查看: 1463|回复: 2
[每日一码] 用VLISP实现打印动态块的属性
已领礼包: 20个
发表于 2017-7-18 22:37:24 | 显示全部楼层 |阅读模式
  1. (defun c:extract() ; by Fenton Webb and Wayne Brill, DevTech, 08/Jan/2007
  2.   ; make sure com is loaded
  3.   (vl-load-com)
  4.   ; get the acad application object
  5.   (setq AcadApp (vlax-get-acad-object))
  6.   ; now from that get the active document
  7.   (setq AcadDoc (vla-Get-ActiveDocument AcadApp))
  8.   ; now get the utility object so we can select an entity
  9.   (setq UtilObj (vla-Get-Utility AcadDoc))
  10.   ; now pick the block ref
  11.   (vla-GetEntity UtilObj 'BlockRefObj 'selPt)
  12.   ; so is this def a block ref
  13.   (if (equal (setq ObjType (vla-Get-ObjectName BlockRefObj))
  14.                      "AcDbBlockReference")
  15.     (progn
  16.       ; now get the dynamic block's properties
  17.       (setq dynProps (vlax-variant-value (vla-getDynamicBlockProperties BlockRefObj )))
  18.       (setq lBound (vlax-safearray-get-l-bound dynProps 1))
  19.       (setq uBound (vlax-safearray-get-u-bound dynProps 1))
  20.       (setq aCounter lBound)
  21.       (while (<= aCounter uBound)
  22.        (setq obj (vlax-safearray-get-element dynProps aCounter))
  23.        (princ "\nPropertyName ")
  24.        (princ "\n")
  25.        (princ (vla-get-PropertyName obj))
  26.           (princ "\nDescription ")
  27.           (princ (vla-get-Description obj))
  28.           (princ "\nReadonly ")
  29.           (princ (vla-get-readonly obj))
  30.           (princ "\nshow ")
  31.           (princ (vla-get-show obj))
  32.           (princ "\nvalue ")
  33.           (princ (vla-get-value obj))
  34.
  35.           (setq aCounter(1+ aCounter))
  36.
  37.       )
  38.
  39.     );progn
  40.   );if
  41.   ; now release everything to make sure
  42.   (if UtilObj
  43.     (progn (vlax-Release-Object UtilObj) (setq UtilObj nil))
  44.   )
  45.   (if AcadDoc
  46.     (progn (vlax-Release-Object AcadDoc) (setq AcadDoc nil))
  47.   )
  48.   (if AcadApp
  49.     (progn (vlax-Release-Object AcadApp) (setq AcadApp nil))
  50.   )
  51.   (princ)
  52. );defun
发表于 2017-10-13 10:26:12 | 显示全部楼层
高手啊,多谢多谢
已领礼包: 6468个
发表于 2017-10-16 00:07:11 | 显示全部楼层
谢谢分享。
GMT+8, 2026-11-5 13:51 , Processed in 0.384236 second(s), 33 queries , Gzip On.
