查看: 1242|回复: 3
[研讨] 这是fools前辈的程序,但是在捕捉圆心的时候会出错,那位大神帮忙看看优化一下
已领礼包: 496个
发表于 2017-7-12 08:24:58 | 显示全部楼层 |阅读模式
这是fools前辈的程序,但是在捕捉圆心的时候会出错,那位大神帮忙看看,优化一下谢谢!
http://bbs.xdcad.net/forum.php?m ... &fromuid=764086
  1. ;;  grread+osnap+grvecs
  2. ;;  Rewritten by Fools @ TheSwamp.org
  3. ;;
  4. ;;  Use (grread) to get original point
  5. ;;  Use (osnap) to calculate accurate point
  6. ;;  Use (grvecs) to show AutosnapMarker
  7. ;;  No return , just show the method
  8. (defun c:gg(/ autosnapmarkercolor autosnapmarkersize bold distperpixel draftobj drag get_osmode ghostpt lst_osmode str_osmode time ypy_drawvecs ypy_getgrvecs ypy_strparse)
  9.   ;;  CAB  10/5/2006
  10.   ;;  Fools change a little about ","  (3/3/2007)
  11.   ;;
  12.   ;;  function to return the current osmode setting in the form of a string
  13.   ;;  if (getvar "osmode") = 175
  14.   ;;  (get_osmode)  returns   "_end,_mid,_cen,_nod,_int,_per"
  15.   (defun get_osmode (/ cur_mode mode$)
  16.     (setq mode$ "")
  17.     (if (< 0 (setq cur_mode (getvar "osmode")) 16383)
  18.       (mapcar
  19.                                 (function
  20.                                         (lambda (x)
  21.                                                 (if (not (zerop (logand cur_mode (car x))))
  22.                                                         (if (zerop (strlen mode$))
  23.        (setq mode$ (cadr x))
  24.        (setq mode$ (strcat mode$ "," (cadr x)))
  25.                                                         )
  26.                                                 )
  27.                                         )
  28.                                 )
  29.                                 '((1 "_end") (2 "_mid") (4 "_cen") (8 "_nod") (16 "_qua") (32 "_int") (64 "_ins") (128 "_per") (256 "_tan") (512 "_nea") (1024 "_qui") (2048 "_app") (4096 "_ext") (8192 "_par"))
  30.       )
  31.     )
  32.     mode$
  33.   )
  34.   ;;My functions
  35.   (defun ypy_strparse (str delim / ptr lst)
  36.     (while (setq ptr (vl-string-search delim str))
  37.       (setq lst (cons (substr str 1 ptr) lst))
  38.       (setq str (substr str (+ ptr 2)))
  39.                 )
  40.                 (reverse (cons str lst))
  41.         )
  42.   (defun ypy_getgrvecs (pt dragpt lst / KEY)
  43.     (setq key T)
  44.     (while (and key lst)
  45.       (if (EQUAL (osnap dragpt (car lst)) pt 1E-6)
  46.         (setq key nil)
  47.         (setq lst (cdr lst))
  48.       )
  49.     )
  50.     (cdr (assoc        (car lst)
  51.                                          '(("_end"
  52.                                                          ((-1 1) (-1 -1))
  53.                                                          ((-1 -1) (1 -1))
  54.                                                          ((1 -1) (1 1))
  55.                                                          ((1 1) (-1 1))
  56.                                                  )                        ;square
  57.                                                         ("_mid"
  58.        ((0 1.414) (-1.225 -0.707))
  59.        ((-1.225 -0.707) (1.225 -0.707))
  60.        ((1.225 -0.707) (0 1.414))
  61.                                                         )                        ;triangle
  62.                                                         ("_cen"
  63.        ((0 1) (-0.707 0.707))
  64.        ((-0.707 0.707) (-1 0))
  65.        ((-1 0) (-0.707 -0.707))
  66.        ((-0.707 -0.707) (0 -1))
  67.        ((0 -1) (0.707 -0.707))
  68.        ((0.707 -0.707) (1 0))
  69.        ((1 0) (0.707 0.707))
  70.        ((0.707 0.707) (0 1))
  71.                                                         )                        ;circle
  72.                                                         ("_nod"
  73.        ((0 1) (-0.707 0.707))
  74.        ((-0.707 0.707) (-1 0))
  75.        ((-1 0) (-0.707 -0.707))
  76.        ((-0.707 -0.707) (0 -1))
  77.        ((0 -1) (0.707 -0.707))
  78.        ((0.707 -0.707) (1 0))
  79.        ((1 0) (0.707 0.707))
  80.        ((0.707 0.707) (0 1))
  81.        ((-1 1) (1 -1))
  82.        ((-1 -1) (1 1))
  83.                                                         )                        ;circle+cross
  84.                                                         ("_qua"
  85.        ((0 1.414) (-1.414 0))
  86.        ((-1.414 0) (0 -1.414))
  87.        ((0 -1.414) (1.414 0))
  88.        ((1.414 0) (0 1.414))
  89.                                                         )                        ;square rotate 45
  90.                                                         ("_int"
  91.        ((-1 1) (1 -1))
  92.        ((-1 -1) (1 1))
  93.        ((1 0.859) (-0.859 -1))
  94.        ((-1 0.859) (0.859 -1))
  95.        ((0.859 1) (-1 -0.859))
  96.        ((-0.859 1) (1 -0.859))
  97.                                                         )                        ;cross
  98.                                                         ("_ins"
  99.        ((-1 1) (-1 -0.1))
  100.        ((-1 -0.1) (0 -0.1))
  101.        ((0 -0.1) (0 -1.0))
  102.        ((0 -1.0) (1 -1))
  103.        ((1 -1) (1 0.1))
  104.        ((1 0.1) (0 0.1))
  105.        ((0 0.1) (0 1.0))
  106.        ((0 1.0) (-1 1))
  107.                                                         )                        ;two squares
  108.                                                         ("_per"
  109.        ((-1 1) (-1 -1))
  110.        ((-1 -1) (1 -1))
  111.        ((0 -1) (0 0))
  112.        ((0 0) (-1 0))
  113.                                                         )                        ;half square
  114.                                                         ("_tan"
  115.        ((0 1) (-0.707 0.707))
  116.        ((-0.707 0.707) (-1 0))
  117.        ((-1 0) (-0.707 -0.707))
  118.        ((-0.707 -0.707) (0 -1))
  119.        ((0 -1) (0.707 -0.707))
  120.        ((0.707 -0.707) (1 0))
  121.        ((1 0) (0.707 0.707))
  122.        ((0.707 0.707) (0 1))
  123.        ((1 1) (-1 1))
  124.                                                         )                        ;circle+line
  125.                                                         ("_nea"
  126.        ((-1 1) (1 -1))
  127.        ((1 -1) (-1 -1))
  128.        ((-1 -1) (1 1))
  129.        ((1 1) (-1 1))
  130.                                                         )                        ;two triangle
  131.                                                         ("_qui")                ; ???
  132.                                                         ("_app"
  133.        ((-1 1) (-1 -1))
  134.        ((-1 -1) (1 -1))
  135.        ((1 -1) (1 1))
  136.        ((1 1) (-1 1))
  137.        ((-1 1) (1 -1))
  138.        ((-1 -1) (1 1))
  139.                                                         )                        ;square+cross
  140.                                                         ("_ext"
  141.        ((0.1 0) (0.13 0))
  142.        ((0.2 0) (0.23 0))
  143.        ((0.3 0) (0.33 0))
  144.                                                         )                        ;three points
  145.                                                         ("_par" ((0 1) (-1 -1)) ((1 1) (0 -1))) ;two lines
  146.                                                 )
  147.          )
  148.     )
  149.   )
  150.   ;;Use grvecs
  151.   (defun ypy_drawvecs (Pt Vecs Size Color / lst matrix)
  152.     ;;no Z axis
  153.     (setq matrix (list (list Size 0.0 0.0 (car pt))
  154.        (list 0.0 Size 0.0 (cadr pt))
  155.        (list 0.0 0.0 1.0 0.0)
  156.        (list 0.0 0.0 0.0 1.0)
  157.                  )
  158.     )
  159.     (setq lst (mapcar 'cons
  160.        (mapcar (function (lambda (x) Color)) Vecs)
  161.        Vecs
  162.               )
  163.     )
  164.     (grvecs (apply 'append lst) matrix)
  165.   )
  166.   ;;****************************
  167.   ;;  Main Routine starts here
  168.   ;;****************************
  169.   (vl-load-com)
  170.   (setq time T)
  171.   (setq str_osmode (get_osmode))
  172.   (setq lst_osmode (ypy_strparse str_osmode ","))
  173.   ;(setq draftobj (vla-get-Drafting
  174.   ;                 (vla-get-Preferences (vlax-get-acad-object))
  175.   ;               )
  176.   ;)
  177.   ;(setq autosnapmarkersize (vla-get-autosnapmarkersize draftobj))
  178.   ;(setq autosnapmarkercolor (vla-get-autosnapmarkercolor draftobj))
  179.         (setq autosnapmarkersize (atoi (getenv "AutoSnapSize")) autosnapmarkercolor (atoi (getenv "AutoSnapColor")))
  180.   (while time
  181.     (setq drag (grread T 15 0)) ;;Can change like (grread (setq drag (grread T 1 1)))
  182.     (cond
  183.                         ((= (car drag) 5)
  184.                                 (redraw)
  185.                                 (setq fm-get-gr drag drag (cadr drag))
  186.                                 (if (or (zerop (strlen str_osmode)) (null (setq ghostpt (osnap drag str_osmode))))
  187.                                         (setq ghostpt drag)
  188.                                         ;;Beacuse of mouse middle button scroll , calculate "distperpixel" every time
  189.                                         (progn (setq distperpixel (/ (getvar "VIEWSIZE") (cadr (getvar "SCREENSIZE"))))
  190.                                                 ;;bold
  191.                                                 (setq bold (mapcar '* (list distperpixel distperpixel distperpixel) (list (+ autosnapmarkersize 0.5) autosnapmarkersize (- autosnapmarkersize 0.5))))
  192.                                                 (foreach item bold
  193.                                                         (ypy_drawvecs ghostpt (ypy_getgrvecs ghostpt drag lst_osmode) item autosnapmarkercolor))
  194.                                         )
  195.                                 )
  196.                         )
  197.                         ((= (car drag) 3)
  198.                                 (if (null (setq ghostpt (osnap (cadr drag) (get_osmode))))
  199.                                         (setq ghostpt (cadr drag))
  200.                                 )
  201.                                 (redraw)
  202.                                 (setq time nil)
  203.                         )
  204.     )
  205.                 (print fm-get-gr)
  206.   )
  207.   (prin1) ;can return ghostpt if want
  208. )
已领礼包: 6056个
发表于 2017-7-13 00:27:03 | 显示全部楼层
为什么不把文件上传上来?这样看多不方便!
已领礼包: 1304个
发表于 2017-7-13 00:34:22 | 显示全部楼层
已领礼包: 496个
 楼主| 发表于 2017-7-13 07:42:02 | 显示全部楼层
源文件,里面稍微修改了部分,不影响修改前的功能
在grread状态下实现捕捉功能并显示标记符号(实用).lsp
6.68 KB, 下载次数: 5, 下载积分: D豆 -1 , 活跃度 1
GMT+8, 2026-11-5 13:16 , Processed in 0.391538 second(s), 39 queries , Gzip On.
