查看: 1534|回复: 0
[每日一码] (XDRX API)AutoLisp SHELL 扩展
发表于 2017-12-16 17:37:46 | 显示全部楼层 |阅读模式
XDRX API 从 2017.1215版本,提供SHELL扩展给LISP,例子如下,关于SHELL可以做什么,可以百度。
SHELL函数:
xdrx_shell_open
xdrx_shell_readdata
xdrx_shell_writedata
xdrx_shell_close
xdrx_shell_getlasterror
  1. ;;; Test 2
  2. ;;; 改变目录到 D盘的drivers目录, 获取目录
  3. ;;; 列表并打印到AUTOCAD命令行
  4. ;;; 如何使用 && 和命令的组合的例子。
  5. (defun c:test2 (/ handle sResult)
  6.   (setq        handle (xdrx_shell_open "c:\\windows\\system32\\cmd.exe"
  7.                           "/c d: && cd \\drivers\\ && dir"
  8.                )
  9.   )
  10.   (if (/= nil handle)
  11.     (progn
  12.       (while (/= nil (setq sResult (xdrx_shell_readdata handle)))
  13.         (princ sResult)
  14.       )
  15.       (xdrx_shell_close handle)
  16.     )
  17.   )
  18.   (princ)
  19. )
  1. ;;; test 3
  4. ;;; 如何使用管道和 && 和命令的组合的例子。
  5. (defun c:test3 (/ handle sResult)
  7.                           "/c d: && cd \\drivers\\ && dir | sort"
  8.                )
  9.   )
  11.     (progn
  13.         (princ sResult)
  14.       )
  16.     )
  17.   )
  18.   (princ)
  19. )
  1. (defun c:test4 (/ handle sResult sContents)
  2.   (setq        handle (xdrx_shell_open "c:\\windows\\system32\\cmd.exe"
  3.                           "/c type \\Windows\\system.ini"
  4.                )
  5.   )
  6.   (if (/= nil handle)
  7.     (progn
  8.       (setq sContents "")
  9.       (while (/= nil (setq sResult (xdrx_shell_readdata handle)))
  10.         (setq sContents (strcat sContents sResult))
  11.       )
  12.       (xdrx_shell_close handle)
  13.     )
  14.   )
  15.   (princ sContents)
  16.   (princ)
  17. )
  1. ;;; Opens cmd.exe shell using the envirnment variable %comspec% if set.
  2. ;;; The sort program is run and input is provided via the xdrx_shell_writedata
  3. ;;; function. This test provides a single string with carriage seperating
  4. ;;; the words of the input. This is one way to provide line buffered input.
  5. (defun c:Test5 (/ handle sResult)
  6.   (setq handle (xdrx_shell_open "%comspec%" "/c sort"))
  7.   (if (/= nil handle)
  8.     (progn
  9.       (xdrx_shell_writedata handle "There\nis\na\nfly\n")
  10.       (setq sResult (xdrx_shell_readdata handle))
  11.       (if (/= nil sResult)
  12.         (princ sResult)
  13.       )
  14.     )
  16.   )
  17.   (princ)
  18. )
  2. ;;; The sort program is run and input is provided to it through xdrx_shell_writedata
  3. ;;; by calling it multiple times.
  4. (defun c:Test6 (/ aList handl sResult)
  5.   (setq aList (list "Lost" "in" "the" "swamp" "with" "the" "gaters"))
  8.     (progn
  9.       (foreach s aList (xdrx_shell_writedata handle (strcat s "\n")))
  12.         (princ sResult)
  13.       )
  14.     )
  16.   )
  17.   (princ)
  18. )
GMT+8, 2026-11-22 11:08 , Processed in 0.274785 second(s), 10 queries , Gzip On, File On.
