查看: 6185|回复: 36
[每日一码] 几类曲线的转向代码
已领礼包: 20个
发表于 2017-9-6 16:26:53 | 显示全部楼层 |阅读模式
1. 直线
[JavaScript] 纯文本查看 复制代码
;; Reverse LINE - Marko Ribar, d.i.a.
(defun rli ( li / enx sp ep )
  (if (= (cdr (assoc 0 (setq enx (entget li)))) "LINE")
    (progn
      (setq sp (cdr (assoc 10 enx)) ep (cdr (assoc 11 enx)))
      (setq enx (subst (cons 10 ep) (assoc 10 enx) enx))
      (setq enx (subst (cons 11 sp) (assoc 11 enx) enx))
      (entmod enx)
      (entupd li)
2.3DPOLYLINE
;; Reverse 3DPOLYLINE - Marko Ribar, d.i.a.
(defun r3dp ( 3dp / v p pl sfa var )
  (vl-load-com)
  (if
    (and
      (= (cdr (assoc 0 (entget 3dp))) "POLYLINE")
      (< 7 (cdr (assoc 70 (entget 3dp))) 10)
    (progn
      (setq v 3dp)
      (while (= (cdr (assoc 0 (entget (setq v (entnext v))))) "VERTEX")
        (setq p (cdr (assoc 10 (entget v))))
        (setq pl (cons p pl))
      (setq pl (apply 'append pl))
      (setq sfa (vlax-make-safearray vlax-vbdouble (cons 0 (1- (length pl)))))
      (vlax-safearray-fill sfa pl)
      (setq var (vlax-make-variant sfa))
      (vla-put-coordinates (vlax-ename->vla-object 3dp) var)
      (entupd 3dp)
3. SPLINE
;; Reverse SPLINE - Marko Ribar, d.i.a.
(defun rspl ( spl / enx x12 x13 x1 x2 x3 x4 x5 )
  (if (= (cdr (assoc 0 (setq enx (entget spl)))) "SPLINE")
    (progn
      (foreach a1 enx
        (cond
          ( (= (car a1) 12) (setq x13 (cons (cons 13 (mapcar '- (cdr a1))) x13)) )
          ( (= (car a1) 13) (setq x12 (cons (cons 12 (mapcar '- (cdr a1))) x12)) )
          ( (= (car a1) 40) (setq x2 (cons a1 x2)) )
          ( (= (car a1) 10) (setq x3 (cons a1 x3)) )
          ( (= (car a1) 41) (setq x4 (cons a1 x4)) )
          ( (= (car a1) 11) (setq x5 (cons a1 x5)) )
          ( t (setq x1 (cons a1 x1)) )
      (entmod
        (append
          (reverse x1)
          x12
          x13
          (mapcar '(lambda ( x ) (cons 40 (- (cdar x2) (cdr x)))) x2)
          (if x4
            (apply 'append (mapcar '(lambda ( a b ) (list a b)) x3 x4))
            x3
          x5
      (entupd spl)
4.LWPOLYLINE
(defun rlw ( LW / E X1 X2 X3 X4 X5 X6 )
  ;; by ElpanovEvgeniy
  ;; reverse lwpolyline
  (if (= (cdr (assoc 0 (setq e (entget lw)))) "LWPOLYLINE")
    (progn (foreach a1 e
             (cond ((= (car a1) 10) (setq x2 (cons a1 x2)))
                   ((= (car a1) 40) (setq x4 (cons (cons 41 (cdr a1)) x4)))
                   ((= (car a1) 41) (setq x3 (cons (cons 40 (cdr a1)) x3)))
                   ((= (car a1) 42) (setq x5 (cons (cons 42 (- (cdr a1))) x5)))
                   ((= (car a1) 210) (setq x6 (cons a1 x6)))
                   (t (setq x1 (cons a1 x1)))
           (entmod (append (reverse x1)
                           (append (apply (function append)
                                          (apply (function mapcar)
                                                 (cons 'list
                                                       (list x2
                                                             (cdr (reverse (cons (car x3) (reverse x3))))
                                                             (cdr (reverse (cons (car x4) (reverse x4))))
                                                             (cdr (reverse (cons (car x5) (reverse x5))))
                                   x6
           (entupd lw)
5.HELIX
;; Reverse HELIX - Marko Ribar, d.i.a.
(defun rhel ( hel / enx enx1 enx2 v x1 x2 x3 )
  (if (= (cdr (assoc 0 (setq enx (entget hel)))) "HELIX")
    (progn
      (setq enx1 (reverse (cdr (member '(100 . "AcDbHelix") (reverse enx)))))
      (setq enx2 (member '(100 . "AcDbHelix") enx))
      (foreach a1 enx1
        (cond
      (setq enx2 (subst (cons 40 (distance (cdr (assoc 10 enx2)) (cdr (assoc 11 enx2)))) (assoc 40 enx2) enx2))
      (setq enx2 (subst (cons 10 (mapcar '+ (cdr (assoc 10 enx2)) (mapcar '* (cdr (assoc 12 enx2)) (list (* (cdr (assoc 41 enx2)) (cdr (assoc 42 enx2))) (* (cdr (assoc 41 enx2)) (cdr (assoc 42 enx2))) (* (cdr (assoc 41 enx2)) (cdr (assoc 42 enx2))))))) (assoc 10 enx2) enx2))
      (setq enx2 (subst (cons 11 (cdr (car x3))) (assoc 11 enx2) enx2))
      (setq enx2 (subst (cons 12 (mapcar '- (cdr (assoc 12 enx2)))) (assoc 12 enx2) enx2))
      (entmod
        (append
          (reverse x1)
          x3
          enx2
      (entupd hel)
6.2d POLYLINE
游客,如果您要查看本帖隐藏内容请回复
评分
参与人数 1D豆 +20 收起 理由
sh_h + 20 很给力!经验;技术要点;资料分享奖!
查看全部评分
已领礼包: 2476个
发表于 2017-9-6 16:32:55 | 显示全部楼层
这个是不是之前有人分享过..还是收了..反正好东西..
已领礼包: 6881个
发表于 2017-9-6 19:02:08 | 显示全部楼层
这是不是线型反向啊
谢谢大师的作品
已领礼包: 481个
发表于 2017-9-6 20:32:15 | 显示全部楼层
谢谢大师
已领礼包: 780个
发表于 2017-9-6 22:04:16 | 显示全部楼层
谢谢大师分享!!!
已领礼包: 4044个
发表于 2017-9-6 22:34:04 | 显示全部楼层
回复学习学习!
已领礼包: 1337个
发表于 2017-9-7 12:57:32 | 显示全部楼层
挺好的.谢谢分享.
已领礼包: 2759个
财富等级: 家财万贯
发表于 2017-9-7 14:44:51 | 显示全部楼层
学习!!!!!!!!!!!!!!
已领礼包: 6056个
发表于 2017-9-8 01:22:20 | 显示全部楼层
学习一下。
已领礼包: 812个
发表于 2017-9-8 08:00:09 | 显示全部楼层
感谢大师分享.
已领礼包: 1368个
发表于 2017-9-8 09:06:22 | 显示全部楼层
谢谢分享,正需要。
已领礼包: 2965个
财富等级: 家财万贯
发表于 2017-9-8 09:16:17 | 显示全部楼层
回复学习学习
已领礼包: 1482个
发表于 2017-9-8 16:28:05 | 显示全部楼层
回复看看,感谢分享。
已领礼包: 5800个
发表于 2017-9-9 08:59:53 | 显示全部楼层
非常感谢楼主分享代码!
已领礼包: 720个
发表于 2017-9-9 16:50:11 | 显示全部楼层
收了
GMT+8, 2026-11-3 01:45 , Processed in 0.523926 second(s), 58 queries , Gzip On.
