查看: 1635|回复: 2
[每日一码] 选择集转换成VLA选择集
发表于 2017-8-3 12:59:40 | 显示全部楼层 |阅读模式
  1. (defun VanillaSS->VlaSS ( SS SSnm / i L SScoll SfArrayObjs vSS )
  2.   (cond
  3.     ( (not (eq 'PICKSET (type SS))) nil)
  4.     ( (not (and (eq 'STR (type SSnm)) (snvalid SSnm))) nil)
  5.     (T
  6.       (repeat (setq i (sslength SS))
  7.         (setq L (cons (vlax-ename->vla-object (ssname SS (setq i (1- i)))) L))
  8.       )
  9.       (setq SScoll (vla-get-SelectionSets (vla-get-ActiveDocument (vlax-get-acad-object))))
  10.       (if (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-Item (list SScoll SSnm))))
  11.         (vla-Delete (vla-Item SScoll SSnm))
  12.       )
  13.       (setq vSS (vla-Add SScoll SSnm))
  14.       (setq SfArrayObjs (vlax-make-safearray vlax-vbObject (cons 0 (1- (length L)))))
  15.       (setq i -1)
  16.       (foreach o L (vlax-safearray-put-element SfArrayObjs (setq i (1+ i)) o) )
  17.       (vla-AddItems vSS SfArrayObjs)
  18.       vSS
  19.     )
  20.   )
  21. )
已领礼包: 20个
发表于 2017-8-3 13:32:10 | 显示全部楼层
发个选择集转到VLA对象表
  1. (defun ss2vlalst (ss)
  2.   (if (= (type ss) 'pickset)
  3.     (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
  4.   )
  5. )
已领礼包: 6468个
发表于 2017-8-4 00:09:20 | 显示全部楼层
二楼的代码简单哦
GMT+8, 2026-11-5 15:34 , Processed in 0.392401 second(s), 33 queries , Gzip On.
