查看: 1197|回复: 4
[求助] 如何用VLISP程序设定cad的样版路径?
发表于 2017-12-1 15:19:17 | 显示全部楼层 |阅读模式
发表于 2017-12-1 15:45:01 | 显示全部楼层
使用 activex  Preferences对象,具体看帮助手册。
vla-put-TemplateDwgPath
[JavaScript] 纯文本查看 复制代码
(vl-load-com)
(defun c:Example_TemplateDwgPath()
    ;; This example returns the current setting of
    ;; TemplateDwgPath. It then changes the value, and finally
    ;; it resets the value back to the original setting.
    (setq acadObj (vlax-get-acad-object))
    (setq preferences (vla-get-Preferences acadObj))
    ;; Retrieve the current TemplateDWGPath value
    (setq currTemplateDWGPath (vla-get-TemplateDwgPath (vla-get-Files preferences)))
    (alert (strcat "The current value for TemplateDwgPath is " currTemplateDWGPath))
    ;; Change the value for TemplateDWGPath
    (setq newTemplateDWGPath "TestTemplateDWGPath")
    (vla-put-TemplateDwgPath (vla-get-Files preferences) newTemplateDWGPath)
    (alert (strcat "The new value for TemplateDwgPath is " newTemplateDWGPath))
    ;; Reset TemplateDWGPath to its original value
    (vla-put-TemplateDwgPath (vla-get-Files preferences) currTemplateDWGPath)
    (alert (strcat "The TemplateDwgPath value is reset to " currTemplateDWGPath))
 楼主| 发表于 2017-12-1 17:11:06 | 显示全部楼层
非常非常的感谢,先研究研究!
已领礼包: 9341个
发表于 2017-12-2 08:31:57 | 显示全部楼层
感谢分享程序,3Q
GMT+8, 2026-11-5 10:19 , Processed in 0.391669 second(s), 38 queries , Gzip On.
