查看: 1375|回复: 13
[研讨] 关于TEXT实体设置对齐方式为中下时候遇到的问题
发表于 2017-8-6 01:49:03 | 显示全部楼层 |阅读模式
  1. (defun c:tt2 ()
  2.   (if (and (setq e (car (entsel "\nselect a text:")))
  3.            (setq o (vlax-ename->vla-object e))
  4.            (eq (vla-get-objectname o) "AcDbText")
  5.            (setq pt (getpoint "\npick alignment point:"))
  6.       )
  7.     (progn
  8.       (vla-put-alignment o acAlignmentbottomCenter)
  9.       (vla-put-textalignmentpoint o (vlax-3d-point pt))
  10.     )
  11.   )
  12.   (princ)
  13. )
上面代码TT2,是设置对齐方式为中下,但是对齐点离开文字很远,其他的对齐方式,朋友们帮忙测试和分析下
文字样式字体用SHX。
已领礼包: 1268个
发表于 2017-8-6 02:59:26 来自手机 | 显示全部楼层
换个字体
嗯,很多字体都有这个问题,romanc,romand,complex都有这个问题  发表于 2017-8-7 13:15
已领礼包: 5060个
发表于 2017-8-6 07:19:29 来自手机 | 显示全部楼层
手机回复,没法测试:应该是顺序问题,dxf10和dxf11是两个不同组码,如果先改对齐方式为中下,中断一下,文字的位置会变了。试试去掉alignment,改 vla-put-textposition
已领礼包: 2476个
发表于 2017-8-6 08:01:22 | 显示全部楼层
Justify Alignment Mode HorizontalMode(setHozMode) VerticalMode(setVerMode) Code73 Code72
0 acAlignmentLeft L 0 0 0 0
1 acAlignmentCenter C 0 1 0 1
2 acAlignmentRight R 0 2 0 2
3 acAlignmentAligned A 0 3 0 3
4 acAlignmentMiddle M 0 4 0 4
5 acAlignmentFit F 0 5 0 5
6 acAlignmentTopLeft TL 3 0 3 0
7 acAlignmentTopCenter TC 3 1 3 1
8 acAlignmentTopRight TR 3 2 3 2
9 acAlignmentMiddleLeft ML 2 0 2 0
10 acAlignmentMiddleCenter MC 2 1 2 1
11 acAlignmentMiddleRight MR 2 2 2 2
12 acAlignmentBottomLeft BL 1 0 1 0
13 acAlignmentBottomCenter BC 1 1 1 1
14 acAlignmentBottomRight BR 1 2 1 2
(setq l1 '(0 1 2 3 4 5 6 7 8 9 10 11 12 13 14)
        l2 '("L" "C" "R" "A" "M" "F" "TL" "TC" "TR" "ML" "MC" "MR" "BL" "BC" "BR")
(setq e (entlast)
        pc (Vlax-Get (Vlax-Ename->Vla-Object e) 'InsertionPoint )
        pc1 (Vlax-Get (Vlax-Ename->Vla-Object e) 'TextAlignmentPoint )
(Vlax-Put-Property (Vlax-Ename->Vla-Object e) 'Alignment 10 )
(setq pca (Vlax-Get (Vlax-Ename->Vla-Object e) 'InsertionPoint ))
(Vlax-Put-Property (Vlax-Ename->Vla-Object e) 'TextAlignmentPoint (Vlax-3d-Point (mapcar '- pc pca)) )
感觉跟块插入点意思相近
 楼主| 发表于 2017-8-6 08:15:00 | 显示全部楼层
测试下对齐方式 13, acAlignmentBottomCenter
 楼主| 发表于 2017-8-6 08:18:01 | 显示全部楼层
所有的西文的字体都这样。就想看看是AUTOCAD的BUG,还是有什么方法解决。
 楼主| 发表于 2017-8-6 08:34:21 | 显示全部楼层
又测试了几次,发现是当BIGFONT设置为 gbcbig.shx时候,才会出现问题,难道是这个字体设计的原因?
已领礼包: 2476个
发表于 2017-8-6 08:58:33 | 显示全部楼层
我测试没问题....
 楼主| 发表于 2017-8-6 09:10:59 | 显示全部楼层
你的代码,我修改了对齐方式是13,
你用下我上面图的样式设置,大字体用 GBCBIG.SHX,小字体随便,你在测试下
  1. (defun c:tt ()
  2.   (setq        l1 '(0 1 2 3 4 5 6 7 8 9 10 11 12 13 14)
  3.         l2 '("L" "C" "R" "A" "M" "F" "TL" "TC" "TR" "ML" "MC" "MR" "BL"
  4.              "BC" "BR")
  5.   )
  6.   (setq        e   (entlast)
  7.         pc  (Vlax-Get (Vlax-Ename->Vla-Object e) 'InsertionPoint)
  8.         pc1 (Vlax-Get (Vlax-Ename->Vla-Object e) 'TextAlignmentPoint)
  9.   )
  10.   (Vlax-Put-Property (Vlax-Ename->Vla-Object e) 'Alignment 13)
  11.   (setq pca (Vlax-Get (Vlax-Ename->Vla-Object e) 'InsertionPoint))
  12.   (Vlax-Put-Property
  13.     (Vlax-Ename->Vla-Object e)
  14.     'TextAlignmentPoint
  15.     (Vlax-3d-Point (mapcar '- pc pca))
  16.   )
  17. )
已领礼包: 2476个
发表于 2017-8-6 09:38:31 | 显示全部楼层
这次位置不对了..
已领礼包: 1268个
发表于 2017-8-6 10:37:21 | 显示全部楼层
这个可能和图形(英制)以及 字体定义中的控制有关,一般用 style 命令修改,没有深究过
已领礼包: 604个
发表于 2017-8-6 21:29:37 | 显示全部楼层
遇到过,但没深究。当时感觉还是JUSTIFYTEXT命令好。
已领礼包: 20个
发表于 2017-8-6 21:41:37 | 显示全部楼层
这种字体,应该用JUSTTEXT命令结果也一样。应该是字体设计的缺陷。
因为命令也是调用底层内部的核心,和VLA调用的是一样的。
GMT+8, 2026-11-5 15:39 , Processed in 0.459089 second(s), 57 queries , Gzip On.
