查看: 2542|回复: 4
[求助] 选择属性实体,如何能得到属性所属的INSERT的插入点?
发表于 2017-8-1 15:57:43 | 显示全部楼层 |阅读模式
  1. (setq obj (car (nentsel "\n拾取属性文字: ")))
  2. (setq objVL (vlax-ename->vla-object obj))
  3. (setq objVL-Strng (vlax-get objVL 'textstring))
  4. (setq objVL-inspnt (vlax-get objVL 'insertionpoint))
上面'insertionpoint属性得到的是属性文字的插入点,那块的插入点呢?
发表于 2017-8-1 16:29:03 | 显示全部楼层
要从属性实体,得到它所属的块实体,用 vla-get-ownerid ,得到块的对象后,就可以用 insertionpoint 获得块的插入点了
  1. (defun c:tt ()
  2.   (if (and (setq att (car (nentsel "\n选择属性文字: ")))
  3.            (setq attobj (vlax-ename->vla-object att))
  4.            (= "AcDbAttribute" (vla-get-objectname attobj))
  5.            (setq blkobj        (vla-ObjectIdToObject
  6.                           (vla-get-ActiveDocument (vlax-get-acad-object))
  7.                           (vla-get-OwnerID attobj)
  8.                         )
  9.            )
  10.       )
  11.     (progn
  12.       (setq attpt (vlax-get attobj 'InsertionPoint)) ;;属性插入点
  13.       (setq blkpt (vlax-get blkobj 'InsertionPoint)) ;;INSERT插入点
  14.     )
  15.   )
  16. )
已领礼包: 20个
发表于 2017-8-1 17:07:52 | 显示全部楼层
块对象也可以用组码330得到
  1. (and
  2.   (setq att (car (nentsel "\nSelect attribute: ")))
  3.   (= "ATTRIB" (cdr (assoc 0 (entget att))))
  4.   (setq attobj (vlax-ename->vla-object att))
  5.   (setq blkobj (cdr (assoc 330 (entget att))))
  6.   (setq attpt (vlax-get attobj 'InsertionPoint))
  7.   (setq blkpt (cdr (assoc 10 (entget blkobj))))
  8. )
已领礼包: 1268个
发表于 2017-8-1 17:16:38 | 显示全部楼层
已领礼包: 375个
发表于 2021-1-5 09:29:04 | 显示全部楼层
已经收藏,感谢楼主的问题
GMT+8, 2026-11-3 15:10 , Processed in 0.508514 second(s), 37 queries , Gzip On.
