查看: 1798|回复: 0
[每日一码] 批量计算面积(POLYLINE,LWPOLYLINE,SPLINE,ARC,CIRCLE,SPLINE,HATCH,REGION)
发表于 2017-11-30 23:55:01 | 显示全部楼层 |阅读模式
  1. (defun c:tt ()
  2.   (if (setq
  3.         ss (ssget '((0 . "*POLYLINE,CIRCLE,ELLIPSE,SPLINE,ARC,REGION,HATCH"))
  4.            )
  5.       )
  6.     (progn (setq ar (apply '+ (xdrx_entity_getproperty ss "area")))
  7.            (princ (xdrx_string_format "\n总面积=%.2f" ar))
  8.     )
  9.   )
  10.   (princ)
  11. )
命令: tt
选择对象: 指定对角点: 找到 4 个
选择对象:
总面积=4382119.29
GMT+8, 2026-11-22 11:07 , Processed in 0.353444 second(s), 9 queries , Gzip On, File On.
