查看: 1216|回复: 0
[求助] 判断一点处直线相交形状,VBA有没有比较快的方法
发表于 2017-11-1 13:29:12 | 显示全部楼层 |阅读模式
用VBA判断某一点处直线的形状,比如以下四种形状,见图。我的思路和代码如下,但运行的实在太慢,请教各位大神,有没有好的办法,多谢
某一点处直线相交的形状
某一点处直线相交的形状
我的思路是从该点附近的四个方向,分别做栏选,判断每次是不是有直线选中,然后综合栏选结果,判断直线形状:
思路
思路
代码如下:
'输入AcadDocument对象(CadDOc),点(pnt),栏选偏移量(offset_value),形状代号(k:1,2,3,4),输出在该点处的直线是否具有形状代号代表的形状
Function criss_cross(cadDoc As AcadDocument, pnt As Variant, offset_value As Double, k As Integer) As Boolean
    Dim x As Double
    Dim y As Double
    Dim up_line As Boolean
    Dim down_line As Boolean
    Dim left_line As Boolean
    Dim right_line As Boolean
    up_line = False
    down_line = False
    left_line = False
    right_line = False
    x = pnt(0)
    y = pnt(1)
    x_left = x - offset_value
    x_right = x + offset_value
    y_up = y + offset_value
    y_down = y - offset_value
    Dim sel_line As AcadSelectionSet
    On Error Resume Next
    If Not IsNull(cadDoc.SelectionSets.Item("line1")) Then
        Set xx_sel = cadDoc.SelectionSets.Item("line1")
        xx_sel.Delete
    End If
    On Error GoTo 0
    Set sel_line = cadDoc.SelectionSets.Add("line1")
    BuildFilter pType1, pData1, 0, "LINE,LWPOLYLINE"
    Dim up_pt_list(0 To 5) As Double
    up_pt_list(0) = x_left: up_pt_list(1) = y_up: up_pt_list(2) = 0#
    up_pt_list(3) = x_right: up_pt_list(4) = y_up: up_pt_list(5) = 0#
    Dim down_pt_list(0 To 5) As Double
    down_pt_list(0) = x_left: down_pt_list(1) = y_down: down_pt_list(2) = 0#
    down_pt_list(3) = x_right: down_pt_list(4) = y_down: down_pt_list(5) = 0#
    Dim left_pt_list(0 To 5) As Double
    left_pt_list(0) = x_left: left_pt_list(1) = y_up: left_pt_list(2) = 0#
    left_pt_list(3) = x_left: left_pt_list(4) = y_down: left_pt_list(5) = 0#
    Dim right_pt_list(0 To 5) As Double
    right_pt_list(0) = x_right: right_pt_list(1) = y_up: right_pt_list(2) = 0#
    right_pt_list(3) = x_right: right_pt_list(4) = y_down: right_pt_list(5) = 0#
    sel_line.SelectByPolygon acSelectionSetFence, up_pt_list, pType1, pData1
    If sel_line.Count > 0 Then up_line = True
    sel_line.Clear
    sel_line.SelectByPolygon acSelectionSetFence, down_pt_list, pType1, pData1
    If sel_line.Count > 0 Then down_line = True
    sel_line.Clear
    sel_line.SelectByPolygon acSelectionSetFence, left_pt_list, pType1, pData1
    If sel_line.Count > 0 Then left_line = True
    sel_line.Clear
    sel_line.SelectByPolygon acSelectionSetFence, right_pt_list, pType1, pData1
    If sel_line.Count > 0 Then right_line = True
    sel_line.Clear
    Dim dic_point_type As New Dictionary
    dic_point_type(1) = False
    dic_point_type(2) = False
    dic_point_type(3) = False
    dic_point_type(4) = False
    If up_line And left_line Then dic_point_type(1) = True
    If up_line And right_line Then dic_point_type(2) = True
    If down_line And right_line Then dic_point_type(3) = True
    If down_line And left_line Then dic_point_type(4) = True
    criss_cross = dic_point_type(k)
End Function
上面这段代码对下图的每个交点处理一遍,耗时4分钟左右:
GMT+8, 2026-11-22 09:30 , Processed in 1.983506 second(s), 9 queries , Gzip On, File On.
