查看: 1616|回复: 5
[分享] 发一个拖曳的通用类
发表于 2017-9-2 14:39:48 | 显示全部楼层 |阅读模式
  1. class EntityDrawJig : DrawJig
  2.     {
  3.         public static Point3d m_pt1;
  4.         public Point3d insertPt;
  5.         private List<Entity> en = new List<Entity>();
  6.         public EntityDrawJig(List<Entity> ent,Point3d pt)
  7.         {
  8.             en = ent;
  9.             m_pt1 = pt;
  10.         }
  11.         protected override bool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.WorldDraw draw)
  12.         {
  13.             foreach (Entity e in en)
  14.             {
  15.                 draw.Geometry.Draw(e);
  16.             }
  17.             return true;
  18.         }
  19.         protected override SamplerStatus Sampler(JigPrompts prompts)
  20.         {
  21.             Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
  22.             Database db = HostApplicationServices.WorkingDatabase;
  23.             Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
  24.             Matrix3d mt = ed.CurrentUserCoordinateSystem;
  25.             JigPromptPointOptions optJig = new JigPromptPointOptions("\n指定插入点");
  26.             optJig.UserInputControls = UserInputControls.Accept3dCoordinates | UserInputControls.NullResponseAccepted;
  27.             PromptPointResult resJigInsertPt = prompts.AcquirePoint(optJig);
  28.             m_pt1 = m_pt1.TransformBy(mt);
  29.             insertPt=resJigInsertPt.Value;
  30.             if (resJigInsertPt.Status == PromptStatus.Cancel)
  31.             {
  32.                 return SamplerStatus.Cancel;
  33.             }
  34.             if (m_pt1 != insertPt)
  35.             {
  36.                 Vector3d vector = m_pt1.GetVectorTo(insertPt);
  37.                 Matrix3d mat = Matrix3d.Displacement(vector);
  38.                 for (int i = 0; i < en.Count; i++)
  39.                 {
  40.                     en.TransformBy(mat);
  41.                 }
  42.                 m_pt1 = insertPt;
  43.                 return SamplerStatus.OK ;
  44.             }
  45.             else
  46.             {
  47.                 return SamplerStatus.NoChange;
  48.             }
  49.         }
  50.     }
  51. [CommandMethod("sy")]
  52.         public void 实验()
  53.         {
  54.             Database db = HostApplicationServices.WorkingDatabase;
  55.             Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
  56.             Point3d pt = Point3d.Origin;
  57.             Line line1 = new Line(pt, pt.polarPoint(Math.PI / 4, 100));
  58.             Line line2 = new Line(pt, pt.polarPoint(-Math.PI / 4, 100));
  59.             Circle c = new Circle(pt, Vector3d.ZAxis, 50);
  60.             List<Entity> ent = new List<Entity>();
  61.             ent.Add(c);
  62.             ent.Add(line1);
  63.             ent.Add(line2);
  64.             EntityDrawJig draJig = new EntityDrawJig(ent, pt);
  65.             PromptResult proResult = ed.Drag(draJig);
  66.             if (proResult.Status == PromptStatus.OK)
  67.             {
  68.                 for (int i = 0; i < ent.Count; i++)
  69.                 {
  70.                     ObjectId objId = db.AddToModelSpace(ent);
  71.                 }
  72.             }
  73.         }
 楼主| 发表于 2017-9-2 14:46:46 | 显示全部楼层
没搞明白,为什么网站的添加代码文字没用
发表于 2017-9-2 14:59:47 | 显示全部楼层
你先原样贴上来,我帮你修改下。
发表于 2017-9-3 20:31:42 | 显示全部楼层
向大佬学习
已领礼包: 7个
发表于 2017-9-25 12:45:11 | 显示全部楼层
参考参考参考参考参考参考
发表于 2018-1-9 09:18:26 | 显示全部楼层
haodaima ,ganxie louzhu wusifengxian
GMT+8, 2026-11-2 22:05 , Processed in 0.466285 second(s), 41 queries , Gzip On.
