查看: 1836|回复: 0
[文件] (XD::FILE:ResolveRelativePath)相对路径处理
已领礼包: 20个
发表于 2017-12-11 10:53:19 | 显示全部楼层 |阅读模式
函数发布
函数名称: XD::FILE:ResolveRelativePath
调用格式: (XD::FILE:ResolveRelativePath filePath dwgPath)
参数说明: fileNamePath --- 文件路径
dwgPath --- DWG文件目录
返回值: 字符串
函数简介: 相对路径处理
函数来源: 转载
函数作者: marting
适用版本: 不限
最后更新时间: 2017-12-11
备注: -
演示图片: -
  1. ;; Returns a filename based on the resolved path
  2. ;; Usage: (XD::FILE:ResolveRelativePath "..\\grid.dwg" (getvar "dwgprefix"))
  3. (defun XD::FILE:ResolveRelativePath (fileNamePath dwgPath / )
  4.   ; Check for relative paths and attempt to resolve the path to the xref
  5.   (cond
  6.     ; Relative path, should resolve multiple levels of relative folders; DWG file must be saved
  7.     ((and (= (substr fileNamePath 1 2) "..")(/= (getvar "dwgprefix") ""))
  8.       (while (= (substr fileNamePath 1 2) "..")
  9.         (setq fileNamePath (substr fileNamePath 4)
  10.               dwgPath (substr dwgPath 1 (vl-string-position (ascii "\\") dwgPath 0 T))
  11.         )
  12.       )
  13.       (setq fileNamePath (strcat dwgPath "\\" fileNamePath))
  14.     )
  15.     ; Absolute paths, resolves only the top level folder; DWG file must be saved
  16.     ((and (= (substr fileNamePath 1 1) ".")(/= (getvar "dwgprefix") ""))
  17.       (setq fileNamePath (substr fileNamePath 3)
  18.             fileNamePath (strcat dwgPath "\\" fileNamePath)
  19.       )
  20.     )
  21.   )
  22.   ; Check to see if the fileNamePath is valid, if not then attempt to locate the file in the working support path
  23.   (if (not (findfile fileNamePath))
  24.     (setq fileNamePath (findfile (strcat (vl-filename-base fileNamePath) (vl-filename-extension fileNamePath))))
  25.     (if (= (vl-filename-directory fileNamePath) "")
  26.       (setq fileNamePath (findfile fileNamePath))
  27.     )
  28.   )
  29.   ; Returns the resolved path with filename, if the path couldn't be resolved
  30.   ; then the original fileNamePath is returned
  31.   fileNamePath
  32. )
GMT+8, 2026-11-2 22:08 , Processed in 0.438980 second(s), 31 queries , Gzip On.
