查看: 3916|回复: 14
[工具] MatchProp(刷子)
发表于 2017-7-20 22:46:34 | 显示全部楼层 |阅读模式
  1. ; My Match Properties - Grrr
  2. (defun C:MyMatchProps ( / tgassoc tgswitch *error* dcl des dch dcf tmp L SS tmpL i o )
  3.   ; Toggle associator - connect toggle value (0 or 1) with symbol value (nil or T):
  4.   (defun tgassoc ( keyorval ) (cadr (assoc keyorval '((nil "0")(T "1")("0" nil)("1" T)))) ) ; Grrr
  5.   ; Toggle switcher - switch toggle's value
  6.   (defun tgswitch ( key ) (set_tile key (cadr (assoc (get_tile key) '(("0" "1") ("1" "0")))))) ; Grrr
  7.   (defun *error* ( msg )
  8.     (and (< 0 dch) (unload_dialog dch))
  9.     (and (eq 'FILE (type des)) (close des))
  10.     (and (eq 'STR (type dcl)) (findfile dcl) (vl-file-delete dcl))
  11.     (and msg (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\nError: " msg)) ))
  12.     (princ)
  13.   ); defun *error*
  14.   (cond
  15.     ( (progn (and (setq SS (cadr (ssgetfirst))) (sssetfirst nil nil)) nil) ) ; I'm using implied SS, because I often work with SS filters
  16.     (
  17.       (progn
  18.         (while (not (member dcf '(0 1)))
  19.           (*error* nil)
  20.           (cond
  21.             (
  22.               (not ; Rewrite and Reload the dialog continiously
  23.                 (and (setq dcl (vl-filename-mktemp nil nil ".dcl")) (setq des (open dcl "w"))
  24.                   (vl-every (function (lambda (x) (princ (strcat "\n" x) des)))
  25.                     (list
  26.                       "MyMatchProps : dialog"
  27.                       "{ label = \"Match Properties\";"
  28.                       "  spacer; : column "
  29.                       "  { : row "
  30.                       "    { : text { label = \"Source object\"; }"
  31.                       "      : button { key = \"sb\"; label = \">>\"; fixed_width = true; width = 2; }"
  32.                       "    }"
  33.                       "    : row "
  34.                       "    { : text { label = \"Destination objects\"; }"
  35.                       "      : button { key = \"db\"; label = \">>\"; fixed_width = true; width = 2; }"
  36.                       "    }"
  37.                       "  }"
  38.                       "  : spacer { height = 1; }"
  39.                       (if L
  40.                         (strcat
  41.                           "  : column"
  42.                           "  { children_fixed_width = true; children_alignment = left;"
  43.                           "    : text { label = \"Properties To Match\"; }  spacer;"
  44.                           (apply 'strcat (mapcar (function (lambda (x) (strcat ": toggle { label = \"" (car x) "\"; key = \"" (car x) "\"; value = 1; }"))) L))
  45.                           "    spacer;"
  46.                           "    : button { label = \"Switch Toggles\"; key = \"Switch\"; mnemonic = \"t\"; }"
  47.                           "    spacer;"
  48.                           "  }"
  49.                         ); strcat
  50.                         "  : text { label = \"Source object not specified!\"; alignment = centered; }"
  51.                       ); if L
  52.                       "  : spacer { height = 1; }"
  53.                       "  ok_cancel; : text { key = \"error\"; }"
  54.                       "}"
  55.                     ); list
  56.                   ); vl-every
  57.                   (not (setq des (close des))) (< 0 (setq dch (load_dialog dcl)))
  58.                 ); and
  59.               ); not
  60.               (princ "\nUnable to write or load the DCL file.") (setq dcf 0)
  61.             )
  62.             ( (not (new_dialog "MyMatchProps" dch)) (princ "\nUnable to display the dialog") (setq dcf 0) )
  63.             (T
  64.               (if tmpL (mapcar (function (lambda (x) (set_tile (car x) (cdr x)))) tmpL)) ; remember (restore) chosen toggles between sessions.
  65.               (vl-every (function (lambda (x) (action_tile (car x) (strcat "(done_dialog " (itoa (cadr x)) ")")))) '(("sb" 2) ("db" 3))) ; button actions
  66.               (action_tile "Switch"
  67.                 (vl-prin1-to-string
  68.                   '(progn
  69.                     (mapcar (function (lambda (x) (tgswitch x))) (mapcar 'car L))
  70.                     (setq tmpL (mapcar (function (lambda (x) (cons x (get_tile x)))) (mapcar 'car L)))
  71.                   ); progn
  72.                 ); vl-prin1-to-string
  73.               ); action_tile
  74.               (if L
  75.                 (vl-every ; toggle actions
  76.                   (function
  77.                     (lambda (x)
  78.                       (action_tile (car x)
  79.                         (vl-prin1-to-string
  80.                           '(cond
  81.                             ( (assoc $key tmpL) (setq tmpL (subst (cons $key $value) (assoc $key tmpL) tmpL)) )
  82.                             ( (setq tmpL (cons (cons $key $value) tmpL)) )
  83.                           ); cond
  84.                         ); vl-prin1-to-string
  85.                       ); action_tile
  86.                     ); lambda
  87.                   ); function
  88.                   L
  89.                 ); vl-every
  90.               ); if L
  91.               (action_tile "accept"
  92.                 (vl-prin1-to-string
  93.                   '(cond
  94.                     ( (not L) (set_tile "error" "Check the above message - Grrr.") )
  95.                     ( (not SS) (set_tile "error" "Destination objects not specified!") )
  96.                     ( (setq L (mapcar (function (lambda (x) (append x (list (get_tile (car x)))))) L)) ; end result of L
  97.                       (done_dialog 1)
  98.                     )
  99.                   ); cond
  100.                 ); vl-prin1-to-string
  101.               ); action_tile
  102.               (setq dcf (start_dialog))
  103.             ); T
  104.           ); cond
  105.           (cond
  106.             ( (= 2 dcf)
  107.               (and
  108.                 (setq tmp
  109.                   (
  110.                     (lambda (x / p)
  111.                       (setvar 'errno 0)
  112.                       (while (/= 52 (getvar 'errno)) (setq p (car (entsel "\nSelect Source Object <exit>: ")))
  113.                         (cond ( (= 7 (getvar 'errno)) (princ "\nMissed, try again!") (setvar 'errno 0) )
  114.                           (p (setq p (vlax-ename->vla-object p)) (setvar 'errno 52) )
  115.                         ); cond
  116.                       ); while
  117.                       p
  118.                     ); lambda
  119.                     nil
  120.                   )
  121.                 ); setq tmp
  122.                 (setq L ; I care about only this list here
  123.                   (apply 'append
  124.                     (mapcar (function (lambda (x) (if (vlax-property-available-p tmp x) (list (list x (vlax-get tmp x))))))
  125.                       '("Color" "Layer" "LineType" "LinetypeScale" "Lineweight"
  126.                         "EntityTransparency" "Material" "Rotation" "TextString" "StyleName" "Width" "Height"
  127.                         "AttachmentPoint" "BackgroundFill" "LineSpacingDistance" "LineSpacingFactor" "LineSpacingStyle"
  128.                         "XEffectiveScaleFactor" "XScaleFactor" "YEffectiveScaleFactor" "YScaleFactor" "ZEffectiveScaleFactor" "ZScaleFactor"
  129.                       ); list
  130.                     ); mapcar
  131.                   ); apply 'append
  132.                 ); setq L
  133.               ); and
  134.             ); (= 2 dcf)
  135.             ( (= 3 dcf) (and (princ "\nSelect Destination Objects: ") (setq tmp (ssget "_:L")) (setq SS tmp) ) ); (= 3 dcf)
  136.           ); cond
  137.         ); while
  138.         (/= 1 dcf)
  139.       ); progn
  140.       (princ "\nUser cancelled the dialog.")
  141.     )
  142.     ( (and L SS)
  143.       (setq L (vl-remove-if (function (lambda (x) (not (tgassoc (caddr x))))) L))
  144.       (repeat (setq i (sslength SS))
  145.         (and (setq o (vlax-ename->vla-object (ssname SS (setq i (1- i))))) (vlax-write-enabled-p o)
  146.           (mapcar
  147.             (function
  148.               (lambda (x)
  149.                 (and (vlax-property-available-p o (car x)) (vl-catch-all-apply 'vlax-put (list o (car x) (cadr x))))
  150.               ); lambda
  151.             ); function
  152.             L
  153.           ); mapcar
  154.         ); and
  155.       ); repeat
  156.       ; (alert (apply 'strcat (mapcar '(lambda (x) (strcat "\n" (vl-prin1-to-string x))) L))) ; check
  157.       ; (alert (apply 'strcat (mapcar '(lambda (x) (strcat "\n" (vl-prin1-to-string x))) tmpL))) ; check
  158.     ); T
  159.   ); cond
  160.   (*error* nil) (princ)
  161. ); defun
发表于 2017-7-21 01:43:15 | 显示全部楼层
高手不凡,感谢
发表于 2017-7-21 07:17:11 | 显示全部楼层
谢谢分享程序!!!
发表于 2017-7-21 08:20:24 | 显示全部楼层
支持一下,要是有中文版的就好了!
发表于 2017-7-21 08:35:25 | 显示全部楼层
看不懂,也不清楚是什么用的,要是写个介绍就好了。新手什么都不懂。
发表于 2017-7-21 11:36:40 | 显示全部楼层
谢谢分享程序!!!
发表于 2017-7-21 15:02:38 | 显示全部楼层
谢谢 你的分享
发表于 2017-7-22 13:57:23 | 显示全部楼层
大师的作品都是精品,谢谢大师分享!!!
发表于 2017-8-7 08:00:11 | 显示全部楼层
非常不错的插件谢谢
发表于 2018-11-15 06:33:50 | 显示全部楼层
这个刷子不错和隔壁的刷子类似,但多了对话框。
发表于 2019-11-28 09:18:29 | 显示全部楼层
程序测试成功,但感觉还是没有CAD自带的格式刷方便
发表于 2019-11-28 09:34:52 | 显示全部楼层
谢谢分享程序!!!
发表于 2019-11-28 09:43:30 | 显示全部楼层
谢谢分享程序!!!
发表于 2019-11-28 09:59:38 | 显示全部楼层
感谢分享程序!
发表于 2019-11-29 12:38:08 | 显示全部楼层
非常不错的插件谢谢 收藏了!
GMT+8, 2026-11-22 10:32 , Processed in 0.424515 second(s), 37 queries , Gzip On, File On.
