查看: 3263|回复: 8
[求助] 多重引线的源块属性块的值怎么修改和获取!
发表于 2017-8-12 20:54:16 | 显示全部楼层 |阅读模式
多重引线的属性块的值怎么获取修改,纯属性块可以获取修改,但是但是用到多重引线就不行了!
发表于 2017-8-12 21:31:52 | 显示全部楼层
论坛好像是讨论过,适当的关键字搜搜
已领礼包: 20个
发表于 2017-8-12 21:41:29 | 显示全部楼层
mleader VLA对象的方法里面有
所以,你可以用 vla-getblockattributevalue 获得mleader 属性块的值
例子:
  1. (vl-load-com)
  2. (defun c:Example_BlockAttribute()
  3.     ;; This example creates an MLeader object and gets and sets values for
  4.     ;; the block attribute type.
  5.     (setq acadObj (vlax-get-acad-object))
  6.     (setq doc (vla-get-ActiveDocument acadObj))
  7.
  8.     (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5)))
  9.     (vlax-safearray-fill points '(0 4 0
  10.                                   1.5 5 0
  11.                                  )
  12.     )
  13.     (setq i 0)
  14.
  15.     (setq modelSpace (vla-get-ModelSpace doc))
  16.     (setq oML (vla-AddMLeader modelSpace points i))
  17.
  18.     (vla-put-ContentType oML acBlockContent)
  19.     (vla-put-ContentBlockType oML acBlockBox)
  20.     (setq sBlock (vla-get-ContentBlockName oML))
  21.     (vlax-for o (vla-Item (vla-get-Blocks doc) sBlock)
  22.         (if (= (vla-get-ObjectName o) "AcDbAttributeDefinition")
  23.                    (progn
  24.                 (vla-SetBlockAttributeValue oML (vla-get-ObjectID o) "123")
  25.                 (alert (vla-GetBlockAttributeValue oML (vla-get-ObjectID o)))
  26.                    )
  27.         )
  28.     )
  29.
  30.     (vla-Update acadObj)
  31.     (vla-ZoomExtents acadObj)
  32. )
 楼主| 发表于 2017-8-12 22:45:14 | 显示全部楼层
找到一个可以用的,但是如果有两个值,不知道怎么改成两个不同的,可以帮我改下么,才学lisp 不怎么会
  • (defun c:data ()
  •   (setq value "值")
  •   (setq ss (ssget ":L" '((0 . "multileader"))))
  •   (setq mleader (ssname ss 0))
  •   (vl-load-com)
  •   ;; ? Lee Mac 2010
  •   (if (and (eq "AcDbMLeader"
  •                (vla-get-objectname
  •                  (setq mleader (cond ((eq 'vla-object (type mleader)) mleader)
  •                                      ((vlax-ename->vla-object mleader))
  •            (= 1 (vla-get-contenttype mleader))
  •            (setq def (lm:itemp (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
  •                                (vla-get-contentblockname mleader)
  •     (vlax-for obj def
  •       (if (eq "AcDbAttributeDefinition" (vla-get-objectname obj))
  •         ;; RJP mod to get existing value and add a new value to it
  •         (if (and (setq id (vla-get-objectid obj))
  •                  (setq exval (vla-getblockattributevalue mleader id))
  •           (vla-setblockattributevalue mleader id value)
 楼主| 发表于 2017-8-12 22:58:19 | 显示全部楼层
  • (defun lm:itemp        (coll item)
  •   ;; ? Lee Mac 2010
  •   (if
  •     (not (vl-catch-all-error-p (setq item (vl-catch-all-apply (function vla-item) (list coll item))))
  •      item
发表于 2017-8-13 00:56:35 | 显示全部楼层
截取个图片说明下吧,什么样的两个不同的,开始前图片,和你修改后的图片
 楼主| 发表于 2017-8-13 14:15:17 | 显示全部楼层
我想要的效果是最后的那样
已领礼包: 51个
发表于 2017-8-13 14:25:41 | 显示全部楼层
你普通的块的属性,多个文字的,你是怎么写的代码, 多重引线属性块是一样的写法,因为都是一个函数
发表于 2025-4-20 16:39:46 | 显示全部楼层
(vl-load-com)
(defun c:CopyTagNumB (/ ent entData blkName blkDef attDef tagVal newPos newEnt)
    (setq ent (car (entsel "\n选择要复制的多重引线块: ")))
    (cond
        ((not ent)
            (princ "\n未选择任何对象"))
        ((/= (cdr (assoc 0 (setq entData (entget ent)))) "INSERT")
            (princ "\n选择的不是块对象"))
        (T
            (setq blkName (cdr (assoc 2 entData)))
            (setq blkDef (tblsearch "BLOCK" blkName))
            ; 查找块定义中的属性定义
            (setq attDef (entnext (cdr (assoc -2 blkDef))))
            (while (and attDef (/= (cdr (assoc 0 (entget attDef))) "ATTDEF"))
                (setq attDef (entnext attDef)))
            (if (null attDef)
                (princ "\n块中没有属性定义")
                (progn
                    (setq tagVal (cdr (assoc 1 (entget attDef))))
                    (if (numberp (read tagVal))
                        (progn
                            (setq newPos (list (+ (car (cdr (assoc 10 entData))) 10)
                                      (cadr (cdr (assoc 10 entData)))
                                      (caddr (cdr (assoc 10 entData)))))
                            (command "_.COPY" ent "" "_non" (cdr (assoc 10 entData)) "_non" newPos)
                            ; 获取新块
                            (setq newEnt (entlast))
                            (while (and newEnt (/= (cdr (assoc 0 (entget newEnt))) "INSERT"))
                                (setq newEnt (entnext newEnt)))
                            (if newEnt
                                (progn
                                    (command "_.ATTEDIT" "_E" newEnt "TAGNUMB" "" "" (itoa (+ (read tagVal) 1)))
                                    (princ (strcat "\n已创建新块,数值:" (itoa (+ (read tagVal) 1)))))
                                (princ "\n未找到新块"))
                        (princ "\n属性值非数字"))
    (princ)
GMT+8, 2026-11-3 01:33 , Processed in 0.554702 second(s), 48 queries , Gzip On.
