查看: 1713|回复: 9
[求助] 怎么给直线、多线等实体添加自定义属性呢?
发表于 2017-6-19 19:19:44 | 显示全部楼层 |阅读模式
在cad中,选中直线、多线等实体后,ctr+1可以查看该实体的特性
能不能自定义特性呢
比如一条直线,想定义如下信息
用途:道路
材质:金属
名称:延安路
客户:某某客户
能实现吗?
发表于 2017-6-19 19:23:20 | 显示全部楼层
用 扩展实体数据 或者 xdata 搜索论坛
 楼主| 发表于 2017-6-19 20:48:30 | 显示全部楼层
(regapp "FREDS")
(entmake ; makes entity
    '((0 . "CIRCLE") ; entity type
    (8 . "0") ; layer name
    (62 . 3) ; color
    (39 . 2.75) ; thickness
    (10 8.0 6.0 0.0) ; center point
    (40 . 2.0) ; radius
    ; create and add xdata
    (-3 ("FREDS" (1002 . "{")
                          (1000 . "This is my data")
                          (1000 . "More Data")
                          (1000 . "and some more data")
                          (1040 . 12.345)
                          (1010 8.97197 6.8436 0.0)
                          (1040 . 2.75013)
                          (1002 . "}")))
(Setq a (entget (entlast) '("FREDS")))
;; gets the assoc list with attached
;; extended entity data that belongs
;; to the regapp "FREDS"
(princ a) ;; prints assoc list to screen
(princ "\n\n") ;; two blank lines
(setq z (assoc -3 a)) ;; save xdata that belongs to the
;; regapp "FREDS" to z variable
(setq a (subst'(-3 ("FREDS")) (assoc -3 a) a)) ;; new assoc list without
;; xdata. The -3 assoc code has only
;; the regapp name without any data.
;; This gets substituted for the assoc
;; -3 list that has data.
(entmod a) ;; modifies entity removing the
;; xdata because feeding a entmod
;; an assoc list with only the regapp
;; name for the -3 assoc code removes
;; the extended entity data from the
;; entity.
;; gets the new assoc list to verify
;; the xdata has been removed
(princ a) ;; prints the new assoc list without
;; the xdata to screen.
如何设置扩展实体数据呢?
上面的代码有获取,那如何设置呢?
论坛上找了个类似的
代码如下:
(setx (entlast) "PRICE"  ((1040.123.45) (1040.321.54)))
(defun setx(entname appname xdata / x0 x1)
(setq appname(strcase appname))
(if (= (type entname) 'ENAME)
(if (tblsearch "APPID" appname)
(if (setq x0 (entget entname))
(progn
(setq x1 (list -3 (append (list appname) xdata)))
(setq x0 (append (entget entname) (list x1)))
(entmod x0)
但提示 函数错误: (1040.321.54),不知道该怎么用啊~~~~~··
发表于 2017-6-19 20:51:03 | 显示全部楼层
从你的错误提示看
((1040.123.45)
这个前面应该加上 '
变成这样:
'((1040.123.45)....
 楼主| 发表于 2017-6-19 20:56:58 | 显示全部楼层
追加了 ’ ,又提示 setx 函数未定义但下面已经定义了啊,为什么呢
先定义才能用  发表于 2017-6-20 07:29
发表于 2017-6-19 21:54:47 | 显示全部楼层
不知道你CAD什么版本呢, 那你就把setx函数提到最前面去。
已领礼包: 1268个
发表于 2017-6-20 00:25:04 | 显示全部楼层
vlax-ldata-put 更简单灵活
 楼主| 发表于 2017-6-20 10:14:18 | 显示全部楼层
有具体的例子吗?不是特别知道
 楼主| 发表于 2017-6-21 10:37:36 | 显示全部楼层
我按vlax-ldata-put试了一下代码如下:
(regapp "project")
(setq e (car (entsel)))
(vlax-ldata-put e "project" '("北京项目"))
然后用
(entget (car (entsel)) '("*"))查看了一下组码
并没有给相应的实体加上扩展的实体数据,什么原因呢?还是使用错了
GMT+8, 2026-11-5 22:39 , Processed in 0.412228 second(s), 46 queries , Gzip On.
