查看: 8688|回复: 28
[求助] 如何删除掉多段线中间的弧线段
发表于 2017-7-27 12:27:42 | 显示全部楼层 |阅读模式
如图
发表于 2017-7-27 19:31:59 | 显示全部楼层
  1. (defun c:tt (/ enx hed idx int lst ocs rtn sel)
  2.   (if (setq sel        (ssget "_:L"
  3.                        '((0 . "LWPOLYLINE")
  4.                          (-4 . "<NOT")
  5.                          (-4 . "&=")
  6.                          (70 . 1)
  7.                          (-4 . "NOT>")
  8.                         )
  9.                 )
  10.       )
  11.     (repeat (setq idx (sslength sel))
  12.       (setq enx        (entget (ssname sel (setq idx (1- idx))))
  13.             hed        (reverse (member (assoc 38 enx) (reverse enx)))
  14.             ocs        (cdr (assoc 210 enx))
  15.             lst        (lwv-ptb enx)
  16.             rtn        nil
  17.       )
  18.       (while (caddr lst)
  19.         (cond
  20.           ((equal 0.0 (cdr (assoc 42 (car lst))) 1e-8)
  21.            (if (not (and rtn
  22.                          (ptonline (cdar rtn)
  23.                                    (cdr (assoc 10 (car lst)))
  24.                                    (cdr (assoc 10 (cadr lst)))
  25.                          )
  26.                     )
  27.                )
  28.              (setq rtn (cons (assoc 10 (car lst)) rtn))
  29.            )
  30.           )
  31.           (rtn
  32.            (if (setq int
  33.                       (apply 'inters
  34.                              (append
  35.                                (list (trans (cdar rtn) ocs 1))
  36.                                (mapcar
  37.                                  '(lambda (a b) (trans (cdr (assoc 10 a)) ocs 1))
  38.                                  lst
  39.                                  '(0 1 2)
  40.                                )
  41.                                '(nil)
  42.                              )
  43.                       )
  44.                )
  45.              (setq rtn (cons (cons 10 (trans int 1 ocs)) rtn))
  46.              (setq rtn (cons (assoc 10 (car lst)) rtn))
  47.            )
  48.           )
  49.         )
  50.         (setq lst (cdr lst))
  51.       )
  52.       (while (and (cadr lst)
  53.                   (ptonline (cdar rtn)
  54.                             (cdr (assoc 10 (car lst)))
  55.                             (cdr (assoc 10 (cadr lst)))
  56.                   )
  57.              )
  58.         (setq lst (cdr lst))
  59.       )
  60.       (setq rtn (append (reverse rtn) (mapcar 'car lst)))
  61.       (if (entmake
  62.             (append
  63.               (subst (cons 90 (length rtn)) (assoc 90 hed) hed)
  64.               (reverse rtn)
  65.               (list (cons 210 ocs))
  66.             )
  67.           )
  68.         (entdel (cdr (assoc -1 enx)))
  69.       )
  70.     )
  71.   )
  72.   (princ)
  73. )
  74. (defun ptonline        (pt1 pt2 pt3)
  75.   (equal (distance pt1 pt3)
  76.          (+ (distance pt1 pt2) (distance pt2 pt3))
  77.          1e-8
  78.   )
  79. )
lwv-ptb:
游客,如果您要查看本帖隐藏内容请回复
发表于 2017-7-27 20:29:41 | 显示全部楼层
看看,学习学习!!!
发表于 2017-7-27 20:50:39 | 显示全部楼层
回复,向大师学习!!!
  1. ;command方式简化版
  2. (defun c:fr0 ()
  3.   (command ".fillet" "r" 0)
  4.   (command ".fillet" "p")
  5. )
评分
参与人数 1D豆 +5 收起 理由
Lisphk + 5 技术引导讨论和指点奖!
查看全部评分
发表于 2017-7-27 21:35:31 | 显示全部楼层
进来看一看@,学习哈!
发表于 2017-7-28 00:34:43 | 显示全部楼层
不错,学习了。
发表于 2017-7-28 07:55:26 | 显示全部楼层
“marting”大师的水平就是高,知识渊博。
发表于 2017-7-28 08:33:09 | 显示全部楼层
看看,向大师学习
发表于 2017-7-28 09:14:51 | 显示全部楼层
只要看到大师代码就收了..
发表于 2017-7-28 14:43:15 | 显示全部楼层
感谢分享
学习学习再学习
发表于 2017-8-16 12:54:38 | 显示全部楼层
“我来测试一下,行不行”
发表于 2017-8-16 16:08:21 | 显示全部楼层
回复学习,谢谢
发表于 2017-8-17 09:23:56 | 显示全部楼层
看下,学习下
发表于 2019-1-10 20:59:46 | 显示全部楼层
不错,学习了。
发表于 2019-1-11 05:05:49 来自手机 | 显示全部楼层
学习再学习
来自: 微社区
GMT+8, 2026-11-24 16:14 , Processed in 0.353246 second(s), 41 queries , Gzip On, File On.
