查看: 1271|回复: 1
[每日一码] 文本转MLEADER程序
发表于 2017-12-18 09:08:01 | 显示全部楼层 |阅读模式
[JavaScript] 纯文本查看 复制代码
(defun c:txt2mleader (/ newleader pt1 pt2 ss txt x w rjp-getbbwdth)
  (vl-load-com)
  (defun rjp-getbbwdth (obj / out ll ur)
    (vla-getboundingbox obj 'll 'ur)
    (setq out (mapcar 'vlax-safearray->list (list ll ur)))
    (distance (car out) (list (caadr out) (cadar out)))
  (if (setq ss (ssget '((0 . "*TEXT"))))
    (progn (setq txt (apply
		       'strcat
		       (mapcar
			 'cdr
			 (vl-sort
			   (mapcar '(lambda (x)
				      (cons (vlax-get x 'insertionpoint)
					    (strcat (vlax-get x 'textstring) " ")
				   (setq
				     ss	(mapcar
					  'vlax-ename->vla-object
					  (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
			   (function (lambda (y1 y2) (< (cadr (car y2)) (cadr (car y1))))
		 w   (car (vl-sort (mapcar 'rjp-getbbwdth ss) '>))
		 txt (apply 'strcat
			    (mapcar 'chr (reverse (cdr (reverse (vl-string->list txt)))))
	   (mapcar 'vla-delete ss)
  (if (and (setq pt1 (getpoint "\nSpecify leader arrowhead location: "))
	   (setq pt2 (getpoint pt1 "\nSpecify landing location: "))
    (progn (command "._MLEADER" pt1 pt2 "")
	   (setq newleader (vlax-ename->vla-object (entlast)))
	   (vla-put-textstring newleader txt)
	   (vla-put-textwidth newleader w)
  (princ)
已领礼包: 85个
发表于 2017-12-18 10:11:27 | 显示全部楼层
学习学习
GMT+8, 2026-11-5 10:57 , Processed in 0.340074 second(s), 31 queries , Gzip On.
