查看: 3104|回复: 20
[求助] 问个过于打印的问题
发表于 2017-7-2 10:19:33 | 显示全部楼层 |阅读模式
我自己修改的帮助文档的打印的例子,编译通过,但是加载执行cad崩溃
static void PlotAPI_plotPreview(void)
                Acad::ErrorStatus es;
                AcAxDocLock lock;
                AcDbPlotSettingsValidator* pPSV=NULL;
                //AcDbPlotSettings *pPlotSettings;
                //AcDbPlotSettings* pPlotSetting = (AcDbPlotSettings*)pLayout;
                BOOL m_bFit=FALSE;
                double m_Scale=0;
                BOOL m_Landscape=FALSE;
                AcDbObjectId layoutId;
                //CComPtr<IAsdkPlotNotifySink> pPlotSink=NULL;
                /*, m_Scale(0)
                , m_Landscape(FALSE)
                , m_CurrentDevice(_T(""))
                , pPSV(NULL)
                , m_bFit(FALSE)
                , m_Background(FALSE)
                , m_bPlotToFile(FALSE)
                , m_csFilename(_T(""))
                ,dwAppCF(0)
                ,dwAppObj(0)
                ,pPlotSink(NULL)*/
                /*CComboBox m_Devices;
                CComboBox m_Media;
                double m_Scale;
                BOOL m_Landscape;
                CString m_CurrentDevice;
                CString m_CurrentMedia;
                AcDbPlotSettingsValidator* pPSV;
                void CalcExtents(void);
                BOOL m_bFit;
                BOOL m_Background;
                BOOL m_bPlotToFile;
                CString m_csFilename;
                DWORD dwAppCF;*/
                //DWORD dwAppObj;
                AcApLayoutManager *pLayMan = NULL;
                pLayMan=(AcApLayoutManager*)acdbHostApplicationServices()->layoutManager();
                //get the active layout
                AcDbLayout *pLayout = pLayMan->findLayoutNamed(pLayMan->findActiveLayout(TRUE),TRUE);
                AcDbPlotSettings* pPlotSettings = (AcDbPlotSettings*)pLayout;
                es=pPSV->setPlotType(pPlotSettings,AcDbPlotSettings::kExtents);
                // Set the Scale...
                if (m_bFit)
                        es = pPSV->setUseStandardScale(pPlotSettings,Adesk::kTrue);
                        es = pPSV->setStdScaleType(pPlotSettings,AcDbPlotSettings::kScaleToFit);
                else // Choose to use this custom scale...
                        es=pPSV->setUseStandardScale(pPlotSettings,Adesk::kFalse);
                        es=pPSV->setCustomPrintScale(pPlotSettings,m_Scale,1);
                es=pPSV->setPlotCentered(pPlotSettings,true);
                acedGetAcadFrame()->ShowWindow(SW_SHOW);
                acedGetAcadFrame()->SetFocus();
                //下面这句注释掉了,编译不过
                /*ShowWindow(SW_HIDE);
                if(pPlotSink)
                        pPlotSink->put_Visible(FALSE);*/
                AcPlPlotEngine* pEngine = NULL;
                if(Acad::eOk==AcPlPlotFactory::createPreviewEngine(pEngine))
                        pEngine->beginPlot(NULL);
                        AcPlPlotPageInfo pageInfo;
                        AcPlPlotInfo plotInfo;
                        plotInfo.setLayout(layoutId);
                        plotInfo.setOverrideSettings(pPlotSettings);
                        AcPlPlotInfoValidator validator;
                        validator.setMediaMatchingPolicy(AcPlPlotInfoValidator::kMatchEnabled);
                        es = validator.validate(plotInfo);
                        const TCHAR *szDocName=acDocManager->curDocument()->fileName();
                        es = pEngine->beginDocument(plotInfo, szDocName);
                        es = pEngine->beginPage(pageInfo, plotInfo, true);
                        es = pEngine->beginGenerateGraphics();
                        es = pEngine->endGenerateGraphics();
                        es = pEngine->endPage();
                        es = pEngine->endDocument();
                        es = pEngine->endPlot();
                        pEngine->destroy();
                        pEngine = NULL;
                else
                        AfxMessageBox(_T("Plot Engine is Busy..."));
                //下面这句注释掉了,编译不过
                /*ShowWindow(SW_SHOW);
                if(pPlotSink)
                pPlotSink->put_Visible(TRUE);*/
        static void PlotAPI_bPlot(void)
                AcAxDocLock lock;
                BOOL m_bFit=FALSE;
                double m_Scale=0;
                // Set the Scale...
                if (m_bFit)
                // Specify that we want our plot centered by AutoCAD...
                // Create a publish engine, and send the plot through...
                if(Acad::eOk==AcPlPlotFactory::createPublishEngine(pEngine))
                        // Here is the progress dialog for the current plot process...
                        AcPlPlotProgressDialog *pPlotProgDlg = acplCreatePlotProgressDialog(acedGetAcadFrame()->m_hWnd,false,1);
                        pPlotProgDlg->setPlotMsgString(AcPlPlotProgressDialog::kDialogTitle,_T("Plot API Progress"));
                        pPlotProgDlg->setPlotMsgString(AcPlPlotProgressDialog::kCancelJobBtnMsg,_T("Cancel Job"));
                        pPlotProgDlg->setPlotMsgString(AcPlPlotProgressDialog::kCancelSheetBtnMsg,_T("Cancel Sheet"));
                        pPlotProgDlg->setPlotMsgString(AcPlPlotProgressDialog::kSheetSetProgressCaption,_T("Job Progress"));
                        pPlotProgDlg->setPlotMsgString(AcPlPlotProgressDialog::kSheetProgressCaption,_T("Sheet Progress"));
                        pPlotProgDlg->setPlotProgressRange(0,100);
                        pPlotProgDlg->onBeginPlot();
                        pPlotProgDlg->setIsVisible(true);
                        es = pEngine->beginPlot(pPlotProgDlg);
                        AcPlPlotInfo plotInfo; // Used to describe how the plot is to be made
                        // First, set the layout to the specified layout (which is the current layout in this sample)
                        plotInfo.setLayout(layoutId);// This is required.
                        // Now, override the layout settings with the plot settings we have been populating
                        // We need to validate these settings.
                        // Begin document.  The version we call is dependent on the plot-to-file status.
                        /*if(m_bPlotToFile)
                        es = pEngine->beginDocument(plotInfo, szDocName, NULL, 1, true, m_csFilename);
                        else*/
                        // Follow through sending commands to the engine, and notifications to the progress dialog.
                        pPlotProgDlg->onBeginSheet();
                        pPlotProgDlg->setSheetProgressRange(0, 100);
                        pPlotProgDlg->setSheetProgressPos(0);
                        pPlotProgDlg->setSheetProgressPos(100);
                        pPlotProgDlg->onEndSheet();
                        pPlotProgDlg->setPlotProgressPos(100);
                        // Destroy the engine
                        pEngine->destroy();
                        pEngine = NULL;
                        // and the progress dialog.
                        pPlotProgDlg->destroy();
                else
                        // Ensure the engine is not already busy...
发表于 2017-7-2 10:27:14 | 显示全部楼层
调试下,或者加些打印语句, 看看执行到哪行代码,出现崩溃。另外,说明下ARX什么版本,CAD什么版本。
 楼主| 发表于 2017-7-2 11:00:42 | 显示全部楼层
f附加进程调试,cad2014,像死机了一样,这调试怎么这么恶心
发表于 2017-7-2 12:29:01 | 显示全部楼层
那你就在不同的地方加上打印语句,看看执行到哪里了吧。
 楼主| 发表于 2017-7-2 21:38:01 | 显示全部楼层
vs2002的帮助文档的例子,我编译了一下,编译成功,但是加载就出问题
发表于 2017-7-2 21:45:22 | 显示全部楼层
那你看看2014帮助文档是否也有这个例子,编译2014文档的,也可能函数用法变了。
 楼主| 发表于 2017-7-2 22:13:03 | 显示全部楼层
我后来就用vs2002的编译器直接编译2002的例子,没升级成2014,搞不懂为什么arx2006自己的例子编译完还出错,想把代码传上来不知怎么传
 楼主| 发表于 2017-7-2 22:15:12 | 显示全部楼层
还有很多zhez这种这种情况,2005以上版本编译完加载都没问题,改成2002版本就不知道出什么问题
已领礼包: 20个
发表于 2017-7-2 22:26:44 | 显示全部楼层
不太长的代码,直接粘贴到论坛,选中代码后,点 代码 按钮,选C++
大的工程,可以压缩到RAR,传上来,超过几个M,可以多卷压缩。
 楼主| 发表于 2017-7-2 22:28:07 | 显示全部楼层
http://gjj123321.ys168.com/,我放到这里了,看能不能下载
 楼主| 发表于 2017-7-2 22:34:28 | 显示全部楼层
  1. AcApLayoutManager *pLayMan = NULL;
  2.                 pLayMan=(AcApLayoutManager*)acdbHostApplicationServices()->layoutManager();
  3.                 //get the active layout
  4.                 AcDbLayout *pLayout = pLayMan->findLayoutNamed(pLayMan->findActiveLayout(TRUE),TRUE);
  5.                 AcDbPlotSettings* pPlotSetting = (AcDbPlotSettings*)pLayout;
  6.                 char* mediaName;
  7.                 pPlotSetting->getCanonicalMediaName(mediaName);
  8.                 acutPrintf(_T("\nMedia Name:%s"), mediaName);
  9.
  10.                 pPlotSetting->close();
  11.                 pLayout->close();
这段代码在2005以上都没问题,,改成2002编译成功,加载崩溃,大师帮忙看下啥问题
已领礼包: 7740个
发表于 2017-7-3 00:11:38 | 显示全部楼层
谢谢提问,又有机会学习学习了
已领礼包: 3904个
发表于 2017-7-3 07:56:25 | 显示全部楼层
看看执行到哪行代码
已领礼包: 5060个
发表于 2017-7-3 08:05:07 来自手机 | 显示全部楼层
不会调试的coder是不及格的程序员
 楼主| 发表于 2017-7-3 11:11:01 | 显示全部楼层
&nbsp;pPlotSetting->getCanonicalMediaName(mediaName);这句就完蛋了,各位大神,看看你们的vs2002编译这段代码有问题没,会不会是我的编译器安装的出问题了
GMT+8, 2026-11-2 23:12 , Processed in 0.557638 second(s), 59 queries , Gzip On.
