查看: 10065|回复: 42
[每日一码] 拟合的POLYLINE转SPLINE
发表于 2017-7-14 13:02:02 | 显示全部楼层 |阅读模式
  1. (defun c:2ndss2spls ( / *error* arc2spl line2spl loop sss i ent ssss )
  2.   (vl-load-com)
  3.   (defun *error* ( msg )
  4.     (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
  5.     (if msg (prompt msg))
  6.     (princ)
  7.   )
  8.   (defun arc2spl ( e / make_spline points q1 q2 a pc f pe ps w )
  9.            (setq q1 (vlax-curve-GetStartParam e)
  10.                  q2 (vlax-curve-GetEndParam e)
  11.                  a  (/ (- (vlax-curve-GetEndParam e) (vlax-curve-GetStartParam e)) 3.0) ; a - parameter interval... and angle
  12.                  pc (mapcar                              ; pc - points on contur
  13.                       (function
  14.                         (lambda (p)
  15.                          (vlax-curve-GetPointAtParam e p)
  16.                           )
  17.                         )
  18.                       (list q1 (+ q1 a) (- q2 a) q2)
  19.                     )
  20.                  f  (mapcar                               ; f - first deriv on pc
  21.                       (function
  22.                         (lambda (p)
  23.                           (vlax-curve-GetFirstDeriv e p)
  24.                           )
  25.                         )
  26.                       (list q1 (+ q1 a) (- q2 a) q2)
  27.                     )
  28.                  pe (mapcar                              ; pe - extra control points for spline construction
  29.                       (function
  30.                         (lambda (p1 p2 d1 d2)
  31.                           (inters p1 (mapcar '+ p1 d1)
  32.                                   p2 (mapcar '+ p2 d2)
  33.                                   nil
  34.                                   )
  35.                         )
  36.                       )
  37.                      pc (cdr pc) f (cdr f)
  38.                     )
  39.                  ps  (list (car pc) (car pe) (cadr pc) (cadr pe) (caddr pc) (caddr pe) (cadddr pc)) ; ps - control points for spline
  40.                  w   (list 1.0 (cos (/ a 2)) 1.0 (cos (/ a 2)) 1.0 (cos (/ a 2)) 1.0)  ; weights for spline
  41.            )
  42.     (defun make_spline ( pts )
  43.       (entmakex
  44.         (append
  45.            '((0 . "SPLINE") (100 . "AcDbEntity") (100 . "AcDbSpline")
  46.               (70 . 4) (71 . 2) (72 . 10) (73 . 7) (74 . 0)
  47.               (42 . 1.0e-010) (43 . 1.0e-010)
  48.               (40 . 0.0) (40 . 0.0) (40 . 0.0) (40 . 1.0) (40 . 1.0)
  49.               (40 . 2.0) (40 . 2.0) (40 . 3.0) (40 . 3.0) (40 . 3.0))
  50.            pts
  51.         )
  52.       )
  53.     )
  54.     (entdel e)
  55.     (make_spline (points ps w))
  56.   )
  57.   (defun line2spl ( e / sp ep d )
  58.     (setq sp (cdr (assoc 10 (entget e)))
  59.           ep (cdr (assoc 11 (entget e)))
  60.           d (distance sp ep)
  61.     )
  62.     (entdel e)
  63.     (entmakex
  64.       (list
  65.         '(0 . "SPLINE") '(100 . "AcDbEntity") '(100 . "AcDbSpline") '(210 0.0 0.0 1.0) '(71 . 1) '(73 . 2)
  66.         '(42 . 1.0e-010) '(43 . 1.0e-010) '(40 . 0.0) '(40 . 0.0) (cons 40 d) (cons 40 d) (cons 10 sp) (cons 10 ep)
  67.       )
  68.     )
  69.   )
  70.   (vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
  71.   (setq loop T)
  72.   (setq sss (ssget "_I"))
  73.   (if
  74.     (and
  75.       sss
  76.       (vl-some '(lambda ( x ) (wcmatch (cdr (assoc 0 (entget x))) "LINE,ARC,*POLYLINE")) (vl-remove-if 'listp (mapcar 'cadr (ssnamex sss))))
  77.     )
  78.     (setq loop nil)
  79.   )
  80.   (while loop
  81.     (setq sss (ssget "_:L" (list '(-4 . "<or") '(0 . "LINE,ARC,LWPOLYLINE") '(-4 . "<and") '(0 . "POLYLINE") '(-4 . "<or") '(70 . 0) '(70 . 1) '(70 . 8) '(70 . 9) '(70 . 128) '(70 . 129) '(-4 . "or>") '(-4 . "and>") '(-4 . "or>"))))
  82.     (if sss (setq loop nil))
  83.   )
  84.   (setq ssss (ssadd))
  85.   (repeat (setq i (sslength sss))
  86.     (setq ent (ssname sss (setq i (1- i))))
  87.     (cond
  88.       ( (eq (cdr (assoc 0 (entget ent))) "LINE")
  89.         (line2spl ent)
  90.         (ssadd (entlast) ssss)
  91.       )
  92.       ( (eq (cdr (assoc 0 (entget ent))) "ARC")
  93.         (arc2spl ent)
  94.         (ssadd (entlast) ssss)
  95.       )
  96.       ( (eq (cdr (assoc 0 (entget ent))) "LWPOLYLINE")
  97.         (sssetfirst nil (ssadd ent))
  98.         (c:lw2spl)
  99.         (ssadd (entlast) ssss)
  100.         (sssetfirst nil nil)
  101.       )
  102.       ( (and
  103.           (eq (cdr (assoc 0 (entget ent))) "POLYLINE")
  104.           (or
  105.             (eq (cdr (assoc 70 (entget ent))) 0)
  106.             (eq (cdr (assoc 70 (entget ent))) 1)
  107.             (eq (cdr (assoc 70 (entget ent))) 128)
  108.             (eq (cdr (assoc 70 (entget ent))) 129)
  109.           )
  110.         )
  111.         (command "_.CONVERTPOLY" "_L" ent)
  112.         (while (> (getvar 'cmdactive) 0) (command ""))
  113.         (sssetfirst nil (ssadd ent))
  114.         (c:lw2spl)
  115.         (ssadd (entlast) ssss)
  116.         (sssetfirst nil nil)
  117.       )
  118.       ( (and
  119.           (eq (cdr (assoc 0 (entget ent))) "POLYLINE")
  120.           (or
  121.             (eq (cdr (assoc 70 (entget ent))) 8)
  122.             (eq (cdr (assoc 70 (entget ent))) 9)
  123.           )
  124.         )
  125.         (sssetfirst nil (ssadd ent))
  126.         (c:3p2spl)
  127.         (ssadd (entlast) ssss)
  128.         (sssetfirst nil nil)
  129.       )
  130.     )
  131.   )
  132.   (sssetfirst nil ssss)
  133.   (*error* nil)
  134. )
  135. (defun c:oldheavyfit2spl ( / *error* *adoc* ss pl sp e sss )
  136.   (vl-load-com)
  137.   (defun *error* ( m )
  138.     (vla-endundomark *adoc*)
  139.     (if m
  140.       (prompt m)
  141.     )
  142.     (princ)
  143.   )
  144.   (vla-startundomark (setq *adoc* (vla-get-activedocument (vlax-get-acad-object))))
  145.   (prompt "\nPick old heavy 2d polyline that is curve fited...")
  146.   (setq ss (ssget "_+.:E:S:L" (list '(0 . "POLYLINE") '(-4 . "<or") '(70 . 2) '(70 . 3) '(70 . 130) '(70 . 131) '(-4 . "or>"))))
  147.   (if ss
  148.     (progn
  149.       (setq pl (ssname ss 0))
  150.       (setq sp (vlax-curve-getstartpoint pl))
  151.       (command "_.EXPLODE" pl)
  152.       (while (< 0 (getvar 'cmdactive))
  153.         (command "")
  154.       )
  155.       (sssetfirst nil (ssget "_P"))
  156.       (c:2ndss2spls)
  157.       (setq sss (cadr (ssgetfirst)))
  158.       (setq e (car (nentselp (trans sp 0 1))))
  159.       (command "_.JOIN" e sss "")
  160.     )
  161.   )
  162.   (*error* nil)
  163. )
函数 points :
游客,如果您要查看本帖隐藏内容请回复
已领礼包: 604个
发表于 2017-7-14 13:14:14 | 显示全部楼层
听说爆破一下就可以了,不知道是不是真的。很难遇到POLYLINE线,也无法验证
 楼主| 发表于 2017-7-14 13:17:02 | 显示全部楼层
自己画个2D POLYLINE不就验证了,你说的爆破一下是做什么? 变SPLINE ?
已领礼包: 6881个
发表于 2017-7-14 13:25:55 | 显示全部楼层
感谢版主的分享
谢谢
已领礼包: 2476个
发表于 2017-7-14 17:12:47 | 显示全部楼层
我以为是反过来..样条转多段线
已领礼包: 326个
发表于 2017-7-19 15:01:14 | 显示全部楼层
好程序,謝謝分享!
已领礼包: 26个
发表于 2017-7-19 19:14:02 | 显示全部楼层
已领礼包: 9341个
发表于 2017-7-19 19:46:26 | 显示全部楼层
实用程序谢谢分享!!!
已领礼包: 481个
发表于 2017-7-20 00:56:40 | 显示全部楼层
回复看看
已领礼包: 6个
发表于 2017-7-20 07:52:03 | 显示全部楼层
做好事业务的一样
已领礼包: 1337个
发表于 2017-10-26 17:49:49 | 显示全部楼层
进来学习哈,谢谢!
已领礼包: 2965个
财富等级: 家财万贯
发表于 2017-10-27 09:26:49 | 显示全部楼层
回复学习,谢谢分享
已领礼包: 5800个
发表于 2017-10-27 11:45:25 | 显示全部楼层
感谢自主分享程序
发表于 2017-11-7 23:46:53 | 显示全部楼层
不会吧,还可以这样
已领礼包: 41个
发表于 2018-1-18 09:51:51 | 显示全部楼层
多数是spline转polyline,这个牛逼谢谢分享
GMT+8, 2026-11-2 00:43 , Processed in 0.600063 second(s), 57 queries , Gzip On.
