查看: 2940|回复: 8
[求助] 块属性自动编号小插件
发表于 2017-10-14 11:32:13 | 显示全部楼层 |阅读模式
悬赏20D豆未解决
这个插件是一个块属性数字自动编号的,求大神给修改成带前缀数字的块属性的自动编号,并且能够修改成同时两个或多个带前缀属性的自动编号。
;;-----------------=={ AutoLabel Attributes }==---------------;;
;;  Automatically labels a specific attribute in a set of     ;;
;;  blocks, renumbering if blocks are added, copied or        ;;
;;  erased.                                                   ;;
;;  Author: Lee Mac, Copyright ?2011 - www.lee-mac.com       ;;
;;  Version 1.0    -    14-09-2011                            ;;
;;                         Settings                           ;;
;; [Note: Block names and Attribute Tags are *not* case-sensitive]
(setq *blockname* "010"  ;; Name of Block to be Updated
      *blocktag*  "编"    ;; Attribute Tag to be Updated
;;                      Main Program                          ;;
(defun ObjectReactorCallback:RenumberBlocks ( object reactor params )
    (setq *reactor* reactor)
    (vlr-command-reactor "temp" '((:vlr-commandended . CommandReactorCallback:RenumberBlocks)))
    (vlr-remove  reactor)
    (princ)
(defun CommandReactorCallback:RenumberBlocks ( reactor params / e f i l n s )
    (if reactor (vlr-remove reactor))
    (if
        (and
            (not *undoflag*)
            (setq s (ssget "_X" *filter*))
        (progn
            (setq n 0)
            (repeat (setq i (sslength s))
                (if (eq *blockname*
                        (AutoLabel:EffectiveName
                            (setq o (vlax-ename->vla-object (setq e (ssname s (setq i (1- i))))))
                    (progn
                        (setq e (entnext e)
                              l (entget  e)
                              f nil
                        (while (and (not f) (eq "ATTRIB" (cdr (assoc 0 l))))
                            (if (eq *blocktag*  (strcase (cdr (assoc 2 l))))
                                (setq f (entmod (subst (cons 1 (itoa (setq n (1+ n)))) (assoc 1 l) l)))
                            (setq e (entnext e)
                                  l (entget  e)
                        (if (and *reactor* (not (member o (vlr-owners *reactor*))))
                            (vlr-owner-add *reactor* o)
    (if *reactor*
        (progn (vlr-add *reactor*) (setq *reactor* nil))
    (princ)
(defun CommandReactorCallback:UndoCheck ( reactor params )
    (setq *undoflag* (wcmatch (strcase (car params)) "*U,*UNDO"))
    (princ)
(defun CommandReactorCallback:BlockInserted ( reactor params / e l )
    (if
        (and
            (not *undoflag*)
            (wcmatch (strcase (car params)) "*I,*INSERT,*EXECUTETOOL")
            (setq e (entlast))
            (setq l (entget e))
            (eq "INSERT" (cdr (assoc 0 l)))
            (= 1 (cdr (assoc 66 l)))
            (eq *blockname* (AutoLabel:EffectiveName (vlax-ename->vla-object e)))
        (AutoLabel:GetNewNumber e)
    (princ)
(defun AutoLabel:GetNewNumber ( ent / e f i l n r s )
    (if (setq s (ssget "_X" *filter*))
        (progn
            (setq n 0)
                (if (eq *blockname*
                        (AutoLabel:Effectivename
                            (vlax-ename->vla-object (ssname s (setq i (1- i))))
                    (setq n (1+ n))
            (setq e (entnext ent)
                  l (entget e)
                    (setq f (entmod (subst (cons 1 (itoa n)) (assoc 1 l) l)))
                (setq e (entnext e)
                      l (entget  e)
            (if
                (setq r
                    (vl-some
                        (function
                            (lambda ( r ) (if (eq *reacdata* (vlr-data r)) r))
                        (cdar (vlr-reactors :vlr-object-reactor))
                (vlr-owner-add r (vlax-ename->vla-object ent))
    (princ)
(defun AutoLabel:EffectiveName ( obj )
    (strcase
        (if (vlax-property-available-p obj 'effectivename)
            (vla-get-effectivename obj)
            (vla-get-name obj)
;;                   Loading Expressions                      ;;
(vl-load-com)
    (lambda ( / i s l o )
        (setq
            *blocktag*  (strcase *blocktag*)
            *blockname* (strcase *blockname*)
            *reacdata*  "AutoBlockLabel"
            *reactor*   nil
            *undoflag*  nil
        (foreach r1 (vlr-reactors)
            (foreach r2 (cdr r1)
                (if (eq *reacdata* (vlr-data r2)) (vlr-remove r2))
        (if
            (setq s
                (ssget "_X"
                    (setq *filter*
                        (list
                           '(0 . "INSERT")
                           '(66 . 1)
                            (cons 2 (strcat "`*U*," *blockname*))
                            (cons 410 (getvar 'CTAB))
            (progn
                    (if (eq *blockname*
                                (setq o (vlax-ename->vla-object (ssname s (setq i (1- i)))))
                        (setq l (cons o l))
                (CommandReactorCallback:RenumberBlocks nil nil)
                (vlr-object-reactor l *reacdata*
                    (list
                        (cons :vlr-erased   'ObjectReactorCallback:RenumberBlocks)
                        (cons :vlr-copied   'ObjectReactorCallback:RenumberBlocks)
                        (cons :vlr-unerased 'ObjectReactorCallback:RenumberBlocks)
                (vlr-command-reactor *reacdata*
                    (list
                        (cons :vlr-commandwillstart 'CommandReactorCallback:UndoCheck)
                        (cons :vlr-commandended     'CommandReactorCallback:BlockInserted)
(princ)
;;                         End of File                        ;;
 楼主| 发表于 2017-10-14 11:36:14 | 显示全部楼层
就像这个图中的属性块,加前缀自动编号
已领礼包: 1304个
发表于 2017-10-15 00:20:44 | 显示全部楼层
支持支持支持支持支持支持
已领礼包: 31个
发表于 2017-10-15 08:31:30 | 显示全部楼层
可以使用吗?好用吗?
发表于 2017-10-16 08:23:21 | 显示全部楼层
是怎么个自动法呢,是已经有的属性,编辑,自动加上前缀,还是新建的就自动加上前缀?
发表于 2017-10-16 10:06:59 | 显示全部楼层
论坛有插件,
对话框文字万能替换工具
登录/注册后可看大图
发表于 2020-6-3 07:54:57 | 显示全部楼层
学习之中,希望高手解决
已领礼包: 586个
发表于 2020-6-3 09:07:26 | 显示全部楼层
万能编号 _按属性值排序给属性图块编号
http://bbs.xdcad.net/forum.php?m ... &fromuid=783614
(出处: 晓东CAD家园-论坛)
已领礼包: 18个
发表于 2020-6-12 22:50:52 | 显示全部楼层
只能按块复制的时间前后,而不是位置前后编号的。
GMT+8, 2026-11-3 06:14 , Processed in 0.503046 second(s), 45 queries , Gzip On.
