查看: 1383|回复: 2
[每日一码] C# 拷贝对象的扩展词典到另外一个对象
已领礼包: 6个
发表于 2017-12-27 19:35:40 | 显示全部楼层 |阅读模式
下面的命令显示了将扩展字典条目从一个实体复制到另一个实体的过程。 最后放置一个特殊的逻辑,将与源对象相同的字典名称设置为“DeepCloneObjects”,将具有不同名称的对象复制到目标实体中。
[C#] 纯文本查看 复制代码
[CommandMethod("copyExtDic")]
public void copyExtDic()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    PromptEntityResult surRes =
                ed.GetEntity("Select source entity");
    if (surRes.Status != PromptStatus.OK)
        return;
    PromptEntityResult tarRes =
                ed.GetEntity("Select target entity");
    if (tarRes.Status != PromptStatus.OK)
        return;
    ObjectIdCollection ids = new ObjectIdCollection();
    ObjectId tarId = ObjectId.Null;
    ObjectId surId = ObjectId.Null;
    using (Transaction tr =
            db.TransactionManager.StartTransaction())
        DBObject dbObj = tr.GetObject(surRes.ObjectId,
                                       OpenMode.ForRead);
        surId = dbObj.ExtensionDictionary;
        if (surId != ObjectId.Null)
            DBDictionary dbExt =
                      (DBDictionary)tr.GetObject(surId,
                                    OpenMode.ForRead);
            foreach (DBDictionaryEntry entry in dbExt)
                ids.Add(entry.Value);
        else
            ed.WriteMessage("No dictionary to copy");
            return;
        //find if entiy has
        DBObject target = tr.GetObject(tarRes.ObjectId,
                                          OpenMode.ForRead);
        tarId = target.ExtensionDictionary;
        if (tarId == ObjectId.Null)
            target.UpgradeOpen();
            target.CreateExtensionDictionary();
        tr.Commit();
    IdMapping mapping = new IdMapping();
    db.DeepCloneObjects(ids, tarId, mapping, false);
         (DBDictionary)tr.GetObject(surId, OpenMode.ForRead);
        DBDictionary dbTarg =
            (DBDictionary)tr.GetObject(tarId, OpenMode.ForWrite);
        foreach (IdPair pair in mapping)
            DBObject target = tr.GetObject(pair.Value,
                                              OpenMode.ForRead);
            dbTarg.SetName(
                dbTarg.NameAt(pair.Value),
                dbExt.NameAt(pair.Key));
        tr.Commit();
已领礼包: 50个
发表于 2017-12-27 20:13:53 | 显示全部楼层
支持,难得此专栏还默默分享
发表于 2018-1-3 11:10:54 | 显示全部楼层
请问大神DBDictionaryEntry缺少引用怎么解决
GMT+8, 2026-11-2 21:46 , Processed in 0.478996 second(s), 31 queries , Gzip On.
