查看: 2376|回复: 4
[求助] vba如何调用lisp里vlax-curve曲线相关函数
发表于 2017-9-29 16:45:49 | 显示全部楼层 |阅读模式
[Visual Basic] 纯文本查看 复制代码
Sub GetLength()
    Dim obj As AcadEntity
    Dim pnt As Variant
    ThisDrawing.Utility.GetEntity obj, pnt, "选取曲线:"
    Dim leng As Double
    leng = GetCurveLength(obj)
    MsgBox "所选曲线的长度为 " & leng, , "明经通道VBA示例"
End Sub
'返回曲线的长度
Public Function GetCurveLength(curve As AcadEntity) As Double
    Dim obj As VLAX, retVal
    Set obj = New VLAX
    obj.EvalLispExpression "(setq curve (handent " & Chr(34) & curve.Handle & Chr(34) & "))"
    obj.EvalLispExpression "(setq curvelength (vlax-curve-getDistAtParam curve " & _
                           "(vlax-curve-getEndParam curve)))"
    retVal = obj.GetLispSymbol("curvelength")
    obj.NullifySymbol "curve", "curvelength"
    '释放内存,函数返回
    Set obj = Nothing
    GetCurveLength = CDbl(retVal)
End Function
Sub 曲线最近的点2()
    Dim pnt As Variant
    Dim pt(0 To 2) As Double
    pt(0) = 1292
    pt(1) = 129
    pt(2) = 0
    Dim ClosestPT
    ClosestPT = getClosestPointTo(obj, pt())
    MsgBox "所最近为 " & ClosestPT, , "明经通道VBA示例"
End Sub
'返回到曲线上的最近点
Public Function getClosestPointTo(curve As AcadEntity, givenPnt() As Double) As Double
    Dim pt As String
    Set obj = New VLAX
    pt = "'(" & givenPnt(0) & Chr(32) & givenPnt(1) & Chr(32) & givenPnt(2) & ")))"
    obj.EvalLispExpression "(setq getClosestPointTo (vlax-curve-getClosestPointTo curve " & pt
    retVal = obj.GetLispSymbol("getClosestPointTo")
    obj.NullifySymbol "curve", "getClosestPointTo"
    '释放内存,函数返回
    Set obj = Nothing
    getClosestPointTo = CDbl(retVal)
End Function
'(vlax-curve-getClosestPointTo arcObj '(2.0 6.0 0.0))
' VLAX.CLS v2.0 (Last updated 8/1/2003)
' Copyright 1999-2001 by Frank Oquendo
' 该程序由明经通道修改支持2004版本
' [url]http://www.mjtd.com[/url]
' Permission to use, copy, modify, and distribute this software
' for any purpose and without fee is hereby granted, provided
' that the above copyright notice appears in all copies and
' that both that copyright notice and the limited warranty and
' restricted rights notice below appear in all supporting
' documentation.
' FRANK OQUENDO (THE AUTHOR) PROVIDES THIS PROGRAM "AS IS" AND WITH
' ALL FAULTS. THE AUTHOR SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY
' OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.  THE AUTHOR
' DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
' UNINTERRUPTED OR ERROR FREE.
' Use, duplication, or disclosure by the U.S. ** is subject to
' restrictions set forth in FAR 52.227-19 (Commercial Computer
' Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
' (Rights in Technical Data and Computer Software), as applicable.
' VLAX.cls allows developers to evaluate AutoLISP expressions from
' Visual Basic or VBA
' Notes:
' All code for this class module is publicly available througout various posts
' at [url]news://discussion.autodesk.com/autodesk.autocad.customization.vba.[/url] I do not
' claim copyright or authorship on code presented in these posts, only on this
' compilation of that code. In addition, a great big "Thank you!" to Cyrille Fauvel
' demonstrating the use of the VisualLISP ActiveX Module.
' Dependencies:
' Use of this class module requires the following application:
' 1. VisualLISP
Private VL As Object
Private VLF As Object
Private Sub Class_Initialize()
    '根据AutoCAD的版本判断使用的库类型
    If Left(ThisDrawing.Application.Version, 2) = "15" Then
        Set VL = ThisDrawing.Application.GetInterfaceObject("VL.Application.1")
    ElseIf Left(ThisDrawing.Application.Version, 2) = "16" Then
        Set VL = ThisDrawing.Application.GetInterfaceObject("VL.Application.16")
    End If
    Set VLF = VL.ActiveDocument.Functions
End Sub
Private Sub Class_Terminate()
    '类析构时,释放内存
    Set VLF = Nothing
    Set VL = Nothing
End Sub
Public Function EvalLispExpression(lispStatement As String)
    '根据LISP表达式调用函数
    Dim sym As Object, ret As Object, retVal
    Set sym = VLF.Item("read").funcall(lispStatement)
    On Error Resume Next
    retVal = VLF.Item("eval").funcall(sym)
    If Err Then
        EvalLispExpression = ""
    Else
        EvalLispExpression = retVal
    End If
End Function
Public Sub SetLispSymbol(symbolName As String, value)
    Dim sym As Object, ret, symValue
    symValue = value
    Set sym = VLF.Item("read").funcall(symbolName)
    ret = VLF.Item("set").funcall(sym, symValue)
    EvalLispExpression "(defun translate-variant (data) (cond ((= (type data) 'list) (mapcar 'translate-variant data)) ((= (type data) 'variant) (translate-variant (vlax-variant-value data))) ((= (type data) 'safearray) (mapcar 'translate-variant (vlax-safearray->list data))) (t data)))"
    EvalLispExpression "(setq " & symbolName & "(translate-variant " & symbolName & "))"
    EvalLispExpression "(setq translate-variant nil)"
End Sub
Public Function GetLispSymbol(symbolName As String)
    symValue = value
    GetLispSymbol = VLF.Item("eval").funcall(sym)
End Function
Public Function GetLispList(symbolName As String) As Variant
    Dim sym As Object, list As Object
    Dim Count, elements(), i As Long
    Set list = VLF.Item("eval").funcall(sym)
    Count = VLF.Item("length").funcall(list)
    ReDim elements(0 To Count - 1) As Variant
    For i = 0 To Count - 1
        elements(i) = VLF.Item("nth").funcall(i, list)
    Next
    GetLispList = elements
End Function
Public Sub NullifySymbol(ParamArray symbolName())
    Dim i As Integer
    For i = LBound(symbolName) To UBound(symbolName)
        EvalLispExpression "(setq " & CStr(symbolName(i)) & " nil)"
    Next
End Sub
我在其他地方找到的一段vba如何调用lisp里vlax-curve曲线相关函数的代码(见附件),原代码实现的功能是获取曲线的长度,我依葫芦画瓢想调用lisp的vlax-curve-getClosestPointTo函数实现获取"曲线上离指定点最近的点"的功能(在同一个附件里),但提示"类型不匹配"是什么原因呢
发表于 2018-3-7 03:14:29 | 显示全部楼层
我也遇到同样的问题,而且加载了vl-active-module
发表于 2018-3-14 10:09:10 | 显示全部楼层
Sub GetLength()
    Dim pnt As Variant
    ThisDrawing.SetVariable "cmdecho", 0
    ThisDrawing.SendCommand "(vl-load-com)" & vbCr
    ThisDrawing.SendCommand "(setq ent (handent " & Chr(34) & obj.Handle & Chr(34) & "))" & vbCr
    ThisDrawing.SendCommand "(setvar " & Chr(34) & "USERR1" & Chr(34) & "(vlax-curve-getdistatparam ent (vlax-curve-getendparam ent)))" & vbCr
    MsgBox "所选曲线的长度为 " & str(ThisDrawing.GetVariable("USERR1"))
End Sub
Sub GetLength1()
    Dim pnt As Variant
    MsgBox "所选曲线的长度为 " & str(obj.Length)
End Sub
评分
参与人数 1D豆 +5 收起 理由
newer + 5 热心帮忙奖!
查看全部评分
发表于 2018-3-14 10:40:27 | 显示全部楼层
'再来一个
Sub GetLength2()
    Dim pnt As Variant
    ThisDrawing.SendCommand "(defun getLength(ent) (setq ent (handent ent)) (rtos (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent)) 2 5))" & vbCr
    ThisDrawing.SendCommand "(getLength " & Chr(34) & obj.Handle & Chr(34) & ")" & vbCr
    MsgBox "所选曲线的长度为 " & ThisDrawing.GetVariable("LASTPROMPT")
End Sub
发表于 2018-3-14 14:29:18 | 显示全部楼层
'来一个真正使用vlax-curve曲线相关函数的
Sub Get_Curve_Length()
    Dim VL As Object
    Dim VLF As Object
    Dim Sym As Object
    Dim Ret As Variant
    Else
    End If
    Dim Pnt As Variant
    Dim Ent As AcadEntity
    Dim Pdbz As Boolean
    Pdbz = True
    Do While Pdbz
        ThisDrawing.Utility.GetEntity Ent, Pnt, "选择曲线:"
        If Err <> 0 Then
           Exit Do
        End If
        If VarType(Ent) = vbObject Then
           If InStr("AcDbLine,AcDbPolyline,AcDb2dPolyline,AcDb3dPolyline,AcDbSpline,AcDbCircle,AcDbArc,AcDbEllipse", Ent.ObjectName) > 0 Then
              Set Sym = VLF.Item("read").funcall("handle")
              Ret = VLF.Item("set").funcall(Sym, Ent.Handle)
              Set Sym = VLF.Item("read").funcall("(setq curve (handent handle))")
              Set Ret = VLF.Item("eval").funcall(Sym)
              Set Sym = VLF.Item("read").funcall("(vlax-curve-getDistAtParam curve (vlax-curve-getEndParam curve))")
              MsgBox "选取的曲线长度=" & Ret, 64, "提示"
            Else
              MsgBox "选取的曲线不具有长度属性!", 64, "提示"
            End If
            Pdbz = True
        Else
           Pdbz = False
        End If
    Loop
    Set VLF = Nothing
    Set VL = Nothing
End Sub
GMT+8, 2026-11-22 08:52 , Processed in 0.285123 second(s), 16 queries , Gzip On, File On.
