查看: 1606|回复: 2
[求助] 用Arx在下列类中怎样定义一个带有形参的Lisp函数
发表于 2017-7-2 15:14:48 | 显示全部楼层 |阅读模式
例如要i把 int sp3 (struct resbuf *rb) 定义成autolisp函数。
//----- ObjectARX EntryPoint
class CwcadApp : public AcRxArxApp {
public:
        CwcadApp() : AcRxArxApp() {}
        virtual AcRx::AppRetCode On_kInitAppMsg(void *pkt) {
                // TODO: Load dependencies here
                // You *must* call On_kInitAppMsg here
                AcRx::AppRetCode retCode = AcRxArxApp::On_kInitAppMsg(pkt);
                // TODO: Add your initialization code here
                return (retCode);
        virtual AcRx::AppRetCode On_kUnloadAppMsg(void *pkt) {
                // TODO: Add your code here
                // You *must* call On_kUnloadAppMsg here
                AcRx::AppRetCode retCode = AcRxArxApp::On_kUnloadAppMsg(pkt);
                // TODO: Unload dependencies here
                return (retCode);
        virtual void RegisterServerComponents() {
        // Modal Command with localized name
        // ACED_ARXCOMMAND_ENTRY_AUTO(CwcadApp, gsMyGroup, MyCommand, MyCommandLocal, ACRX_CMD_MODAL)
        static void gsMyGroupMyCommand() {
                // Put your command code here
        // Modal Command with pickfirst selection
        // ACED_ARXCOMMAND_ENTRY_AUTO(CwcadApp, gsMyGroup, MyPickFirst, MyPickFirstLocal, ACRX_CMD_MODAL | ACRX_CMD_USEPICKSET)
        static void gsMyGroupMyPickFirst() {
                ads_name result;
                int iRet = acedSSGet(ACRX_T("_I"), NULL, NULL, NULL, result);
                if (iRet == RTNORM)
                        // There are selected entities
                        // Put your command using pickfirst set code here
                else
                        // There are no selected entities
        // Application Session Command with localized name
        // ACED_ARXCOMMAND_ENTRY_AUTO(CwcadApp, gsMyGroup, MySessionCmd, MySessionCmdLocal, ACRX_CMD_MODAL | ACRX_CMD_SESSION)
        static void gsMyGroupMySessionCmd() {
        // ACED_ADSFUNCTION_ENTRY_AUTO(CwcadApp, MyLispFunction, false)
        static int ads_MyLispFunction() {
                //struct resbuf *args =acedGetArgs () ;
                //acutRelRb (args) ;
                // Return a value to the AutoCAD Lisp Interpreter
                // acedRetNil, acedRetT, acedRetVoid, acedRetInt, acedRetReal, acedRetStr, acedRetPoint, acedRetName, acedRetList, acedRetVal
                return (RTNORM);
        static void gsMyGroupProjPathCfg(void) {//项目及程序路径
                CProjectPath dlg;
                dlg.DoModal();
IMPLEMENT_ARX_ENTRYPOINT(CwcadApp)
ACED_ARXCOMMAND_ENTRY_AUTO(CwcadApp, gsMyGroup, MyCommand, MyCommandLocal, ACRX_CMD_MODAL, NULL)
ACED_ARXCOMMAND_ENTRY_AUTO(CwcadApp, gsMyGroup, MyPickFirst, MyPickFirstLocal, ACRX_CMD_MODAL | ACRX_CMD_USEPICKSET, NULL)
ACED_ARXCOMMAND_ENTRY_AUTO(CwcadApp, gsMyGroup, MySessionCmd, MySessionCmdLocal, ACRX_CMD_MODAL | ACRX_CMD_SESSION, NULL)
ACED_ADSSYMBOL_ENTRY_AUTO(CwcadApp, MyLispFunction, false)
ACED_ARXCOMMAND_ENTRY_AUTO(CwcadApp, gsMyGroup, ProjPathCfg, PrjPath, ACRX_CMD_MODAL, NULL) //项目及及程序路径
 楼主| 发表于 2017-7-2 16:14:43 | 显示全部楼层
问题已解决
发表于 2025-9-10 22:10:21 | 显示全部楼层
怎么解决的,还不会。
GMT+8, 2026-11-22 07:42 , Processed in 0.234058 second(s), 12 queries , Gzip On, File On.
