查看: 2123|回复: 6
[每日一码] 绘制块实体属性文字的文字框
发表于 2017-7-14 18:49:46 | 显示全部楼层 |阅读模式
  1. (defun c:test ( / ent enx idx sel )
  2.     (if (setq sel (ssget '((0 . "INSERT") (66 . 1))))
  3.         (repeat (setq idx (sslength sel))
  4.             (setq ent (entnext (ssname sel (setq idx (1- idx))))
  5.                   enx (entget ent)
  6.             )
  7.             (while (= "ATTRIB" (cdr (assoc 0 enx)))
  8.                 (entmake
  9.                     (append
  10.                        '(
  11.                             (000 . "LWPOLYLINE")
  12.                             (100 . "AcDbEntity")
  13.                             (100 . "AcDbPolyline")
  14.                             (090 . 4)
  15.                             (070 . 1)
  16.                         )
  17.                         (list (cons 38 (cadddr (assoc 10 enx))))
  18.                         (mapcar '(lambda ( p ) (cons 10 p)) (LM:textbox ent))
  19.                         (list (assoc 210 enx))
  20.                     )
  21.                 )
  22.                 (setq ent (entnext ent)
  23.                       enx (entget  ent)
  24.                 )
  25.             )
  26.         )
  27.     )
  28.     (princ)
  29. )
  30. ;; Text Box  -  Lee Mac
  31. ;; A wrapper for the textbox function to return the bounding box of a Text or Attrib (in OCS)
  32. (defun LM:textbox ( ent / ins mat rot )
  33.     (setq ent (entget ent)
  34.           ins (cdr (assoc 10 ent))
  35.           rot (cdr (assoc 50 ent))
  36.           mat (list
  37.                   (list (cos rot) (sin (- rot)) 0.0)
  38.                   (list (sin rot) (cos rot)     0.0)
  39.                  '(0.0 0.0 1.0)
  40.               )
  41.     )
  42.     (mapcar '(lambda ( x ) (mapcar '+ (mxv mat x) ins)) (LM:points->boundingbox (textbox ent)))
  43. )
  44. ;; Points to Bounding Box  -  Lee Mac
  45. ;; Returns the rectangular extents of a supplied point list
  46. (defun LM:points->boundingbox ( lst )
  47.     (   (lambda ( l )
  48.             (mapcar '(lambda ( a ) (mapcar '(lambda ( b ) ((eval b) l)) a))
  49.                '(
  50.                     (caar   cadar)
  51.                     (caadr  cadar)
  52.                     (caadr cadadr)
  53.                     (caar  cadadr)
  54.                 )
  55.             )
  56.         )
  57.         (mapcar '(lambda ( f ) (apply 'mapcar (cons f lst))) '(min max))
  58.     )
  59. )
函数 MXV:
  1. ;; Matrix x Vector  -  Vladimir Nesterovsky
  2. ;; Args: m - nxn matrix, v - vector in R^n
  3. (defun mxv ( m v )
  4.     (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
  5. )
  6. (princ)
已领礼包: 6056个
发表于 2017-7-15 00:23:01 | 显示全部楼层
谢谢分享。
已领礼包: 1304个
发表于 2017-7-15 01:59:28 | 显示全部楼层
已领礼包: 9341个
发表于 2017-7-15 07:19:57 | 显示全部楼层
感谢分享,学习了!
已领礼包: 3904个
发表于 2017-7-15 07:45:02 | 显示全部楼层
发表于 2021-7-25 21:01:23 | 显示全部楼层
好像用不了呀
发表于 2021-8-4 16:14:57 | 显示全部楼层
不知道什么原因,用不了
GMT+8, 2026-10-14 07:05 , Processed in 0.489483 second(s), 44 queries , Gzip On.
