查看: 1736|回复: 0
[每日一码] 关闭所有的文档(包括当前文档)
发表于 2017-8-30 23:46:09 | 显示全部楼层 |阅读模式
Close all documents including the current one
By Balaji Ramamoorthy
The sample code closes all documents, including the current one by first closing all documents except the current one in the document context. The current document is then closed from the application context using the executeInApplicationContext API. This allows the current document to be closed from the same command which is running in the document context.
  1. // Close the other documents
  2. AcApDocumentIterator *Iter
  3.                     = acDocManager->newAcApDocumentIterator();
  4. while(!Iter->done())
  5. {
  6.     if (Iter->document()!=acDocManager->curDocument())
  7.     {
  8.         acDocManager->closeDocument(Iter->document());
  9.     }
  10.     Iter->step();
  11. }
  12. delete Iter;
  13. // Now close the current document
  14. ::acDocManagerPtr()->appContextCloseDocument
  15.                                 (acDocManager->curDocument());
GMT+8, 2026-11-22 10:37 , Processed in 0.549903 second(s), 8 queries , Gzip On, File On.
