查看: 1291|回复: 1
[每日一码] 字符串SPLIT函数
已领礼包: 20个
发表于 2017-12-11 10:19:29 | 显示全部楼层 |阅读模式
  1. ;; Usage: (split (getenv "PrinterConfigDir") ";")
  2. ;; Usage: (split (getenv "PrinterStyleSheetDir") ";")
  3. (defun split (**pression sDelimiter / len val sList)
  4.   ; Get the length of the first item from the expression based on delimiter position
  5.   (setq len (vl-string-position (ascii sDelimiter) **pression))
  6.   ; Loop until there are no more instances of the delimiter in the expression
  7.   (while (numberp len)
  8.     ; Get the item from the expression
  9.     (setq val (substr **pression 1 len))
  10.     ; Append the item to the list
  11.     (setq sList (cons val sList))
  12.     ; Get the remaining part of the expression
  13.     (setq **pression (substr **pression (+ 2 len)))
  14.     ; Get the length of the next item from the string based on delimiter position
  15.     (setq len (vl-string-position (ascii sDelimiter) **pression))
  16.   )
  17.   ; Add the last value to the list
  18.   (if (/= **pression nil)
  19.     (setq sList (cons **pression sList))
  20.   )
  21.   ; Reverse the elements and return the list
  22.   (reverse sList)
  23. )
命令: (split (getenv "PrinterStyleSheetDir") ";")
("C:\\Users\\ArcGIS\\appdata\\roaming\\autodesk\\autocad 2016\\r20.1\\chs\\plot styles" "C:\\Users\\ArcGIS\\appdata\\roaming\\autodesk\\autocad 2016\\r20.1\\chs\\plotters\\plot styles")
已领礼包: 20个
 楼主| 发表于 2017-12-11 10:22:11 | 显示全部楼层
相当于正则表达式查询函数
命令: (xd::string:regexps "[^;]+" (getenv "PrinterStyleSheetDir") "")
GMT+8, 2026-11-5 09:33 , Processed in 0.351456 second(s), 31 queries , Gzip On.
