查看: 1145|回复: 2
[每日一码] 用VL锁定视口
发表于 2017-12-22 21:12:05 | 显示全部楼层 |阅读模式
Question
Is it possible to lock a viewport using Visual LISP?
Answer
It is not possible to lock the viewport by using (entmod).  However, it can
be successfully done using ActiveX functions.  The following sample code checks
the viewport object's DisplayLocked property and, if currently unlocked, proceeds
to lock it:
[JavaScript] 纯文本查看 复制代码
(vl-load-com)
(setq app (vlax-get-acad-object)
         doc (vla-get-activedocument app)
         ent (car (entsel "\nSelect a viewport:"))
         obj (vlax-ename->vla-object ent)
(if (= (vlax-get-property obj 'objectName) "AcDbViewport")
   (progn
      (setq vpLk (vlax-get-property obj 'DisplayLocked))
      (if (= vpLk :vlax-false)
         (progn
            (vlax-put-property obj 'DisplayLocked :vlax-true)
            (alert "Viewport is now locked")
         (alert "Viewport was already locked")
   (alert "Not a viewport")
After executing this code we can not zoom into the viewport:
Command: ms MSPACE
Command: z ZOOM
Viewport is view-locked. Switching to Paper space.
已领礼包: 6468个
发表于 2017-12-24 00:05:50 | 显示全部楼层
沙发。支持楼主。
已领礼包: 146个
发表于 2017-12-24 14:43:07 | 显示全部楼层
学习了
GMT+8, 2026-11-5 08:55 , Processed in 0.337700 second(s), 33 queries , Gzip On.
