查看: 1973|回复: 3
[求助] grread的track问题
发表于 2017-12-20 16:05:13 | 显示全部楼层 |阅读模式
(grread [track] [allkeys [curtype]])
Only specialized AutoLISP routines need this function. Most input to AutoLISP should be obtained through the various getxxx functions.
Arguments
trackIf supplied and not nil, this argument enables the return of coordinates from a pointing device as it is moved.请问这句话是什么意思呀?关键怎么用?
求指点,能写过简单的例子就更好了。
谢谢了。
已领礼包: 488个
发表于 2017-12-20 16:29:38 | 显示全部楼层
后面不是有例子:
(setq code_12 (grread (setq code (grread))))
已领礼包: 20个
发表于 2017-12-20 16:30:53 | 显示全部楼层
 楼主| 发表于 2017-12-20 16:35:49 | 显示全部楼层
我想问的是trackIf 这个参数怎么用呀?求指点,能有个简单的例子就更好了。
GMT+8, 2026-11-5 09:34 , Processed in 0.373641 second(s), 35 queries , Gzip On.
