_X" '((0 . "INSERT") (2 . "`*U*")))
  44.     (progn
  45.       (_StartUndo acdoc) (setq locked (_UnlockLayers acdoc))
  46.
  47.       (vlax-for obj (setq ss (vla-get-ActiveSelectionSet acdoc))
  48.
  49.         (if (_i**plodable (vla-item acblk (setq name (_GetBlockName obj))))
  50.           (progn
  51.             (vla-explode obj) (vla-delete obj)
  52.           )
  53.           (princ (strcat "\nBlock: " name " is not explodable."))
  54.         )
  55.       )
  56.       (vla-delete ss) (_RelockLayers locked) (_EndUndo acdoc)
  57.     )
  58.   )
  59.   (princ)
  60. )
已领礼包: 780个
发表于 2017-6-19 09:28:17 | 显示全部楼层
这个程序非常实用,谢谢楼主分享!!!
GMT+8, 2026-11-5 15:30 , Processed in 0.451524 second(s), 31 queries , Gzip On.
