查看: 1007|回复: 1
[求助] 独立基础形心对正柱子形心
已领礼包: 2个
发表于 2017-7-23 10:26:10 | 显示全部楼层 |阅读模式
柱子的形心事先生成好了,想要框选柱形心,让旁边的独立的形心对正柱子的,写了一段,但是移动不了,看了很久真不知道哪里有问题,麻烦大家帮看下,谢谢!!!
  1. (defun c:xxxz  ()
  2.   (setvar "osmode" 0)
  3.   (setvar "cmdecho" 0)
  4.   (setq ssb (ssget '((0 . "POINT"))))
  5.   (setq p 0)
  6.   (repeat (sslength ssb)
  7.     (setq name_pt (ssname ssb p))
  8.     (setq pt_cen (cdr (assoc 10 (entget name_pt))))
  9.     (setq pt_a (polar pt_cen (/ pi 2) 3000))
  10.     (setq pt_b (polar pt_cen (/ (* 5 pi) 4) 3000))
  11.     (zxx pt_a pt_b pt_cen)
  12.     (setq p (1+ p))
  13.     )
  14.   (princ)
  15.   )
  16. ;找形心
  17. (defun zxx  (a b c)
  18.   (vl-load-com)
  19.   (setq ss (ssget "C" a b))
  20.   (setq i 0)
  21.   (repeat (sslength ss)
  22.     (setq name (ssname ss i))
  23.     (setq nameb name)
  24.     (setq obj_type (cdr (assoc 0 (entget name))))
  25.     (setq obj_layer (cdr (assoc 8 (entget name))))
  26.     (if        (and (= obj_type "LWPOLYLINE") (= obj_layer "S-DJ"))
  27.       (progn
  28.         (command "copy" name "" 0 0)
  29.         (command "region" name "")
  30.         (setq name2 (entlast))
  31.         (setq name (vlax-ename->vla-object (entlast)))
  32.         (setq centroid (vla-get-Centroid name))
  33.         (setq pt_x (vlax-safearray-get-element
  34.                      (vlax-variant-value centroid)
  35.                      0))
  36.         (setq pt_y (vlax-safearray-get-element
  37.                      (vlax-variant-value centroid)
  38.                      1))
  39.         (setq pt (list pt_x pt_y 0))
  40.         (command "point" pt)
  41.         (entdel name2)
  42.         (command "move" nameb "" pt c)
  43. ;;;        (princ "11111111111111111")
  44.         )
  45.       )
  46.     (setq i (1+ i))
  47.     )
  48.   )
发表于 2017-7-23 10:42:00 | 显示全部楼层
截取个图片贴上来,并传一个测试DWG上来。
GMT+8, 2026-11-5 14:44 , Processed in 0.374925 second(s), 31 queries , Gzip On.
