查看: 1506|回复: 1
[[coior=red]文档类] (XD::DOC:XrefPathsList)返回图形中附着的所有XREF文件的路径列表
已领礼包: 20个
发表于 2017-12-11 10:43:59 | 显示全部楼层 |阅读模式
函数发布
函数名称: XD::DOC:XrefPathsList
调用格式: (XD::DOC:XrefPathsList bIncludeFullPath)
参数说明: bIncludeFullPath --- T 完整路径,NIL 仅返回文件名和扩展名
返回值: 表
函数简介: 返回图形中附着的所有XREF文件的路径列表
函数来源: 转载
函数作者:
适用版本: 不限
最后更新时间: 2017-12-11
备注: -
演示图片: -
  1. ;; Returns a list of Xref filenames attached to the drawing
  2. ;; bIncludeFullPath = T - Full file path is returned
  3. ;; bIncludeFullPath = nil - Filename and extension only are returned
  4. ;; Usage: (XD::DOC:XrefPathsList T)
  5. ;; Usage: (XD::DOC:XrefPathsList nil)
  6. (defun XD::DOC:XrefPathsList (bIncludeFullPath / ent val fullName fileName fileList)
  7.   ; Get the first element of the Blocks symbol table
  8.   (setq ent (tblnext "block" T))
  9.   ; Step through the Blocks symbol table
  10.   (while ent
  11.     ; Check for the DXF group code 1
  12.     (if (setq val (assoc 1 ent))
  13.       (progn
  14.         ; Get the xref path name from the DXF group
  15.         (setq fullName (cdr val))
  16.         ; Determine whether the filename is returned only or the full path
  17.         (if bIncludeFullPath
  18.           (progn
  19.             ; Check for a relative path and attempt to resolve the path
  20.             (setq fileName (XD::FILE:ResolveRelativePath fullName (vl-string-trim "\\" (getvar "dwgprefix"))))
  21.           )
  22.           ; Return the filename and extension only
  23.           (setq fileName (strcat (vl-filename-base fullName) (vl-filename-extension fullName)))
  24.         )
  25.         ; Append the filename to the list
  26.         (setq fileList (cons fileName fileList))
  27.       )
  28.     )
  29.     ; Return the next block in the Block symbol table
  30.     (setq ent (tblnext "block"))
  31.   )
  32.   ; Return a sorted list of filenames
  33.   (vl-sort fileList '<)
  34. )
GMT+8, 2026-11-2 22:06 , Processed in 0.556987 second(s), 34 queries , Gzip On.
