查看: 1385|回复: 3
[每日一码] FSO 的 ReadAll 方法
已领礼包: 859个
发表于 2017-12-16 16:58:21 | 显示全部楼层 |阅读模式
  1. (defun readall (fn / fso f)
  2.   (if (and (setq
  3.          fso (vlax-get-or-create-object "scripting.filesystemobject")
  4.        )
  5.        (setq f (vlax-invoke fso 'opentextfile fn 1 :vlax-true))
  6.       )
  7.     (progn
  8.       (setq s (vlax-invoke f 'readall))
  9.      (vlax-invoke f 'close)
  10.       (vlax-release-object f)
  11.       (vlax-release-object fso)
  12.       s
  13.     )
  14.   )
  15. )
按行拆分可以使用
  1. (XD::String:RegExpS "[^\r\n]+" (readll "x:\\xxx.txt") "")
复制代码
Description
Opens a specified file and returns a TextStream object that can be used to read from or append to the file.
Syntax
object.OpenTextFile(filename[, iomode[, create[, format]]])
The OpenTextFile method has these parts:
PartDescription
objectRequired. Always the name of a FileSystemObject.
filenameRequired. String expression that identifies the file to open.
iomodeOptional. Indicates input/output mode. Can be one of two constants, either ForReading or ForAppending.
createOptional. Boolean value that indicates whether a new file can be created if the specified filename doesn't exist. The value is True if a new file is created; False if it isn't created. The default is False.
formatOptional. One of three Tristate values used to indicate the format of the opened file. If omitted, the file is opened as ASCII.
Settings
The iomode argument can have either of the following settings:
ConstantValueDescription
ForReading1Open a file for reading only. You can't write to this file.
ForAppending8Open a file and write to the end of the file.
The format argument can have any of the following settings:
TristateUseDefault2Opens the file using the system default.
TristateTrue1Opens the file as Unicode.
TristateFalse  0Opens the file as ASCII.
已领礼包: 145个
发表于 2017-12-16 21:05:00 | 显示全部楼层
怎么调用自身了? f 是打开的文本文件, 接着调用 f 的 readall,读取文本文件的所有内容。
回复 支持 1 反对 0
已领礼包: 604个
发表于 2017-12-16 20:50:47 | 显示全部楼层
学习一下,(setq s (vlax-invoke f 'readall))这样调用自身有什么好处?
已领礼包: 604个
发表于 2017-12-16 21:29:45 | 显示全部楼层
o,老大,原来我不知道f有readall方法。
GMT+8, 2026-11-5 09:34 , Processed in 0.170108 second(s), 36 queries , Gzip On.
