查看: 5178|回复: 18
[每日一码] 将TEXT,MTEXT对齐方式修改为窗口的正中
发表于 2017-7-31 10:14:16 | 显示全部楼层 |阅读模式
  1. (defun c:tt (/ e ll ur c n)
  2.   (if
  3.     (and
  4.       (progn
  5.         (while
  6.           (and
  7.             (setq e (car (entsel "\nSelect Text or MText: ")))
  8.             (not (wcmatch (cdr (assoc 0 (setq l (entget e)))) "*TEXT"))
  9.           )
  10.            (princ "\n** Object must be Text or MText **")
  11.         )
  12.         e
  13.       )
  14.       (setq ll (getpoint "\nPick Lower-Left Corner: "))
  15.       (setq ur (getpoint "\nPick Upper-Right Corner: " ll))
  16.       (setq c (polar ll (angle ll ur) (/ (distance ll ur) 2.)))
  17.       (setq n (trans '(0. 0. 1.) 1 0 t))
  18.     )
  19.      (entupd
  20.        (cdr
  21.          (assoc        -1
  22.                 (entmod        (if (eq "MTEXT" (cdr (assoc 0 l)))
  23.                           (SubstDXF 10 (trans c 1 0) (SubstDXF 71 5 l))
  24.                           (SubstDXF 11
  25.                                     (trans c 1 n)
  26.                                     (SubstDXF 72 1 (SubstDXF 73 2 l))
  27.                           )
  28.                         )
  29.                 )
  30.          )
  31.        )
  32.      )
  33.   )
  34.   (princ)
  35. )
SubstDXF        :
游客,如果您要查看本帖隐藏内容请回复
评分
参与人数 1D豆 +5 收起 理由
sh_h + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
 楼主| 发表于 2017-7-31 10:17:09 | 显示全部楼层
另外一个同功能的,用VLISP实现的。
  1. (defun c:InRec (/ obj ptA ptB ptBase ptBL ptTR)
  2.   (vl-load-com)
  3.   (if (and (setq obj (car (entsel "\nSelect (text) object to move: ")))
  4.            (setq obj (vlax-ename->vla-object obj))
  5.            (setq ptA (getpoint "\nFirst corner of rectangle: "))
  6.            (setq ptB (getpoint ptA "\nSecond corner of rectangle: "))
  7.       )
  8.     (progn (cond ((vlax-property-available-p obj 'attachmentpoint)
  9.                                         ; AcDbMText
  10.                   (vlax-put obj 'attachmentpoint 5) ; 5 = middle center
  11.                   (setq ptBase (vlax-get obj 'insertionpoint))
  12.                  )
  13.                  ((vlax-property-available-p obj 'alignment) ; AcDbText
  14.                   (vlax-put obj 'alignment 10)
  15.                                         ; 10 = middle center; 4 = middle
  16.                   (setq ptBase (vlax-get obj 'textalignmentpoint))
  17.                  )
  18.                  ('T
  19.                   (vla-getboundingbox obj 'ptBL 'ptTR)
  20.                   (setq        ptBase (kg:MidPoint
  21.                                  (vlax-safearray->list ptBL)
  22.                                  (vlax-safearray->list ptTR)
  23.                                )
  24.                   )
  25.                  )
  26.            )
  27.            (vlax-invoke
  28.              obj
  29.              'move
  30.              ptBase
  31.              (trans (kg:MidPoint ptA ptB) 1 0)
  32.            )
  33.     )
  34.   )
  35. )
  36. (defun kg:MidPoint (pt1 pt2)
  37.   (mapcar '(lambda (a b) (/ (+ a b) 2.0)) pt1 pt2)
  38. )
  39. (princ "\nUsage: InRec ")
  40. (princ)
已领礼包: 2476个
发表于 2017-7-31 10:28:55 | 显示全部楼层
多行文本用得少..改成居中什么样??
发表于 2017-7-31 10:46:46 | 显示全部楼层
kkkkkkkkkkkkkkkkkkkkkkkkkkkkk
已领礼包: 9341个
发表于 2017-7-31 11:22:21 | 显示全部楼层
谢谢分享学习!!!!!
已领礼包: 780个
发表于 2017-7-31 11:30:07 | 显示全部楼层
谢谢楼主分享!!!
已领礼包: 75个
发表于 2017-7-31 12:55:01 | 显示全部楼层
位置改变不?
已领礼包: 5800个
发表于 2017-7-31 14:03:18 | 显示全部楼层
感谢楼主的源代码!
已领礼包: 620个
发表于 2017-8-1 08:08:12 | 显示全部楼层
感谢楼主的源代码!
已领礼包: 6468个
发表于 2017-8-1 10:23:27 | 显示全部楼层
回复学习。
已领礼包: 2965个
财富等级: 家财万贯
发表于 2017-8-1 22:36:37 | 显示全部楼层
回复学习,谢谢
已领礼包: 2个
发表于 2017-8-2 11:29:50 | 显示全部楼层
回复学习。
已领礼包: 6056个
发表于 2017-8-4 00:11:05 | 显示全部楼层
看看隐藏的是什么。
已领礼包: 174个
发表于 2018-12-14 16:04:23 | 显示全部楼层
来学习一下
已领礼包: 158个
发表于 2018-12-18 20:22:39 来自手机 | 显示全部楼层
看看藏了什么
来自: 微社区
GMT+8, 2026-11-2 23:12 , Processed in 0.553572 second(s), 58 queries , Gzip On.
